2 Replies Latest reply on Feb 20, 2012 10:41 PM by Flex harUI
    Trouble with popup not initialized until addPopUp is called
    Jay_Ds
      I am having troubles with initialization.  I have a class given below.  I new() it at the start and use PopUpManager.addPopUp to display it.
      My problem is that the line query:QueryWIthOption id="filterComp" is a class with a lot of variables.  However, if I try to set any of them before I call addPopUp, it doesn't work because filterComp is null.
      I therefore either need to initialize filterComp earlier, store the data until AddToPopup is called, or change the way I am implementing this.  If I store the data in variables, I have to add a whole bunch either to the class below or to the calling class.
      Doing this once is managable, but I have other similar examples with a similar problem. This code was flex 3 before where filterComp was always initialized.
      Is there any good way to do this?  I guess I am interested in both the way to do this in a minimal way, and what is the best way to code to avoid this issue (if I am adding something new in the future).
      Jay
      QueryWithOptionWrapper class:
      <mx:TitleWindow xmlns:fx="http://ns.adobe.com/mxml/2009"
                      xmlns:mx="library://ns.adobe.com/flex/mx"
                      xmlns:query="com.niksun.dashboard.components.query.*">
          <fx:Script>
              <![CDATA[
                  import com.niksun.common.managers.ResourceManager;
          </fx:Script>
          <mx:VBox horizontalAlign="center" width="100%" height="100%" paddingTop="5">
              <query:QueryWithOption id="filterComp" showFilter="true"/>
              <mx:HBox width="100%" horizontalAlign="center" horizontalGap="10">
                  <!-- enabled="{!ModelLocator.getInstance().progress}" -->
                  <mx:Button id="update" label="{ResourceManager.getString('Update')}"
                             horizontalCenter="0"/>
                  <mx:Button id="reset" label="{ResourceManager.getString('Reset')}"/>
                  <mx:Button id="cancel" label="{ResourceManager.getString('Cancel')}"/>
              </mx:HBox>
          </mx:VBox>
      </mx:TitleWindow>
