8 Replies Latest reply on Apr 12, 2013 9:18 AM by mlabriola
    proceedOnEvent() timeout waiting for creationComplete
    jeff@toll Level 1
      Hello,
      I have a test case that will not run due to proceedOnEvent not seeing the desired event.  Here's the test code:
      package com.mine.components.buttonBar
                import flexunit.framework.Assert;
                import mx.collections.ArrayList;
                import mx.core.FlexGlobals;
                import mx.events.FlexEvent;
                import org.flexunit.async.Async;
                import org.fluint.uiImpersonation.UIImpersonator;
                import org.hamcrest.assertThat;
                import org.hamcrest.collection.hasItems;
                import org.hamcrest.object.equalTo;
                import org.hamcrest.object.notNullValue;
                public class ButtonBarTest
                          private var buttonBar: ButtonBar;
                          private var buttonData: Array = [{label: "one"  },{label: "two"},{label: "three"},{label: "four"},{label: "five"}];
                          [Before(async, ui)]
                          public function setUp():void
                                    buttonBar = new ButtonBar();
                                    buttonBar.dataProvider = new ArrayList( buttonData );
                                    Async.proceedOnEvent( this, buttonBar, FlexEvent.CREATION_COMPLETE, 3000 );
                                    UIImpersonator.addChild( buttonBar );
                          [After(async,ui)]
                          public function tearDown():void
                                    UIImpersonator.removeChild( buttonBar );
                                    buttonBar.dataProvider = null;
                                    buttonBar = null;
                          [BeforeClass]
                          public static function setUpBeforeClass():void
                          [AfterClass]
                          public static function tearDownAfterClass():void
                          [Test(async, ui)]
                          public function testGet_selectedIndices():void
                                    assertThat( buttonBar, notNullValue() );
                                    var selectedIndices: Vector.<int> = buttonBar.selectedIndices;
                                    assertThat( selectedIndices, notNullValue() );
                                    assertThat( selectedIndices, equalTo( 0 ) );
                                    buttonBar.selectedIndices = new Vector.<int>( 0, 2, 4 );
                                    assertThat( buttonBar.selectedIndices, hasItems( 0, 2, 4 ) );
      I can run the test within flashbuilder or from ant using a test runner and I get the same result.
      The button bar component is derived from spark.components.SkinnableDataContainer and has its own skin.  Buttons are added to a DataGroup, one button for each dataProvider element.  The buttons and data group are added by the skin classes associated with the button bar.
      I am using flexunit-4.1.0-8-4.1.016076.
      I'd really appreciate some help in getting this test case to work correctly.
      Jeff
