1. Re: edit .mts / H.264 file in premier pro and preserve time of recording (typical timedateoriginal meta)
JSS1138 Feb 17, 2012 10:48 AM (in response to cykehjul3)I don't think this will be possible. Once you bring the clips into PP and export, you're generating entirely new video, with new metadata.
2. Re: edit .mts / H.264 file in premier pro and preserve time of recording (typical timedateoriginal meta)
cykehjul3 Feb 17, 2012 11:42 AM (in response to JSS1138)Well...it is possible with DV formats.
In Premier pro I import DV, edit and export DV and the timecodes are preserved!
I can even generate a new DV file with the source from different DV files, and i STILL have correct date and time of recording thoughout the new DV !!
Even to the extend that if i cut in a scene, it preserves the running time code.
Example; a scene in the DV file starts at 8:30 o'clock and last 4 mins. If I cut a minute out after 1 minutes and export the whole DV as DV, my subtitle generator wil provide a subtitle for 8.30 and one for 8.32.
In Encore it then shows both the 8.30 and 8.32 time of recording perfectly.
I would even be happy if with .mts i could get just 8.30 for both clips from the same scene (.mts file)..
But not even that seems possible as you say.
That is why i was so disapointed when i moved from DV to AVCHD camcorder.
But if this is not possible, what IS possibel ..?
Clearly what i want to achieve makes sense..?
I want to be able to switch on subtitle to see at what time/date a scene was recorded, nothing more.
thx
Per
3. Re: edit .mts / H.264 file in premier pro and preserve time of recording (typical timedateoriginal meta)
JSS1138 Feb 17, 2012 10:01 PM (in response to cykehjul3)Well...it is possible with DV formats.
Yep. But not with HD.
Honestly, not really. Premiere Pro is a professional level editor, and the only scenario I can think of where someone would want this is the home video maker, for which there are many consumer programs out there. I can't guarantee one of them will do what you want, either. And that's probably the fault of the camera makers more than anything, who've really muffed up this whole HD business when it comes to codecs and file structure.
4. Re: edit .mts / H.264 file in premier pro and preserve time of recording (typical timedateoriginal meta)
cykehjul3 Feb 19, 2012 6:44 AM (in response to JSS1138)So..for anyone who has the same problem and find this thread, here are my 2pence.
I want to make a home move of our last 5 skiing vacations. I want a subtitle track containing the time of recording information.
I do not want a title overlay on the video, but when the discussion about 'when was that--!?' comes up, i want to be able to turn on subtitle. Simple !
I moved from DV to AVCHD (not because of HD Jim, but the DV camcorder was old, and newer seemed better at the time)
Hence my new problem: I have a bunch of .mts files, i need to edit those in a timeline editor, and get a subtitle track with the recording time.
recording time is in the -mts video meta data called timedateoriginal. To some extend also file attribute date of change (=time of writing to the SD card).
As it seems difficult to keep the meta data once you passed a timeline editor, and the file attribute does not make sense when you put a bunch of .mts files together, I think the best way forward is to find a timeline editor which also has subtitle tracks.
i.e. after steps 1) and 2) in my i have a single file and a .srt subtitle file to match.
I can now use those in a timeline editor.
Hunt is out for which editor, but it seems there are a couple of options. To be tested.
Once the sequence is edited, the new version of the subtitle needed to be exported so that it can be imported into adobe encore together with the final sequence for DVD/blu-ray authoring.
If anyone find a better way,, please let me know.
thanks...
