0 Replies Latest reply on Feb 16, 2012 1:39 AM by V.Dnath
    INdesign Cs4 applescript
    V.Dnath
      hellow scripters
      i want to do untag all the 'emphasis' tags where they used .. i ran script as below but its delete all the content of all xml tags but i wnt to untag only "Emphasis" tag in xml structer..
      plz anybody help me...
      withregrds
      vbs007
      tell application "Adobe InDesign CS4"
          tell active document
              set theRoot to (item 1 of XML elements) -- the root element
              set theElements to every XML element of theRoot
              repeat with x in theElements
                  if (name of markup tag of x is not "aPNBox") and (name of markup tag of x is not "idline") and (name of markup tag of x is not "tagline") then tell x to untag
                  try
                      set x to every XML element
                      if (name of markup tag of x is equal to "emphasis") then set theSubElements to every XML element of x
                      repeat with y in theSubElements
                          if (name of markup tag of y is not equal to "emphasis") then untag x
                      end repeat
                  end try
              end repeat
          end tell
      end tell
          tell document 1
              delete unused tags
          end tell
      end tell
