4 Replies Latest reply on Feb 18, 2012 8:42 AM by DonMitchinson
    Load a local file
    JW1015
      I have searched every site and blog to try to find a method that actually works without success.
      I want to load a pdf from the application directory on an android, the method works fine debugging on a desktop
      but locks up on an actual device.
      I have a Motorola Xoom with Honeycombe 3.
      In my project I use a local sql database and can access that fine on the Xoom.
      public function listGroups(brand:String):Array
                  var sqlConnection:SQLConnection;
                  sqlConnection = new SQLConnection();
                  sqlConnection.open(File.applicationDirectory.resolvePath("manuals.db" ));
                  var stmt:SQLStatement = new SQLStatement();
                  stmt.sqlConnection = sqlConnection;
                  stmt.text =
                      "SELECT * FROM keywords  " +
                      "WHERE brand = '" + brand + "' " ;
                  stmt.execute();
                  var result:Array = stmt.getResult().data;
                  return result;
      But I cannot get a working path for the pdf to open in a StagewebView using either one of the path var I have.
      <fx:Script>
              <![CDATA[
                  import mx.events.FlexEvent;
                  private var stageWebView:StageWebView;
                  // will load a pdf or swf file from local storage
                  public var path:String = new File(new File("app:/Alpha.pdf").nativePath).url;
                  public var manualFile:String = new File(File.applicationDirectory.resolvePath("Alpha.pdf").nativePath).url;
               protected function applicationCompleteHandler(event:FlexEvent): void
                      if(StageWebView.isSupported== true){
                          stageWebView = new StageWebView();
                          stageWebView.viewPort = new Rectangle(5,100,stage.width-10,stage.height-90);
                          stageWebView.stage = this.stage;
                          stageWebView.addEventListener(LocationChangeEvent.LOCATION_CHANGE,
                              locationChangedHandler);
                          stageWebView.loadURL(manualFile);
                      } else {
                          urlAddress.text = "StageWebView not supported" ;
      I am beginning to think it impossible, has anyone achieved to do this, maybe another android device.
      Any thoughts would be great, a solution even better.
