3 Replies Latest reply on Feb 16, 2012 9:35 AM by JJMack
    Pen Path saving
    Esttillio Level 1
      Hi, just for example when im using Laso tool i can save my selection and when i will need again just go to the channels and select it. How i could save my pen path?
        • 1. Re: Pen Path saving
          Zeno Bokor Level 6
          Go to the Paths panel and double click on your path (it should be named Work Path) or drag it to the New Path button at the bottom of the Paths panel or select Save Path from the Paths panel menu.
          • 2. Re: Pen Path saving
            Esttillio Level 1
            Thanks for help, but when im creating another path and trying to fill with different colour it fills and my first path
            • 3. Re: Pen Path saving
              Make sure your creating a new Path. Have the Path palette visible and click on the new path icon the current path should then not be visible. Otherwise if you creat a new path it is likely to be added to the current path. Also look atr the state of the right set of icons in the options bar. The control the wat paths are added to the current path.
