3 Replies Latest reply on Feb 15, 2012 9:35 PM by Mylenium
    Rotating and Animating an Object
    rattisforever
      I'm trying to animate an object so that it rotates counterclockwise up to a certain point but the falls back down to the original postion. Can anybody explain to me how to do this? I've tried using keyframes, but they do not seem to work. Thanks!
        • 1. Re: Rotating and Animating an Object
          They do. People use them all the time and I'm 100% positive they are working in your case as well. You're probably just missing something very basic. Anyway, without seeing a screenshot of your timeline/ graph editor and comp probably nobody will be able to help you, so create some and attach them using the camera icon in teh post editor.
          Mylenium
          • 2. Re: Rotating and Animating an Object
            rattisforever Level 1
            Everytime I move a few frames forward and rotate the car, a key frame is not added. When I play back the video, the car stays in the same position where I left off. Could you also explain why the car does not have a solid look to it? It looks a bit ghostly.
            Where would I find the graph editor? I'm really new to After Effects.
            • 3. Re: Rotating and Animating an Object
              Well, not meaning to be rude, but have you considered simply reading the help? Seriously, start here. Your screenshot doesn't show any rotation property, so you're not keyframing it. It seems you are just moving a mask around and for that to have any effect, naturally you will have to animate the mask path property.
              Mylenium
