6 Replies Latest reply on Feb 18, 2012 2:00 PM by Muppet Mark
    Javascript RegExp bug?
    TᴀW Adobe Community Professional & MVP
      I'm sending this via email (no Internet access right now) so I hope it
      comes through properly
      In the ExtendScript console, try this:
      "hello".match(/[a-z]+/)
      The output is
      hello
      which is correct
      But if you try this:
      "hello".match(/[f-z]+/)
      the output is only
      h
      which is not what I would have expected. Shouldn't + match all
      characters that are within the range f-z?
      Can anyone help me understand this, or is it in fact a bug?
      Ariel
        • 1. Re: Javascript RegExp bug?
          John Hawkinson Level 5
          Ariel:
          Some portion of your post was misformatted, because Jive turns square brackets into hyperlinks, but I don't think we lost anything.
          This behavior is unambiguously correct. [f-z] matches a single character in the class, and + tells it to match one or more of the previous, in a contiguous block. Since 'h' matches and 'e' does not, it stops with 'h'.
          You haven't told us what you expected, or what you are trying to achieve, so it's a bit tough to give you the answer you're looking for.
          If you are expecting to return the non-contiguous set of characters in the string that match a class, then regexps don't really work that way. You could, I suppose, replace all characters in the inverted class [^f-z] with the null string, which would have a similar effect. i.e. "hello".replace(/[^f-z]/g,"");
          • 2. Re: Javascript RegExp bug?
            Marijan Tompa [tomaxxi] Level 4
            Or simplier: "hello".match(/[f-z]+/g).join("");
            • 3. Re: Javascript RegExp bug?
              It does work correct, as this
              returns two strings: "h,llo" -- exactly as specified in that range
              • 4. Re: Javascript RegExp bug?
                Hi Marijan -- After reading John's post, that's what I thought of as well.
                Ariel
                • 5. Re: Javascript RegExp bug?
                  Hi John,
                  Thanks for your response. Sorry for the formatting problems, but I think
                  you did indeed decipher what came through correctly!
                  I forgot that replace will only return a contiguous block. Now I
                  remember that I've got to use arrays.
                  What I was hoping was to extract from a given string only the letters I
                  want: from "hello" everything but the e, for instance: "hllo"
                  Your inverted idea should work, and also using a "g" tag at the end like
                  you do, with a join("") should do the trick.
                  Thanks for your help. I'll try and remember to mark the answer as
                  correct when I have the chance.
                  Ariel
                  • 6. Re: Javascript RegExp bug?
                    Muppet Mark Level 5
                    Then use the g global as jong did… join the result
