3 Replies Latest reply on Feb 13, 2012 8:38 AM by kglad
    Trouble with an escape the room game.
    maxus phinus
      This part that I'm working on consists of trading a hobo some twine for his alcohol. I'm trying to get the twine to disappear with dropped on the hobo, as well as the alcohol he is holding, which makes the twine leave my inventory and replaces it with the alcohol. So for I can get the twine to disappear correctly, but the alcohol can appear and disappear in some instances when I don't want them to.
      here's the code on the twine in the inventory
      onClipEvent (load) {
                this.tabEnabled = false;
                this._visible = false;
                orig_x = this._x;
                orig_y = this._y;
      on (press) {
                this.startDrag();
      on (release) {
                this.stopDrag();
                if (eval(this._droptarget) == this._parent.hobo.hobogive) {
                               _global.hobobooze = 1
                               _global.alcohol = 1
                               this._root.inv_alcohol._visible = true;}
      on (release) {
                this.stopDrag();
                this._x = orig_x;
                this._y = orig_y;
                if (eval(this._droptarget) == undefined)
                     this._visible = true;
                     this._root.inv_alcohol._visible = false;
                     //if i don't have the last line then
                     //the alcohol appears no matter where i drag the twine
      What i have for the alcohol in the inventory
      and what is on the alcohol the hobo is holding
                if (_global.hobobooze == 0)
                {this._visible = true;
                if (_global.hobobooze == 1)
                {this._visible = false;
        • 1. Re: Trouble with an escape the room game.
          1.  you shouldn't have any code attached to objects.
          2.  your twine's first on(release) does nothing.  to remedy, replace:
          on (release) {
                    this.stopDrag();
                                   _global.alcohol = 1
          on (release) {
                    this.stopDrag();
                    this._x = orig_x;
                    this._y = orig_y;
          //with
          on (release) {
                                   _global.alcohol = 1
                    this.stopDrag();
                    this._x = orig_x;
                    this._y = orig_y;
          • 2. Re: Trouble with an escape the room game.
            maxus phinus Level 1
            that cleans up my code, but i'm still experiencing the same problems with the alcohol not appearing in my inventory on que. i figured out what was wrong with the bottle the hobo is holding so i'm trying to work around that
            • 3. Re: Trouble with an escape the room game.
              check your logic.  use the trace() function to see what flash is doing.
