6 Replies Latest reply on Feb 18, 2012 7:53 AM by BKBK
    CFHTTP Connection Failure
    Stormpool
      I've been struggling with reading a 3rd party product feed.
      I'm using the following code
      <cfhttp url="http://webservices....">
      <cfhttpparam type="header" name="accept-encoding" value="deflate;q=0">
      <cfhttpparam type="header" name="te" value="deflate;q=0">
      </cfhttp>
      <cfdump var="#cfhttp#">
      It returns with
      struct
      Charsetutf-8
      ErrorDetail[empty string]
      FilecontentConnection Failure
      HeaderHTTP/1.1 200 OK Content-Type: text/xml; charset=utf-8 Date: Sat, 18 Feb 2012 13:42:00 GMT Cache-Control: private, max-age=0 X-AspNet-Version: 4.0.30319 Server: Microsoft-IIS/7.0 X-Powered-By: ASP.NET
      Mimetypetext/xml
      Responseheader
      struct
      Cache-Controlprivate, max-age=0
      Content-Typetext/xml; charset=utf-8
      DateSat, 18 Feb 2012 13:42:00 GMT
      ExplanationOK
      Http_VersionHTTP/1.1
      ServerMicrosoft-IIS/7.0
      Status_Code200
      X-AspNet-Version4.0.30319
      X-Powered-ByASP.NET
      Statuscode200 OK
      TextYES
      If use Firefox Live Headers plugin and view the feed in the browser, it displays fine and also the plugin gives me the information
      GET /services/products.asmx...... HTTP/1.1
      Host: webservices.......
      User-Agent: Mozilla/5.0 (Windows NT 6.1; WOW64; rv:10.0.1) Gecko/20100101 Firefox/10.0.1
      Accept: text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
      Accept-Language: en-gb,en;q=0.5
      Accept-Encoding: gzip, deflate
      Connection: keep-alive
      Cache-Control: max-age=0
      HTTP/1.1 200 OK
      Content-Encoding: deflate
      Date: Sat, 18 Feb 2012 13:34:09 GMT
      Content-Length: 9225
      I've googled and tried variation of accept-encoding to no avail, I just get connection failure.
      Any ideas? Thanks
      p.s. also tried
      <cfhttpparam type="header" name="accept-encoding" value="no-compression"/>
        • 1. Re: CFHTTP Connection Failure
          Owain North Level 4
          Have you tried with no headers at all? Can you browse the webservice from the ColdFusion server?  It seems a little odd that it's getting a 200 but giving you back "Connection Failure" - that would imply it's something in their software that's throwing that message rather than the HTTP transaction.
          Is there any documentation that says what you need to send?
          • 2. Re: CFHTTP Connection Failure
            Stormpool Level 1
            Tried without httpheaders, the same result.
            Added throwonerror and it gives the error "Connection Failure: Status Code Unavailable"
            I haven't got access to the ColdFusion server, however I tried it on another CF server to the same affect. I'll install the developer edition on my local PC and retry.
            I will see if I can find any documentation.
            Tested on local PC with CF9 dev server, same issue.
            Documentation does not suggest anything that might help.
            • 3. Re: CFHTTP Connection Failure
              Stormpool Level 1
              I might have been approaching it wrong, it is a SOAP webservice - so I'm going to try this
              http://www.bennadel.com/blog/1809-Making-SOAP-Web-Service-Requests-With-ColdFusion-And-CFH TTP.htm
              well actually it supports http requests, soap 1.1 and soap 1.2
              even with trying the soap approach I get
              struct
              Charsetutf-8
              HeaderHTTP/1.1 200 OK Content-Type: application/soap+xml; charset=utf-8 Date: Sat, 18 Feb 2012 15:01:56 GMT Cache-Control: private, max-age=0 X-AspNet-Version: 4.0.30319 Server: Microsoft-IIS/7.0 X-Powered-By: ASP.NET
              Mimetypeapplication/soap+xml
              Responseheader
              struct
              Content-Typeapplication/soap+xml; charset=utf-8
              DateSat, 18 Feb 2012 15:01:56 GMT
              ExplanationOK
              Status_Code200
              X-Powered-ByASP.NET
              Statuscode200 OK
              TextYES
              • 4. Re: CFHTTP Connection Failure
                BKBK Adobe Community Professional & MVP
                I agree with Owain. The combination of a 200 OK status and cfhttp.filecontent of 'Connection Failure' implies you got a response back, and the response had the message 'Connection Failure' as its only content.
                The content-type is XML, which raises the question, is the service expecting your request to be SOAP?  Could we have a look at your cfhttp code?
                • 5. Re: CFHTTP Connection Failure
                  Stormpool Level 1
                  Well it appears to accept SOAP or HTTP requests.
                  That last dump was product of this code
                  cfsavecontent variable="soapBody">
                  <Cfoutput>
                  <soap12:Envelope xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:soap12="http://www.w3.org/2003/05/soap-envelope">
                    <soap12:Body>
                      <GetCategoryList xmlns="http://xxxx.com/">
                        <apiKey>xxxx</apiKey>
                        <clientID>xxxx</clientID>
                      </GetCategoryList>
                    </soap12:Body>
                  </soap12:Envelope>
                  </cfoutput>
                  </cfsavecontent>
                  <cfhttp url="http://webservices.xxxx.com/services/products.asmx"
                  method="post" result="httpResponse">
                  aram
                  type="header"
                  name="SOAPAction"
                  value="http://webservices.xxxx.com/services/products.asmx/GetCategoryList"
                  <cfhttpparam
                  type="header"
                  <cfhttpparam
                  type="xml"
                  value="#trim( soapBody )#"
                  </cfhttp>
                            <cfdump var="#httpResponse#">
                  • 6. Re: CFHTTP Connection Failure
                    It is usually important to have no characters between the cfsavecontent tag and the XML declaration. Here follows the solution to a similar webservice problem in this forum:
                    <!--- WSDL --->
                    <cfset wsdl_url="http://dwc-dreiman-w7e/WSExchangeMeetingRooms/exchange.asmx?WSDL">
                    <cftry>
                        <!--- Compose SOAP message to send to Web Service--->
                        <cfsavecontent variable="soap"><?xml version="1.0" encoding="UTF-8" ?>
                             <soapenv:Envelope xmlns:soapenv="http://schemas.xmlsoap.org/soap/envelope/" xmlns:xsd="http://www.w3.org/2001/XMLSchema" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance">
                                 <soapenv:Body>
                                     <ns:requestParameterName soapenv:encodingStyle="http://schemas.xmlsoap.org/soap/encoding/" xmlns:ns="http://your_own_namespace_url">
                                            <c xsi:type="xsd:string">bkbk</c>
                                          <d xsi:type="xsd:string">test message from bkbk</d>
                                      </ns:requestParameterName>
                                  </soapenv:Body>
                              </soapenv:Envelope>
                        </cfsavecontent>
                            <!--- Invoke web service to send message--->
                            <cfhttp url="#wsdl_url#" method="post" >
                                <cfhttpparam type="header" name="content-type" value="text/xml">
                                <cfhttpparam type="header" name="SOAPAction" value="">
                                <cfhttpparam type="header" name="content-length" value="#len(soap)#">
                                <cfhttpparam type="header" name="charset" value="utf-8">
                                <cfhttpparam type="xml" name="message" value="#trim(soap)#">
                            </cfhttp>
                            <p><cfoutput>#xmlFormat(cfhttp.fileContent)#</cfoutput> </p>
                        <cfcatch type="any">
                            <cfdump var="#cfcatch#">
                        </cfcatch>
                    </cftry>
