8 Replies Latest reply on Feb 22, 2012 11:47 PM by Rohit . Kumar
    ADEP Data Services JEE 4.6 related Issue.
    buntyk
      Hello,
      I tried to use build simple application in Flash Builder 4.6 with data model i.e. model driven development. I tried to follow the example of lcds data services but doesn't work for me.
      I am able to generate the tables and able to generate form and display data in the datagrid without writing single line of code.
      But when I try to insert data I get errror. And I am not able to go ahead since last few days.
      Please help me.
      Even if somebody can give me some detailed example for this...that would be helpful.
      Thanks alot,
        • 1. Re: ADEP Data Services JEE 4.6 related Issue.
          Rohit . Kumar Adobe Employee
          Hi Buntyk,
          What error are you getting? As for the link: Check out the ADEP Data Services 4.6 documentation at: http://help.adobe.com/en_US/dataservicesjee/4.6/Modeling/index.html. Specificically refer to the various Model Driven Development sections.
          Hope that helps,
          Rohit
          • 2. Re: ADEP Data Services JEE 4.6 related Issue.
            buntyk Level 1
            Hello Rohit,
            I read the link you have sent.
            And I have gone through that again. But still I am getting some kind of
            error...
            "Error occurred completing a transaction
            null"
            I have mac and FB 4.6 installed on it. with Modeler plugin for 4.6 is also
            installed.
            I have installed ADEP Data Services JEE 4.6.
            I have created tried to create the sample app MyDSApp using the
            instructions in the link povided by you,
            Developing Data Services forJava EE 4.6 Model-Driven Applications
            There only thing I did change is I didn't have flex 4.5 sdk installed so I
            used the default 4.6....rather than that everything is the same.
            After I finished the app using the instructions I run it. It showed me the
            product table's all the data.But when I tried to edit a cell in the
            datagrid....I got message
            *"Error occurred completing a transaction *
            null"
            So only thing is while updating I am getting error...
            Please Let me know what is wrong.
            Thank you,
            • 3. Re: ADEP Data Services JEE 4.6 related Issue.
              buntyk Level 1
              More over..
              this is I found in the tomcat server log....
              Data Services] Error notifying transaction before completion
              handlers: org.hibernate.TransactionException: JDBC commit failed
              at
              org.hibernate.transaction.JDBCTransaction.commit(JDBCTransaction.java:157)
              at
              flex.data.adapters.FlexHibernateSessionContext$SessionSynch.beforeCompletion(FlexHibernate SessionContext.java:139)
              at
              flex.data.DataServiceTransaction.notifyBeforeCompletion(DataServiceTransaction.java:2069)
              at
              flex.data.DataServiceTransaction.complete(DataServiceTransaction.java:1673)
              at flex.data.DataService.serviceTransactedMessage(DataService.java:1028)
              at flex.data.DataService.serviceMessage(DataService.java:528)
              at flex.messaging.AsyncMessageBroker.in(AsyncMessageBroker.java:414)
              at flex.messaging.MessageContext.doIn(MessageContext.java:295)
              at flex.messaging.filters.AsyncMessageFilterChain.in
              (AsyncMessageFilterChain.java:205)
              at
              flex.messaging.AsyncMessageBroker$EndpointSplitter.in(AsyncMessageBroker.java:809)
              at flex.messaging.endpoints.BaseSocketServerEndpoint.in
              (BaseSocketServerEndpoint.java:476)
              at
              flex.messaging.endpoints.RTMPConnection.handleTCCommandIn(RTMPConnection.java:886)
              at flex.messaging.endpoints.RTMPConnection.in(RTMPConnection.java:1032)
              at
              flex.messaging.endpoints.RTMPConnection.serviceTCMessage(RTMPConnection.java:1116)
              at flex.messaging.endpoints.RTMPConnection.doRead(RTMPConnection.java:654)
              at
              flex.messaging.endpoints.RTMPProtocolHandler.doRead(RTMPProtocolHandler.java:124)
              at
              flex.messaging.socketserver.Connection$ConnectionReader.run(Connection.java:874)
              at
              java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
              at
              java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
              at java.lang.Thread.run(Thread.java:680)
              Caused by: java.sql.SQLException: StandardXAConnectionHandle:commit:This
              connection is part of a global transaction
              at
              org.enhydra.jdbc.standard.StandardXAConnectionHandle.commit(StandardXAConnectionHandle.jav a:129)
              at
              org.hibernate.transaction.JDBCTransaction.commitAndResetAutoCommit(JDBCTransaction.java:16 6)
              at
              org.hibernate.transaction.JDBCTransaction.commit(JDBCTransaction.java:142)
              ... 22 more
              Error while completing transaction:
              flex.data.DataServiceException: Error occurred completing a transaction
              stacktrace=flex.data.DataServiceException: Error occurred completing a
              transaction
              at
              flex.data.DataServiceTransaction.complete(DataServiceTransaction.java:1689)
              at
              at
              at
              at
              at
              at
              at
              Caused by: org.hibernate.TransactionException: JDBC commit failed
              at
              at
              at
              at
              ... 19 more
              at
              at
              at
              ... 22 more
              Error invoking service 'data-service':
                incomingMessage: Flex Message (flex.data.messages.DataMessageExt)
                  operation = transacted
                  id = null
                  clientId = 46CC4646-66D2-ED16-9DF7-9612C59D36F8
                  correlationId =
                  destination = MyDSApp.Product
                  messageId = D97330F0-08FD-2866-FD1F-9612C82F2A21
                  timestamp = 1329662712754
                  timeToLive = 0
                  body =
                    Flex Message (flex.data.messages.DataMessage)
                        operation = update
                        id = ASObject(1206661731){productid=1}
                        correlationId = D97330F0-08FD-2866-FD1F-9612C82F2A21
                        messageId = B97F910A-239C-E7B5-A7B5-9612DBAEAD61
                        timestamp = 1329662712766
                        timeToLive = 0
                        body =
                            price
                          [Proxy(inst=MyDSApp.package1.Product@20) proxyClass=class
              flex.messaging.io.BeanProxy descriptor=[ excludes: null]],
                        hdr(DSId) = 64813F88-6D96-4801-8435-C65442DF79C8
                        hdr(DSEndpoint) = my-rtmp
                Exception: flex.data.DataServiceException: Error occurred completing a
              transaction
              at
              flex.data.DataServiceTransaction.complete(DataServiceTransaction.java:1722)
              at
              at
              at
              at
              at
              at
              at
              Caused by: flex.data.DataServiceException: Error occurred completing a
              transaction
              at
              ... 19 more
              at
              at
              at
              at
              ... 19 more
              at
              at
              at
              ... 22 more
              • 4. Re: ADEP Data Services JEE 4.6 related Issue.
                Ashish Vashisht
                Hi
                You need to set the following properties on your Fiber model, as appropriate for your app server:
                •   hibernate.transaction.factory_class
                •   hibernate.transaction.manager_lookup_class
                Please see here: http://help.adobe.com/en_US/enterpriseplatform/10.0/AEPDeveloperGuide/WSa53bf8bf8189e60776 c71f0d133f0350afe-8000.html
                Regards,
                Ashish Vashisht
                • 5. Re: ADEP Data Services JEE 4.6 related Issue.
                  buntyk Level 1
                  HI I checked but I am using Tomcat and on that page its written for JBOSS and also when I tried to put those values It gives error on model.
                  So probably not for Tomcat server.
                  What I created is just a basic app.
                  Here are the steps I did hundreds of times.
                  When I installed ADEP Data Services 4.6
                  It has built in tomcat server and sampledb
                  And on the link http://help.adobe.com/en_US/dataservicesjee/4.6/Modeling/WS4ba8596dc6a25eff-1bd28c95126af7 77a3e-8000.html  is
                  " Create a simple model-driven application ".
                  I tried those steps to create the app. All steps as stated in the above link.
                  When I run the app it displays records in the datagrid. But then when I try to update any cell it gives error. As I have posted in my earlier messages.
                  So I am just stuck at starting point and not able to go ahead and try out more....
                  Please help.
                  • 6. Re: ADEP Data Services JEE 4.6 related Issue.
                    Ashish Vashisht Level 1
                    Hi
                    As mentioned on the page, you need to provide values for those properties as per your respective App Server. The exact App Server specific values can be found in the Hibernate documentation (also linked to on the page): http://docs.jboss.org/hibernate/core/3.6/reference/en-US/html/session-configuration.html#c onfiguration-optional-transactionstrategy
                    Specifically for Tomcat, the below values should work:
                    <property name="hibernate.transaction.factory_class">org.hibernate.transaction.JTATransactionFactor y</property>
                    <property name="hibernate.transaction.manager_lookup_class">org.hibernate.transaction.JOTMTransacti onManagerLookup</property>
                    I will check to see that the sample documentation is updated to mention the same.
                    Ashish Vashisht
                    • 7. Re: ADEP Data Services JEE 4.6 related Issue.
                      buntyk Level 1
                      HI Ashish,
                      I am able to figureout the problem.
                      Actually In the model
                      <annotation name="DMS" Table="PRODUCT" hibernate.connection.url="jdbc:hsqldb:hsql://localhost:9002/ordersDB" hibernate.connection.driver_class="org.hsqldb.jdbcDriver"/>
                              <annotation name="RDS" introspectedColumns="PRODUCTID,DESCRIPTION,PRICE,PRODUCTNAME"/>
                              <annotation name="ActionScriptGeneration" DisplayColumn="productname" Package="valueObjects" ImplicitServicePackage="services"/>
                              <annotation name="service Group" service="Dummy,ProductService"/>
                              <annotation name="FbEntityProperties" AssemblerClass="fiber.data.assemblers.FiberAssembler" contextRoot="/dataservices-samples" rootUrl="http://localhost:8400/dataservices-samples"/>
                      After putting these properties it worked ok.
                      Also The DMS was defined at model level but still I have to define DMS at the entity level for these above annotations...
                      Thanks for your help.
                      • 8. Re: ADEP Data Services JEE 4.6 related Issue.
                        FYI, these properties get added when you actually introspect the entity and place it on the Model canvas.
                        Rohit
