17 Replies Latest reply on Feb 23, 2012 3:27 PM by kevinlesser73
    simple slug script
    kevinlesser73
      im trying to create a simple bottom of document, slug for cs5 ID in applescript on 10.6.8
      within the slug should sit 3 words, 'one', 'two' 'three' each word on a separate line, not 1 continuous line. im struggling to understand how to position a text frame rather than one continuous line
      can anyone assist?
      kl73
        • 1. Re: simple slug script
          Muppet Mark Level 5
          tell application "Adobe InDesign CS5"
                    tell the active document
                              tell the first spread
                                        set slugText to make new text frame with properties ¬
                                                  {geometric bounds:{(item 3 of page 1's bounds), 0, ((item 3 of page 1's bounds) + 15), 30}}
                                        set contents of slugText to "one" & return & "two" & return & "three"
                              end tell
                    end tell
          end tell
          --adds it bottom left for me…
                              set a to document bleed bottom offset of document preferences
                              set b to slug bottom offset of document preferences
                                        set c to item 3 of page 1's bounds
                                                  {geometric bounds:{(c + a), 0, (c + b), 30}}
                              end tell
                    end tell
          end tell
          --some tabbing madness here… a little better but it does presume bleeds and slugs
          • 2. Re: simple slug script
            kevinlesser73 Level 1
            mark
            thanks, you make it look so easy! another question if i may?!!
            i have adapted;
            how can i put more space between each line of type and to format to an arial bold 10pt for example?? i tried to increase 15 and 30 figures but no change???, you can see ive added some text tags in replacement of one two three, the slug grame is not big enough now!!
            cheers, really appreciate assistance, whih country are you in?
                                          set contents of slugText to "{{_es_signer_signatureblock}}" & return & "Qty:{{*comment1_es_signer}}" & return & "Invoiced to:{{*comment1_es_signer}}"
                                end tell
                      end tell
            end tell
            • 3. Re: simple slug script
              Muppet Mark Level 5
              This goes inside the tell spread block… after you set the contents… I wouldn't have guessed applied font
              set applied font of every paragraph of slugText to "Arial MT          Bold"
              set point size of every paragraph of slugText to 10
              set leading of every paragraph of slugText to 20
              • 4. Re: simple slug script
                im understanding the 'returns'! and im nearly there i think,
                this code
                set applied font of every paragraph of slugText to "Verdana"
                                              set leading of every paragraph of slugText to 16
                is only working on the 1st line of type for some reason mark?, i presume its because ive added 2 more returns? (see below), i need these extra 2 returns after 1st line as the tag in line 1 produces a rather deep box, also the text frame is way too small, i need to extend the handles on the box to make the type visible, is there a way to make the frame the width of the document?
                thanks alot.
                k
                                              set contents of slugText to "{{_es_signer_signatureblock}}" & return & return & return & "Qty:{{*comment1_es_signer}}" & return & "Invoiced to:{{*comment1_es_signer}}"
                                    end tell
                          end tell
                end tell
                • 5. Re: simple slug script
                  Muppet Mark Level 5
                  Well you can do that in a couple of ways… Adding returns is going to give you blank paragraphs of 16pt leading… Or you could set the leading for each paragraph to suit…
                                                set d to item 4 of page 1's bounds
                                                          {geometric bounds:{(c + a), 0, (c + b), d}}
                                                set contents of slugText to "{{_es_signer_signatureblock}}" & return ¬
                                                          & "Qty:{{*comment1_es_signer}}" & return ¬
                    --set applied font of every paragraph of slugText to "Arial MT Bold"
                                                set leading of second paragraph of slugText to 40
                                      end tell
                            end tell
                  end tell
                  I just commented out the font swap line as don't have that loaded now… The box is page width from bleed offset to slug offset
                  • 6. Re: simple slug script
                    excellent, i was getting errors but i worked that out, because slug on doc was not big enough
                    is there a way i can automate a slug creation to fit also?
                    scripting is awesome!!! i would love to learn more.
                    thanks mark
                    • 7. Re: simple slug script
                      Mars_Man
                      Hi Muppet Mark,
                      I've just been reading through this thread, and was wondering if you could help me. I'm looking to set up a script sort of along these lines, excpet that I would want the script to create a new indesign document and then add in a indesign snippet into the slug. The doucment sizes would vairey each time so the cordinates of the placed snippet would also change each time. I've been looking on line for some help on this as my scripting knowledge isnt that good. Do think it possible to do this?
                      Sorry for tagging onto the topic, but you seem pretty clued up on the scripting side and its in the same area.
                      Marsman
                      • 8. Re: simple slug script
                        Muppet Mark Level 5
                        Yes you can set both the slug and bleed offsets… They are read/write properties… As I stated the script as is was expecting these to be set but if they aren't then it could set them first… I mostly use new document presets where this can be defined…
                        • 9. Re: simple slug script
                          something like this?
                              tell document preferences of active document
                                  set document bleed bottom offset to "8p"
                                  set document bleed top offset to "8p"
                                  set document bleed inside or left offset to "8p"
                                  set document bleed outside or right offset to "8p"
                                  set slug bottom offset to "6p"
                                  set slug top offset to "0p"
                                  set slug inside or left offset to "0p"
                                  set slug right or outside offset to "0p"
                              end tell
                                          & "Invoiced to:{{*comment2_es_signer}}"
                                      set applied font of every paragraph of slugText to "Minion Pro"
                                      set point size of every paragraph of slugText to 12
                                  end tell
                              end tell
                          end tell
                          dont work so i presume its wrong!
                          • 10. Re: simple slug script
                            Muppet Mark Level 5
                            Using snippets and events scripting are 2 things I have not done yet… It may be possible though… You may get more luck/answers if you are open to using JavaScript for this… ( more popular )
                            • 11. Re: simple slug script
                              Muppet Mark Level 5
                              Slugs and bleed can be set using 4 separate values or all 4 linked to one value… Your slug values are less than your bleeds… I would not expect that… A quickly hashed example… Uniform bleeds but but a deeper bottom slug
                                                            if document bleed uniform sizetrue then
        set document bleed uniform size to true
        set document bleed top offset to 5
                                                            end if
                                                            if document slug uniform sizefalse then
        set document slug uniform size to false
        set slug top offset to 10
        set slug inside or left offset to 10
        set slug right or outside offset to 10
        set slug bottom offset to 30
                                                            end if
                                                  end tell
        {geometric bounds:{(c + 5), 0, (c + 30), d}}
                                                  end tell
                                        end tell
                              end tell
                              • 12. Re: simple slug script
                                i need to study this... to understand the difference.
                                i changed the second return to a tab, due to aesthetics! but on a short width document e.g. a business card, the text frame is not wide enough, because it adheres to the page bounds, i tried to do the obvious, change bounds to other descriptions but wont work....?
                                • 13. Re: simple slug script
                                  to understand how to adjust a tab value would be good also.
                                  • 14. Re: simple slug script
                                    mark
                                    ive got around my issue by just repeating & tab & tab & tab!
                                    i dont understand what item 3 and item 4 is in this piece of code
                                    set c to item 3 of page 1's bounds, set d to item 4 of page 1's bounds
                                    i presume this is the key to making the text frame larger than page size?
                                    thanks
                                    • 15. Re: simple slug script
                                      Muppet Mark Level 5
                                      The bounds of an object are a 4 ltem list in AppleScript… So if I ask for the bounds of a page like so…
                                                          get bounds of the first page
                                                end tell
                                      end tell
                                      It will return {0.0, 0.0, 296.999999999461, 209.999999999936} my default A4… So the script is just using the values of the 3rd and 4th items out of the list to do a little math with…
                                      As for your tabs then they belong to paragraphs so apply them there here is an example using 2
                                                          tell the first text frame
        tell the first paragraph
                                        make new tab stop at beginning with properties ¬
        {alignment:left align, position:10}
                                        make new tab stop at end with properties ¬
        {alignment:left align, position:30}
        end tell
                                                          end tell
                                                end tell
                                      end tell
                                      tab, tab, tab, tut, tut I'll take that keyboard off ya…
                                      • 16. Re: simple slug script
                                        these wireless keyboards are no good!!!
                                        get the bounds thing, makes sense, not sure how to position your last code into existing?? see below
                                        im sure its something so simple to you experts!
                                                set document bleed bottom offset to "1p"
                                                set document bleed top offset to "1p"
                                                set document bleed inside or left offset to "1p"
                                                set document bleed outside or right offset to "1p"
                                                set slug bottom offset to "8p"
                                                set slug right or outside offset to "8p"
                                            end tell
                                                    set contents of slugText to "{{_es_signer_signatureblock}}" & tab ¬
                                                        & "Qty:  {{*comment1_es_signer}}" & return ¬
                                                        & "Invoiced to:  {{*comment2_es_signer}}"
                                                end tell
                                                        end tell
                                                    end tell
                                                    set applied font of every paragraph of slugText to "Arial"
                                                    set leading of second paragraph of slugText to 24
                                                end tell
                                            end tell
                                        end tell
                                        • 17. Re: simple slug script
                                          still struggling with the tab, tab, tab, however i position your code it doesnt alter the position of tabs??? ive prob got it in wrong place
                                                              set slug bottom offset to "14p"
                                                              set slug right or outside offset to "10p"
                                                    end tell
        & "Qty:{{*comment1_es_signer}}" & tab ¬
        end tell
        end tell
        set applied font of every paragraph of slugText to "Times"
        set leading of every paragraph of slugText to 60
                                                              end tell
