• Global community
    • Language:
      • Deutsch
      • English
      • Español
      • Français
      • Português
  • 日本語コミュニティ
  • 한국 커뮤니티
Exit
0
Twistie image won't display
Guest
Feb 16, 2012 Feb 16, 2012
RH 9 / WebHelp output
I added twisties to my project a couple of weeks ago and they worked fine.
Recently I re-organized my images and the twistie graphics were not displaying so I went into the css and updated the path.
The collpage icon displays fine, but the expand will not. I even tried using the collapse icon for the open icon and it still won't display. I put the images back at the root and re-did path, and nothing changed.
Attached pictures of the 2 outputs, and the code.
Have a release going out tomorrow so any help much appreciated.
Views
905
Translate
Translate
Report
Report
Community guidelines
community guidelines
Guest
here's the css
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi there
Perhaps try using the file browsing icon (folder) and re-select the image?
Just thinking out loud.
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7, 8 or 9 within the day!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
Votes
Translate
Translate
Report
Report
Guest
I've done that a couple of times to no avail.
Votes
Translate
Translate
Report
Report
LEGEND ,
Hello again
I think the next approach I would suggest would be to choose a different pair of images. See if things correct then. And if so, re-select the desired images.
If that fails, you need to examine the CSS at the code level. I know you probably think you have posted that, but what I mean is to open the CSS file in Windows Notepad and note what is shown there.
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
Votes
Translate
Translate
Report
Report
Guest
I re-directed them both to a new file. Collapse works, Expand doesn't.
Here's the css for the hotspot.
Votes
Translate
Translate
Report
Report
LEGEND ,
Hi there
For starters, the CSS seems that you are referencing the same exact file. So your Expand and Collapse should be identical. But in your screen capture, it appears that the collapse isn't showing?
If you are really wanting the same image, perhaps make a copy and name the copy slightly differently. Then specify it in the CSS editor or code.
Another thing to try is to right-click and add both images to your project as Baggage files.
Cheers... Rick
SorcerStone Blog
RoboHelp eBooks
Votes
Translate
Translate
Report
Report
Guest
LATEST
I thought of deleting the images and starting over but you can't select "no image" from in RH.
Should i try just deleting those two lines for the images from the css, and then re-doing them in RH ?
Votes
Translate
Translate
Report
Report
Resources
RoboHelp Documentation
Download Adobe RoboHelp
