2 Replies Latest reply on Feb 15, 2012 1:17 PM by V.J.B
    Problem exiting eclipse 3.7 while using FB4.6 Plugin
    V.J.B
      I've tried many different versions of eclipse and I've come down to the realization that it is FB4.6.
      Everytime I exit eclipse a pop up saying there are errors look in the metadata/.log file.
      It appears as if FB4.6 is missing some of the plugins that it is trying to use. Any solutions?
      Here is the .log File:
      This is using eclipse 3.6. Every other version that I tested throws a similar if not identical .log file.
      I've tried reinstalling everything, and starting in a clean work environment.
      !SESSION 2012-02-13 20:03:21.468 -----------------------------------------------
      eclipse.buildId=I20100608-0911
      java.version=1.6.0_14
      java.vendor=BEA Systems, Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
      Command-line arguments:  -os win32 -ws win32 -arch x86
      !ENTRY org.eclipse.osgi 2 0 2012-02-13 20:04:16.210
      !MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
      !SUBENTRY 1 org.eclipse.osgi 2 0 2012-02-13 20:04:16.210
      !MESSAGE Bundle reference:file:../Adobe/Adobe Flash Builder 4.6/eclipse/plugins/org.eclipse.core.runtime.compatibility.registry.nl1_3.7.0.v2011071604 3402.jar was not resolved.
      !SUBENTRY 2 org.eclipse.core.runtime.compatibility.registry.nl1_3.7.0.v20110716043402 2 0 2012-02-13 20:04:16.210
      !MESSAGE Missing host org.eclipse.core.runtime.compatibility.registry_[0.0.0,9.0.0).
      !MESSAGE Bundle reference:file:../Adobe/Adobe Flash Builder 4.6/eclipse/plugins/org.eclipse.equinox.security.win32.x86.nl1_3.7.0.v20110716043402.jar was not resolved.
      !SUBENTRY 2 org.eclipse.equinox.security.win32.x86.nl1_3.7.0.v20110716043402 2 0 2012-02-13 20:04:16.210
      !MESSAGE Missing host org.eclipse.equinox.security.win32.x86_[0.0.0,9.0.0).
      !MESSAGE Bundle reference:file:../Adobe/Adobe Flash Builder 4.6/eclipse/plugins/org.eclipse.ui.workbench.compatibility.nl1_3.7.0.v20110716043402.jar was not resolved.
      !SUBENTRY 2 org.eclipse.ui.workbench.compatibility.nl1_3.7.0.v20110716043402 2 0 2012-02-13 20:04:16.210
      !MESSAGE Missing host org.eclipse.ui.workbench.compatibility_[0.0.0,9.0.0).
      !MESSAGE Bundle reference:file:../Adobe/Adobe Flash Builder 4.6/eclipse/plugins/org.eclipse.swt.win32.win32.x86.nl1_3.7.0.v20110716043402.jar was not resolved.
      !SUBENTRY 2 org.eclipse.swt.win32.win32.x86.nl1_3.7.0.v20110716043402 2 0 2012-02-13 20:04:16.210
      !MESSAGE Missing host org.eclipse.swt.win32.win32.x86_[0.0.0,9.0.0).
      !MESSAGE Bundle reference:file:../Adobe/Adobe Flash Builder 4.6/eclipse/plugins/org.eclipse.ui.win32.nl1_3.7.0.v20110716043402.jar was not resolved.
      !SUBENTRY 2 org.eclipse.ui.win32.nl1_3.7.0.v20110716043402 2 0 2012-02-13 20:04:16.210
      !MESSAGE Missing host org.eclipse.ui.win32_[0.0.0,9.0.0).
      !MESSAGE Bundle reference:file:../Adobe/Adobe Flash Builder 4.6/eclipse/plugins/org.eclipse.core.net.win32.x86.nl1_3.7.0.v20110716043402.jar was not resolved.
      !SUBENTRY 2 org.eclipse.core.net.win32.x86.nl1_3.7.0.v20110716043402 2 0 2012-02-13 20:04:16.210
      !MESSAGE Missing host org.eclipse.core.net.win32.x86_[0.0.0,9.0.0).
      !MESSAGE Bundle reference:file:../Adobe/Adobe Flash Builder 4.6/eclipse/plugins/org.eclipse.equinox.launcher.win32.win32.x86.nl1_3.7.0.v2011071604340 2.jar was not resolved.
      !SUBENTRY 2 org.eclipse.equinox.launcher.win32.win32.x86.nl1_3.7.0.v20110716043402 2 0 2012-02-13 20:04:16.210
      !MESSAGE Missing host org.eclipse.equinox.launcher.win32.win32.x86_[0.0.0,9.0.0).
      !MESSAGE Bundle reference:file:../Adobe/Adobe Flash Builder 4.6/eclipse/plugins/org.eclipse.jdt.compiler.apt.nl1_3.7.0.v20110716043402.jar was not resolved.
      !SUBENTRY 2 org.eclipse.jdt.compiler.apt.nl1_3.7.0.v20110716043402 2 0 2012-02-13 20:04:16.210
      !MESSAGE Missing host org.eclipse.jdt.compiler.apt_[0.0.0,9.0.0).
      !MESSAGE Bundle reference:file:../Adobe/Adobe Flash Builder 4.6/eclipse/plugins/org.eclipse.core.filesystem.win32.x86.nl1_3.7.0.v20110716043402.jar was not resolved.
      !SUBENTRY 2 org.eclipse.core.filesystem.win32.x86.nl1_3.7.0.v20110716043402 2 0 2012-02-13 20:04:16.210
      !MESSAGE Missing host org.eclipse.core.filesystem.win32.x86_[0.0.0,9.0.0).
      !MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
      !MESSAGE Bundle org.eclipse.core.runtime.compatibility.registry_3.3.0.v20100520 [40] was not resolved.
      !MESSAGE Bundle org.eclipse.ecf.provider.filetransfer.httpclient.ssl_1.0.0.v20100529-0735 [50] was not resolved.
      !MESSAGE Bundle org.eclipse.ecf.provider.filetransfer.ssl_1.0.0.v20100529-0735 [51] was not resolved.
      !MESSAGE Bundle org.eclipse.ecf.ssl_1.0.0.v20100529-0735 [52] was not resolved.
      !MESSAGE Bundle org.eclipse.ui.workbench.compatibility_3.2.100.I20100511-0800 [181] was not resolved.
      !MESSAGE Bundle org.eclipse.core.filesystem.win32.x86.nl1_3.7.0.v20110716043402_3.7.0.v20110716043402 [382] was not resolved.
      !MESSAGE Bundle org.eclipse.core.net.win32.x86.nl1_3.7.0.v20110716043402_3.7.0.v20110716043402 [385] was not resolved.
      !MESSAGE Bundle org.eclipse.core.runtime.compatibility.registry.nl1_3.7.0.v20110716043402_3.7.0.v20110716 043402 [390] was not resolved.
      !MESSAGE Bundle org.eclipse.equinox.launcher.win32.win32.x86.nl1_3.7.0.v20110716043402_3.7.0.v20110716043 402 [427] was not resolved.
      !MESSAGE Bundle org.eclipse.equinox.security.win32.x86.nl1_3.7.0.v20110716043402_3.7.0.v20110716043402 [461] was not resolved.
      !MESSAGE Bundle org.eclipse.jdt.compiler.apt.nl1_3.7.0.v20110716043402_3.7.0.v20110716043402 [472] was not resolved.
      !MESSAGE Bundle org.eclipse.swt.win32.win32.x86.nl1_3.7.0.v20110716043402_3.7.0.v20110716043402 [574] was not resolved.
      !MESSAGE Bundle org.eclipse.ui.win32.nl1_3.7.0.v20110716043402_3.7.0.v20110716043402 [601] was not resolved.
      !MESSAGE Bundle org.eclipse.ui.workbench.compatibility.nl1_3.7.0.v20110716043402_3.7.0.v20110716043402 [603] was not resolved.
      !ENTRY org.eclipse.osgi 4 0 2012-02-13 20:04:16.210
      !MESSAGE Application error
      !STACK 1
      org.eclipse.swt.SWTException: Failed to execute runnable (java.lang.NullPointerException)
                at org.eclipse.swt.SWT.error(SWT.java:4083)
                at org.eclipse.swt.SWT.error(SWT.java:3998)
                at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:137)
                at org.eclipse.swt.widgets.Display.runAsyncMessages(Display.java:4041)
                at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3660)
                at org.eclipse.swt.widgets.Display.release(Display.java:3713)
                at org.eclipse.swt.graphics.Device.dispose(Device.java:295)
                at org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:131)
                at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
                at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
                at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
                at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
                at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
                at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
                at java.lang.reflect.Method.invoke(Method.java:597)
                at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:619)
                at org.eclipse.equinox.launcher.Main.basicRun(Main.java:574)
                at org.eclipse.equinox.launcher.Main.run(Main.java:1407)
                at org.eclipse.equinox.launcher.Main.main(Main.java:1383)
      Caused by: java.lang.NullPointerException
                at com.adobe.flexbuilder.ui.UIPlugin$3.run(UIPlugin.java:186)
                at org.eclipse.swt.widgets.RunnableLock.run(RunnableLock.java:35)
                at org.eclipse.swt.widgets.Synchronizer.runAsyncMessages(Synchronizer.java:134)
                at org.eclipse.swt.graphics.Device.dispose(Device.java:296)
                at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
                at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
                ... 1 more
