1 Reply Latest reply on Apr 19, 2008 9:49 PM by kglad
    Trying to reload data using setInterval
      Can someone tell me why the attached code will run & refresh as fast as it can for like 5-10 seconds, and then quit all together. All I'm trying to do is reload the data. Can someone tell me what I'm doing wrong?
        • 1. Re: Trying to reload data using setInterval
          1. the function in your setInterval should not have parenthesis.
          2. you should not be passing a variable to reloadPHP() because it accepts none.
          3. sendAndLoad() is a loadvars method and you have no loadvars instance.
          4. you should use a loadvars instance with an onLoad or onData handler to receive your data and to restart your interval for the next php call.
