2 Replies Latest reply on Feb 19, 2012 3:45 PM by ninjatogo
    Problems with simple conditionals
    ninjatogo Level 1
      Hello, I am very new to programming but I have started practicing with AIR and Flashbuilder.
      I'm having a bit of trouble trying to write what seems like a simple conditional statement that works.
      My problem is that I have a textbox[a] that may have text in it, when it does have text in it the function I have works.
      I want to pull text from a different textbox[b] when textbox[a] is empty and perform the original function on the text of textbox[b].
      My current code:
      protected function Replace_clickHandler(event:MouseEvent):void
      // TODO Auto-generated method stub
      var str:String = OutputBox.text;
      var search:String = Replacethis.text;
      var replace:String = Replacewith.text;
      function strReplace(str:String, search:String, replace:String):String {
      return str.split(search).join(replace);
      OutputBox.text = (strReplace(str, search, replace));
      Any help would be appreciated!
        • 1. Re: Problems with simple conditionals
          Webtop Level 1
          You should do something like this:
          var str:String = (Textbox1.text != "") ? Textbox1.text : Textbox2.text;
          Replace the references to Textbox1 and Textbox2 with the names of your textboxes.
          That piece of code uses what is called a ternary operator. If the expression in the parentheses is true, the code after the ? is used, otherwise the code after the : is used.
          It is a shorthand version of this:
          if(Text1.text != "") {
              var str:String = Textbox1.text;
          } else {
              var str:String = Textbox2.text;
          They both do the same thing, one is just more concise.
          You should also trim any whitespace from the text before testing it, or a single space in Textbox1 with evaluate as true.
          Hope that helps.
          Paul
          • 2. Re: Problems with simple conditionals
            ninjatogo Level 1
            Thanks for the reply; I can't test it right now, but I will give it a try.
