2 Replies Latest reply on Feb 13, 2012 9:06 AM by Maury boy
    Context Sensitive Help in RH9
    Maury boy
      Previously we were using Whats This Help made in RH, but after spending hours working with Adobe support staff, we found that What's This Help made in RH are not compatible with 64bit systems. (Adobe support staff has stated this to be the case.)
      We need to learn about other ways of making Context Sensitive Helps using RH9. The easiest way is using the .chm file to create topic-level CSH, but our proprietary program that it will be used with is really huge and the development team can't spare the time to work Map IDs  and so on.
      Maybe someone knows about other options and can make a few suggestions.
      Thank you
        • 1. Re: Context Sensitive Help in RH9
          Hi there
          I do understand how reluctant developers can be to work with this. But I might think that if they had set up for "What's This" help, they have most of what is needed done already. After all, doesn't that require a unique mapping to nearly every field on a dialog?
          One approach would be to map each dialog to a topic. Then describe the individual fields in the topic. If you used heading levels coupled with a Mini TOC, it should be pretty straightforward.
          Another thing to ask the developers is if the app is running in 64 bit or 32 bit mode on 64 bit systems. While I'm not a developer, I do work with one and recently saw a note advising that certain things were corrected in his app by forcing it to run in 32 bit mode on 64 bit systems. I'm wondering if they can accomplish that, if it will restore the What's This functionality? Might be worth suggesting.
          Cheers... Rick
          Helpful and Handy Links
          RoboHelp Wish Form/Bug Reporting Form
          Begin learning RoboHelp HTML 7, 8 or 9 within the day!
          Adobe Certified RoboHelp HTML Training
          SorcerStone Blog
          RoboHelp eBooks
          • 2. Re: Context Sensitive Help in RH9
            Maury boy Level 1
            Thank you for your input. I'll forward your email to the R&D manager.
            Actually, I kept the original email as short as possible, and left out
            some history.
            We have a completely new Devel. Team (offshore), and they can't spare
            the time.
            Also, the What's This Helps work in the same 32bit environment, and also
            in a 64 bit virtual machine emulation (in 32 bit), but in a native 64
            bit environment they don't even show up. 64bit is the new wave and we
            have to be able to support that.
            We spent hours on the phone with Adobe support on this issue, and until
            the very end they assured us that it would work. Finally, their testing
            proved that it wouldn't work. Dead end. (Can't fault them. They worked
            very hard on the case. That's just the way it goes.)
            We just looking for different options
            Respectfully,
            Joe Lacey
            Technical Writer
            Amada America, Inc.
            Buena Park, CA
