2 Replies Latest reply on Aug 14, 2014 10:42 AM by AmyBD
    How to upload an image in a directory using PHP code generated by Dreamweaver?
    skhaan82 Level 1
      I have created a dynamic website with Dreamweaver and PHP, i have also created a insertform page using dreamweaver's 'Record Insertion Form Wizard' i have a field named prod_img in my MySQL database and on my form but this is a text field and i have to enter the path of the image directory to display it but this needs to have the image in the directory, i want to add a browse file field so that the image uploads to the directory by PHP.
      My code is as follows:
      <?php require_once('../Connections/dwtltd.php'); ?>
      <?php
      if (!function_exists("GetSQLValueString")) {
      function GetSQLValueString($theValue, $theType, $theDefinedValue = "", $theNotDefinedValue = "")
        if (PHP_VERSION < 6) {
          $theValue = get_magic_quotes_gpc() ? stripslashes($theValue) : $theValue;
        $theValue = function_exists("mysql_real_escape_string") ? mysql_real_escape_string($theValue) : mysql_escape_string($theValue);
        switch ($theType) {
          case "text":
            $theValue = ($theValue != "") ? "'" . $theValue . "'" : "NULL";
            break;
          case "long":
          case "int":
            $theValue = ($theValue != "") ? intval($theValue) : "NULL";
            break;
          case "double":
            $theValue = ($theValue != "") ? doubleval($theValue) : "NULL";
            break;
          case "date":
            break;
          case "defined":
            $theValue = ($theValue != "") ? $theDefinedValue : $theNotDefinedValue;
            break;
        return $theValue;
      $editFormAction = $_SERVER['PHP_SELF'];
      if (isset($_SERVER['QUERY_STRING'])) {
        $editFormAction .= "?" . htmlentities($_SERVER['QUERY_STRING']);
      if ((isset($_POST["MM_insert"])) && ($_POST["MM_insert"] == "form1")) {
        $insertSQL = sprintf("INSERT INTO special_offers (spec_img, spec_head, spec_desc, spec_call, spec_price, spec_rtn) VALUES (%s, %s, %s, %s, %s, %s)",
                             GetSQLValueString($_POST['spec_img'], "text"),
                             GetSQLValueString($_POST['spec_head'], "text"),
                             GetSQLValueString($_POST['spec_desc'], "text"),
                             GetSQLValueString($_POST['spec_call'], "text"),
                             GetSQLValueString($_POST['spec_price'], "text"),
                             GetSQLValueString($_POST['spec_rtn'], "text"));
        mysql_select_db($database_dwtltd, $dwtltd);
        $Result1 = mysql_query($insertSQL, $dwtltd) or die(mysql_error());
        $insertGoTo = "../specialoffers.php";
          $insertGoTo .= (strpos($insertGoTo, '?')) ? "&" : "?";
          $insertGoTo .= $_SERVER['QUERY_STRING'];
        header(sprintf("Location: %s", $insertGoTo));
      $query_insertRS = "SELECT * FROM special_offers ORDER BY spec_id ASC";
      $insertRS = mysql_query($query_insertRS, $dwtltd) or die(mysql_error());
      $row_insertRS = mysql_fetch_assoc($insertRS);
      $totalRows_insertRS = mysql_num_rows($insertRS);
      <form action="<?php echo $editFormAction; ?>" method="post" name="form1" id="form1">
        <table align="center" cellpadding="5">
          <tr valign="baseline">
            <td align="right" nowrap="nowrap">Add Image:</td>
            <td><span id="sprytextfield1">
            <input type="text" name="spec_img" value="" size="32" />
            <span class="textfieldRequiredMsg">A value is required.</span></span></td>
          </tr>
            <td nowrap="nowrap" align="right">Offer Heading:</td>
            <td><input type="text" name="spec_head" value="" size="32" /></td>
          </tr>
            <td nowrap="nowrap" align="right">Offer Description:</td>
            <td><input type="text" name="spec_desc" value="" size="32" /></td>
          </tr>
            <td nowrap="nowrap" align="right">Phone:</td>
            <td><input type="text" name="spec_call" value="" size="32" /></td>
          </tr>
            <td nowrap="nowrap" align="right">Price:</td>
            <td><input type="text" name="spec_price" value="" size="32" /></td>
          </tr>
            <td nowrap="nowrap" align="right">RTN:</td>
            <td><input type="text" name="spec_rtn" value="" size="32" /></td>
          </tr>
            <td nowrap="nowrap" align="right"> </td>
            <td><input type="submit" value="Insert record" /></td>
          </tr>
        </table>
        <input type="hidden" name="MM_insert" value="form1" />
      </form>
      Help greatly appreciated.
      I have googled, yahooed, binged etc etc and tried many tutorials but nothing goes in my favor please do not suggest to search on search engines or websites.
