5 Replies Latest reply on Feb 16, 2012 11:12 AM by prodigalmaster
    remove elements from Array
    sensiblemind Level 1
      Hi all
      if i have array like
      var my_Arr:Array = new Array("a", "b", "c");
      and i have button to use random element of ths array , is there any to remove that element  that if i press the button again i won't find the last element ?
      could somebody help me out...?
      thnx
      Wael
        • 1. Re: remove elements from Array
          prodigalmaster Level 2
          var someArray:Array = [1,2,3,4,5,6,7,8,9];
          someArray.shift(); //remove first value (1)
          someArray.pop();//remove final value (9)
          if you type: someArray. then a list of possibilities will come up and you can see which each one does, e.g. .reverse probably reverses the array e.g. 9, 8, 7 ..etc.
          • 2. Re: remove elements from Array
            yes thank you , and also it help to undo the random selection to use reverse probably
            thnx prodigalmaster
            • 3. Re: remove elements from Array
              No problem. Althought I don't see how reverse would undo the random selection at all.
              • 4. Re: remove elements from Array
                Actually you are right , i thought when i reverse the Array i could have Random value
                BUT is there a way to random the array and select item that i can remove it from my array ?
                here is the code i tried to make
                var someArray:Array = [1, 2, 3, 4, 5, 6, 7, 8, 9];
                random_But.onRelease = function()
                          trace(someArray.reverse());
                          txt = someArray[0];
                          trace("1st element   "    + someArray[0]);
                          someArray.shift();//remove first value (1)
                          //trace(someArray.length);
                          if (someArray.length <= 1)
                                    this.enabled = false;
                i appreciate your Help
                • 5. Re: remove elements from Array
                  Make a variable and give it a random value with Math.round(Math.random()*randomNumber); or to simplify just use random(randomNumber).
                  Then remove a value from someArray using that variable.
                  A quick google search showed that what you need is splice:
                  someArray.splice(randomNumber,1); //index of value in array, count of values to delete e.g. if it was 2 then it would deleted the value in the index and the next
                  Therefore:
                  var randomNumber = random(someArray.length);
                  random_But.onRelease = function() {
                  someArray.splice(randomNumber, 1);//removes 1 random element
                  txt = someArray[0];
