5 Replies Latest reply on Feb 19, 2012 9:27 PM by mac152207
    Make.New.Folder [JS] (mac1522 is old) my new id (mac152207)
    mac152207
      Hello Sir, (Bob Levine, Peter Spler, Jongware)
      I am really sorry about this. I am forgotten my password so i am using new id.
      My question Make new folder other System it is not part of (by) indesign. Its is part of automation. I have all system (IP, Users name, password). Sir my job is create proper folder structure one by one my colleague system. So i want need your help.
      My old query =>
      Hi all,
      How i can new folder on other system by ip. My system ip like this 20.20.20.84 but i want make new folder this ip 20.20.20.86. You have any Java/Apple script for this.
      my both mac connf. Mac OS X 10.6.8
      thank you so much
      Regard ~Mac1522~
      Thank you so much
      Regard. mac152207
        • 1. Re: Make.New.Folder [JS] (mac1522 is old) my new id (mac152207)
          Replace "My Folder" with the new folder name and replace Volume:Users:userfolder:Desktop with the path to the destination folder:
          tell application "Finder"
              set fName to "My Folder"
              set fDest to folder "Volume:Users:userfolder:Desktop" as alias
              if (folder fName of folder fDest exists) is false then
                  set newFolder to make new folder at fDest with properties {name:fName}
              end if
          end tell
          • 2. Re: Make.New.Folder [JS] (mac1522 is old) my new id (mac152207)
            Also if the destination volume is not on the host computer you'll need to mount it before making the new folder, something like this:
                activate
                try
                    mount volume "VolumeName" on server "20.20.20.86" as user name "user" with password "pass"
                on error
                    display dialog "VolumeName is not Online"
                end try
            end tell
            Replace VolumeName, user, pass with the serving computer's specs
            • 3. Re: Make.New.Folder [JS] (mac1522 is old) my new id (mac152207)
              mac1522
              Hi Rob day,
              Thank you so much for greet answering you second apply code run great (connect other system). But sir first apple code make new folder other system i am not understand actually i am new for apple script. I am attached screen shoot i need you help again.
              you code=>
              try
                mount volume "AP0015" on server "20.20.20.74" as user name "AP0015" with password "abc"
                        end try
              my question is that make new folder other system (AP0015). Sir i want this folder structure other system (AP0015)
              I am really sorry for click "Correct Answers" i could not find this option
              regard thanks once again
              mac152207
              • 4. Re: Make.New.Folder [JS] (mac1522 is old) my new id (mac152207)
                To make a new folder you need to provide a colon delimited string as an alias with a name property something like:
                make new folder at alias "AP0015:Produce:Fruit" with properties {name:"Apples"}
                which would make a folder named Apples inside a folder named Fruit inside a folder named Produce on AP0015
                Here's a commented script which should work:
                  --set a time out in case the server is not available
                          with timeout of 20 seconds
                                    try
                                    on error
                                              display dialog "AP0015 is not Online"
                                    end try
                          end timeout
                  --the path to the folder where the new folders will be created
                  --in this case it's the root of the AP0015 server
                  --the path to the destop would be "AP0015:Users:AP0015:Desktop:"
                  --don't forget the colon at the end of the string
                          set baseFolder to "AP0015:"
                  --the name of the new container folder
                          set bfName to "New Jobs"
                  --a list of the sub folders to create
                          set subfolders to {"Art", "Font", "MSP", "Sample", "Version_01", "Xml"}
                  --make the container folder if one doesn't already exist
                          try
                  make new folder at alias baseFolder with properties {name:bfName}
                          on error
                                    display dialog "A Folder at " & baseFolder & " named " & bfName & " Already Exists"
                          end try
                  --loop through the sub folder list and make the subfolders
                          repeat with i from 1 to number of items in subfolders
                                    set subname to item i of subfolders
                  make new folder at alias (baseFolder & bfName) with properties {name:subname}
                          end repeat
                end tell
                • 5. Re: Make.New.Folder [JS] (mac1522 is old) my new id (mac152207)
                  mac152207 Level 1
                  Hi rob day sir,
                  Thank you so much your apple script code simple great thank you sooooo much once again.
                  ~Regard~
                  mac
