2 Replies Latest reply on Apr 27, 2015 5:32 AM by Sri80
    External JAR and Execute Script
    VVeasel88 Level 1
      Is there a way to use external jar(Drools) in execute script step? Any alternatives?
      thanks
        • 1. Re: External JAR and Execute Script
          $Nith$ Level 4
          You can use any external jar files in LiveCycle just like other java web application.
          1. Place your JAR file in application's lib directory.
          e.g c:\jboss\server\all\lib
          2. import the package within ExecuteScript activity and start using the classes.
          Nith
          • 2. Re: External JAR and Execute Script
            Sri80
            I am using third party(PDFOne) dll and using it in Execute Script operation.
            I am getting below error message. In the error saying that there is no method "load(java.lang.String)".
            But "load(java.lang.String)" method is available in PdfDocument Class.
            I have tested in eclipse with same line of java code. It is working fine there. What is the problem in ALC ?
            java.lang.RuntimeException: Sourced file: inline evaluation of: ``import com.gnostice.pdfone.PDFOne; import com.gnostice.pdfone.PdfDocument; impor . . . '' : Error in method invocation: Method load( java.lang.String ) not found in class'com.gnostice.pdfone.PdfDocument' : at Line: 14 : in file: inline evaluation of: ``import com.gnostice.pdfone.PDFOne; import com.gnostice.pdfone.PdfDocument; impor . . . '' : d .load ( "C:\\Users\\e0208940\\Documents\\Applications\\PoC Empower IQ approval\\01-Checksum.pdf" )
