2 Replies Latest reply on Feb 18, 2012 5:36 PM by pwillener
    Adobe Flash Player Distribution contains wrong version 11.1.102.62
    MbdaLogicielsBureautiques Level 1
      Hello,
      I'm trying to download (from the Flash Player Distribution page http://www.adobe.com/products/flashplayer/distribution3.html ) Flash Player 11.1.102.62 (32 bits) for Windows, in order to install it in our Company using SCCM.
      But the file I get is not the correct one... it seems to be an older one, not the 11.1.102.62 (even if I click on the line "Flash Player 11.1.102.62 (32 bit) for Windows").
      So, it seems the webmaster may have made some misstake.
      Thanks to correct it
        • 1. Re: Adobe Flash Player Distribution contains wrong version 11.1.102.62
          pwillener Level 8
          I just downloaded all four 32-bit installers for Windows; see details below.
          NameSizeFile Version
          Timestamp
          install_flash_player_11_active_x_32bit.exe3.62 MB (3,803,296 bytes)11.1.102.622012-02-14 12:41:53
          install_flash_player_11_active_x_32bit.msi4.64 MB (4,867,072 bytes)2012-02-14 12:41:26
          install_flash_player_11_plugin_32bit.exe3.59 MB (3,765,920 bytes)11.1.102.622012-02-14 12:44:45
          install_flash_player_11_plugin_32bit.msi4.60 MB (4,828,672 bytes)2012-02-14 12:44.14
          If you get different versions, then you may have an old version cached somewhere.
          • 2. Re: Adobe Flash Player Distribution contains wrong version 11.1.102.62
            pwillener Level 8
            And here are the details for the 64-bit installers:
            Timestamp
            install_flash_player_11_active_x_64bit.exe7.83 MB (8,211,104 bytes)11.1.102.622012-02-14 11:00:37
            install_flash_player_11_active_x_64bit.msi8.97 MB (9,406,464 bytes)
            2012-02-14 12:49:40
            install_flash_player_11_plugin_64bit.exe7.74 MB (8,124,064 bytes)11.1.102.622012-02-14 10:43:05
            install_flash_player_11_plugin_64bit.msi8.88 MB (9,318,400 bytes)
            2012-02-14 12:51:21
