0 Replies Latest reply on Feb 14, 2012 3:02 AM by like_it
    Filtering List using richeditable text (sdk 4.1)
    like_it
      Hi All,
      I am facing a trouble with list and richeditable text
      MainApplication.mxml
                     creationComplete="group1_creationCompleteHandler(event)"
                     xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
          <fx:Script>
              <![CDATA[
                  import mx.collections.ArrayCollection;
                  import mx.events.FlexEvent;
                  import spark.events.TextOperationEvent;
                  protected function textInputId_changeHandler(event:TextOperationEvent):void
                      //checkContains();
                      dataProvider.refresh();
                  public function checkContains():void
                      var tempApp:ArrayCollection=new ArrayCollection();
                      var toCheck:String=null;
                      var tempArrayIndex:int=0;
                      for(var index:int=0;index<dataProvider.length ;index++)
                          toCheck=dataProvider.getItemAt(index) as String;
                          var startIndex:int;
                          if((startIndex=toCheck.toUpperCase().indexOf(textInputId.text.toUpperCase()))>=0)
                              var o:Object=new Object();
                              o["startIndex"]=startIndex;
                              o["endIndex"]=startIndex+(textInputId.text.length);
                              o["data"]=toCheck;
                              tempApp.addItem(o);
                              /* mainTempArrayIndexDictionary[tempArrayIndex++]=index;     */
                      list.dataProvider=tempApp;
                  [Bindable]
                  var dataProvider:ArrayCollection=new ArrayCollection();
                  protected function group1_creationCompleteHandler(event:FlexEvent):void
                      o["startIndex"]=0;
                      o["endIndex"]=0;
                      o["data"]="A1sgdfg";
                      dataProvider.addItem(o);
                      o=new Object();
                      o["startIndex"]=0;
                      o["endIndex"]=0;
                      o["data"]="Artrter2";
                      o=new Object();
                      o["startIndex"]=0;
                      o["endIndex"]=0;
                      o["data"]="A3cxbvxcxv";
                      dataProvider.filterFunction=filterFunctionType;
                  public function filterFunctionType(o:Object):Boolean
                      var startIndex:int;
                      if((startIndex=(o["data"] as String).toUpperCase().indexOf(textInputId.text.toUpperCase()))>=0)
                          return true;
                      else
                          return false;
          </fx:Script>
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
          </fx:Declarations>
          <s:VGroup width="10%" height="100%">
              <s:BorderContainer width="100%" height="20" borderColor="0x18181B">
                  <mx:Spacer width="100%" height="2"/>
                  <s:RichEditableText change="textInputId_changeHandler(event)" verticalAlign="middle" width="100%" height="100%" id="textInputId" fontWeight="bold"/>
              </s:BorderContainer>
              <s:List itemRenderer="DefaultItemrenderer"  id="list" dataProvider="{dataProvider}" width="100%" height="95%"
                      alternatingItemColors="[0xF5EDE4, 0xFFFFFFF]"/>
          </s:VGroup>
      </s:Application>
      DefaultItemrenderer.mxml
      <s:ItemRenderer xmlns:fx="http://ns.adobe.com/mxml/2009"
                      xmlns:mx="library://ns.adobe.com/flex/mx" >
          <fx:Declarations>
          </fx:Declarations>
          <fx:Script>
              <![CDATA[
                  import flashx.textLayout.formats.TextLayoutFormat;
                  import mx.controls.textClasses.TextRange;
                  import spark.components.RichEditableText;
                  public var textLayoutFormat:TextLayoutFormat = new TextLayoutFormat();
                      override public function set data(value:Object):void
                      if(value)
                          if(value is String)
                              textLabel.text=value as String;
                          else
                              textLabel.text=value["data"] as String;
                              textLayoutFormat.backgroundColor = 0xC4C4C4;
                              trace(value["data"]+"  "+value["startIndex"]+"   "+value["endIndex"]);
                              textLabel.setFormatOfRange(textLayoutFormat,value["startIndex"] as int,value["endIndex"] as int);
                              textLabel.validateNow();
                      super.data=value;
          </fx:Script>
          <s:VGroup id="g" width="100%" height="100%" paddingTop="5" paddingLeft="3">
              <s:RichEditableText  editable="false" id="textLabel"/>
          </s:VGroup>
      </s:ItemRenderer>
      Now . when you run this application ,  the text box at the top acts as a filter to the list and selcted text gets highlighted  . For e.g. try "A1sg" , you could see only 1 record in list with "A1sg" highlighted . Now remove "g" from "A1sg" , but as u can see still the highlighting is in "A1sg" where as filter is "A1s". Now remove "s" from "A1s" leaving filter to be "A1" but still the highlighting doesnt change. Now remove "1" leaving filter to "A" , now you can see some change.
      I have verified that filtering is working fine.not sure why it doesnt get reflected.
      Can some one please help me on this.
