23 Replies Latest reply on Jul 14, 2013 9:34 PM by Noel Carboni
    Photoshop CS5 (under Windows 7) crashes when I try to print
    Alastair Mac
      I am running 64-bit Photoshop CS5 Extended upgraded to current version (12.0.4).
      When I try to print, every single time, I get the following error immediately:
           > Adobe Photoshop CS5 has stopped working
                Windows is checking for a solution to the problem
      and then shortly after
                A problem caused the program to stop working correctly.
                Windows will close the program and notify you if a solution is available.
      Quite infuriating. My printer works fine. I can print photos to it from Lightroom no problem (which, in this occasion, I had to do - saved from PS, imported to LR, then printed... very efficient!!).
      I note there are other posts on this but they seem to be mostly Mac and also many seem to cure by upgrading to 12.0.4.
      I am a relatively light user (keen amateur not professional) so I don't use PS regularly. However this also means it is pretty much an out-of-the-box install since I don't tinker with it either. It's so long since I last used it I can't remember if I had this problem last time - I vaguely recall having had it sometimes but not others. Doesn't seem to matter whether the file I opened is a JPG or a PSD (the only two I have tried).
      Any help out there?
      Alastair
