3 Replies Latest reply on Apr 19, 2008 1:50 PM by heathrowe
    Create Slideshow
    locopop
      I am trying to creat a slideshow in Fireworks CS3 for the first time. I have selected 22 images, given them captions, gone through all the side panels and when I hit create it says "no images were processed."
      Can anyone suggest what I might be doing wrong?
        • 1. Re: Create Slideshow
          heathrowe Most Valuable Participant
          Which Player?
          What file types are you trying to process?
          Also for which ever Player you are using, in the Album Book Properties tab, click the I icon command to the right of the Player drop down list for details on what is acceptable/not acceptable for that particular Player. Not all tab options are necessary for a given Player.
          h
          • 2. Re: Create Slideshow
            locopop Level 1
            the images are optimized jpegs. Itried a couple different players - Dreamworld - green (Flash) and Sliver-silver (flash)
            • 3. Re: Create Slideshow
              Ok - One thing to verify is the optimized jpgs. If I remember correctly, Flash does not handle 'Progressive' jpg's well.
              If you created the outputed jpgs from Photoshop for example, make sure 'Progressive' is deselected. If from FireWorks, turn off 'Progressive Browser Display'.
              If the above was the case, just try it on a few images, rebuild the slideshow, to confirm.
              h
