I have just install Adobe AIR 3 and my application MyHDPrototype on a Windows Server 2008 R2, but my application crash while launching with this error :
Problem signature:
Problem Event Name: APPCRASH
Application Name: MyHDPrototype.exe
Application Version: 0.0.0.0
Application Timestamp: 4eb75b06
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7600.16850
Fault Module Timestamp: 4e211485
Exception Code: 40010006
Exception Offset: 0000b9bc
OS Version: 6.1.7600.2.0.0.272.7
Locale ID: 1033
Additional Information 1: 1e91
Additional Information 2: 1e91040eb9ce625050ba88148d4364c0
Additional Information 3: bc94
Additional Information 4: bc949dae699561fad889eac3081eb041
Any Idea ?
Hi David,
I'm not familiar with this app. Do you have a link to it? Would you also mind generating a crash dump for me? Please see this post for two .reg files that will enable/disable crash logging.
Chris
Hi Chris,
My Application do absolutly nothing
<s:WindowedApplication width="300"
height="450"
title="MyHDRenderer (prototype version)"
xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:mx="library://ns.adobe.com/flex/mx"
xmlns:s="library://ns.adobe.com/flex/spark">
<fx:Declarations>
<!-- Placer ici les éléments non visuels (services et objets de valeur, par exemple). -->
</fx:Declarations>
<s:layout>
<s:VerticalLayout/>
</s:layout>
<s:Label text="Arguments : "/>
<s:List width="100%" height="100%"/>
<s:Button label="close"/>
</s:WindowedApplication>
And it works perfectly on my Window 7 x64. This is the reason why i suspect an issue with WS 2008 R2.
I'll contact my server admin to enable crash logging.
Ok, good to know. The crash log might be revealing. I'll also try and get a 2008 vm image and try it out. You're publishing this as a straight forward .air file and installing the latest AIR runtime, right?
Chris
I just install a new WS 2008 R2 in a VM and it's works.
So it seems to not be an issue with 2008 R2 but a server configuration probleme.
I'm know waiting for my server admin and the crashlog.
Last AIR runtime yes.
I have a number of AIR-based applications installed on my windows 2008 R2 x64 desktop. One of them (snackr) is fine. The other two (Socialtext desktop and Chatter desktop) both crash at startup with a similar error to that reproduced above. These applications both worked fine for a while, but have been crashing regularly for a while. It might be down to a windows update, or possibly an update to the ARI runtime. Given that Snackr doesn't exhibit the problem there's obviously something that both these other apps are doing that's causing the problem....
Stephen
Problem signature:
Application Name: Chatter Desktop.exe
Application Timestamp: 4fc84269
Exception Code: e06d7363
OS Version: 6.1.7600.2.0.0.274.10
Locale ID: 2057
Additional Information 1: ae2c
Additional Information 2: ae2caaa5c408580c7d04cd5fa3bdc86d
Additional Information 3: 94ef
Additional Information 4: 94ef4e45067a5bf6893e4b026a3e4238
Read our privacy statement online:
and
Problem signature:
Application Name: Socialtext Desktop.exe
Application Timestamp: 4e039b26
Locale ID: 2057
@SPConnolly - did this just start occurring with AIR 3.4? If so, do both of these applications use encrypted local store?
I've got two folders in the folowing location, so I presume the answer is yes
C:\Users\stephen_connolly.GPK\AppData\Roaming\Adobe\AIR\ELS\SocialtextDesktop.F9CDE29572F658B1290DD6C1043E9E4D9571903B.1
and
C:\Users\stephen_connolly.GPK\AppData\Roaming\Adobe\AIR\ELS\sfdc-desktop.0E7F0072024938CDBA99B20C38B5F315254C2A5B.1
The apps should just be font ends to web services, so other than login credentials there shouldn't be anything important in there I need to keep. I renamed the folders and tried restarting but I still get the application crashes for socialtext.Chatter Desktop now appears to be working again. Thanks!
Ok, please see this post for more details on the ELS failure with 3.4: http://forums.adobe.com/message/4656135#4656135
I'm surprised that Chatter Desktop started working, do you think this was due to deleting the folder or something else?
I think it must have been - nothing else has changed AFAICT. However the SocialText desktop is still reporting a failure, albeit a slightly different one.
Fault Module Name: StackHash_9b28
Fault Module Version: 6.1.7600.16915
Fault Module Timestamp: 4ec49d10
Exception Code: c0000374
Exception Offset: 000ce903
Locale ID: 2057
Additional Information 1: 9b28
Additional Information 2: 9b280f2afd112539ddd3361067db5a81
Additional Information 3: de63
Additional Information 4: de6308265ce9f403cbe9bd31f1d7207a
The StackHash_xxx refers to issues with DEP, which I am not keen on switching off.
Could you please open a new bug report on the SocialText crash over at bugbase.adobe.com? Please post back with the URL so that others affected can add their comments and votes. I'll also follow up internally. We're expecting a new AIR beta release shortly, so we'll want to test against that too.
Done. Created Bug 3336429
Thank you
