2 Replies Latest reply on Feb 16, 2012 6:18 AM by Soren Hoy
    Livecycle populate text field with multiple records from list box
    Legro22
      Can someone tell me how can I populate a text field from list box when I have multiple select.
      Here is example:
      List box consist: Hello
                               World.
      I want to see this in text field: Hello,World.
      Thanks!
        • 1. Re: Livecycle populate text field with multiple records from list box
          paulk07 Level 3
          if(xfa.event.prevText=="")
          textfield.rawValue = xfa.event.newText;
          if(xfa.event.prevText!="")
          textfield.rawValue = texfield.rawValue+"\n"+xfa.event.newText;
          I think something like this may work.
          • 2. Re: Livecycle populate text field with multiple records from list box
            Soren Hoy Level 1
            Hi Legro
            I don't know if I understand you correctly, but you can do something like this:
            ----------------- java script begin ---------------------------------
            //Reset text field
            TextField.rawValue = "";
            //loop through items in listbox
            for(i = 0; i < ListBox.length; i++)
                      //if item selected
                      if(ListBox.getItemState(i))
                                //check if Text field value if null
                                if (TextField.isNull)
                                          TextField.rawValue = ListBox.getDisplayItem(i);
                                else
                                          TextField.rawValue = TextField.rawValue + " " + ListBox.getDisplayItem(i);
            ----------------- java script end ---------------------------------
            I have attached an sample PDF so that you can see how it works!!
            Kind Regards
            Søren Høy Nielsen Dafolo A/S
