1 Reply Latest reply on Mar 23, 2012 10:52 AM by Mrsunilg
    Invocation error or access error
    Mrsunilg Level 1
      I am using invokation method to invoke adobe livecycle processes. I am able to invoke livecycle process but not able to pass the parameters in map from java code to adobe process using invocation method.
      when i run the smiliar code from another machine, the process is getting invoked too and parameters are also passing. But from some machines it is only getting invoked, parameter is passed as null.
      I recorded the process and found that each input parameters are null.
      It is system access issue : If yes, then i should not be able to invoke the process.
      i get following errors because input parameters are null
      14:02:38,142 ERROR [Document] DOCS001: Unexpected exception. While doing first time passivation for a document..
      1. java.lang.ClassCastException: com.adobe.repository.RepositoryException cannot be cast to com.adobe.repository.ResourceNotFoundException
              at com.adobe.repository.commands.RepositoryUrlDataProviderCommand.execute(RepositoryUrlDataP roviderCommand.java:162)
              at com.adobe.repository.commands.CommandProcessor.execute(CommandProcessor.java:135)
              at com.adobe.repository.bindings.docmanager.DocManagerBinding.repositoryUrlDataProvider(DocM anagerBinding.java:185)
              at com.adobe.repository.bindings.docmanager.DocManagerBinding.repositoryUrlDataProvider(DocM anagerBinding.java:162)
              at com.adobe.idp.RepositoryHelperImpl.callRepository(RepositoryHelperImpl.java:109)
              at com.adobe.idp.RepositoryHelperImpl.callPassivate(RepositoryHelperImpl.java:82)
              at com.adobe.idp.Document.passivateInitData(Document.java:1524)
              at com.adobe.idp.Document.passivate(Document.java:1241)
              at com.adobe.idp.Document.passivate(Document.java:1180)
              at com.adobe.idp.DocumentManagerClient.getDocumentInlineData(DocumentManagerClient.java:779)
              at com.adobe.pdfdocumentmanager.client.DocumentAppenderByteWriter.newDocumentByteReader(Docu mentAppenderByteWriter.java:423)
              at com.adobe.pdfdocumentmanager.client.SharedPdfDocumentContext.toPDFDocument(SharedPdfDocum entContext.java:747)
              at com.adobe.formServer.utils.CommonGibsonUtils.PDFDocumentFromDocument(CommonGibsonUtils.ja va:127)
              at com.adobe.printSubmitter.PrintServer.transformPDF(PrintServer.java:336)
              at com.adobe.printSubmitter.service.OutputServiceImpl.transformPDFInTxn(OutputServiceImpl.ja va:777)
              at com.adobe.printSubmitter.service.OutputServiceImpl$4.doInTransaction(OutputServiceImpl.ja va:741)
              at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doRequiresNew (EjbTransactionBMTAdapterBean.java:218)
              at sun.reflect.GeneratedMethodAccessor302.invoke(Unknown Source)
              at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
              at java.lang.reflect.Method.invoke(Method.java:597)
              at org.jboss.invocation.Invocation.performCall(Invocation.java:359)
              at org.jboss.ejb.StatelessSessionContainer$ContainerInterceptor.invoke(StatelessSessionConta iner.java:237)
              at org.jboss.resource.connectionmanager.CachedConnectionInterceptor.invoke(CachedConnectionI nterceptor.java:158)
              at org.jboss.ejb.plugins.CallValidationInterceptor.invoke(CallValidationInterceptor.java:63)
              at org.jboss.ejb.plugins.AbstractTxInterceptor.invokeNext(AbstractTxInterceptor.java:121)
              at org.jboss.ejb.plugins.AbstractTxInterceptorBMT.invokeNext(AbstractTxInterceptorBMT.java:1 73)
              at org.jboss.ejb.plugins.TxInterceptorBMT.invoke(TxInterceptorBMT.java:77)
              at org.jboss.ejb.plugins.StatelessSessionInstanceInterceptor.invoke(StatelessSessionInstance Interceptor.java:169)
              at org.jboss.ejb.plugins.SecurityInterceptor.invoke(SecurityInterceptor.java:168)
              at org.jboss.ejb.plugins.LogInterceptor.invoke(LogInterceptor.java:205)
              at org.jboss.ejb.plugins.ProxyFactoryFinderInterceptor.invoke(ProxyFactoryFinderInterceptor. java:138)
              at org.jboss.ejb.SessionContainer.internalInvoke(SessionContainer.java:648)
              at org.jboss.ejb.Container.invoke(Container.java:960)
              at org.jboss.ejb.plugins.local.BaseLocalProxyFactory.invoke(BaseLocalProxyFactory.java:430)
              at org.jboss.ejb.plugins.local.StatelessSessionProxy.invoke(StatelessSessionProxy.java:103)
              at $Proxy216.doRequiresNew(Unknown Source)
              at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:133)
              at com.adobe.idp.dsc.transaction.impl.DefaultTransactionTemplate.execute(DefaultTransactionT emplate.java:79)
              at com.adobe.printSubmitter.service.OutputServiceImpl.transformPDFWithSMT(OutputServiceImpl. java:735)
              at com.adobe.printSubmitter.service.OutputServiceImpl.transformPDF(OutputServiceImpl.java:72 4)
              at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
              at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
              at com.adobe.idp.dsc.component.impl.DefaultPOJOInvokerImpl.invoke(DefaultPOJOInvokerImpl.jav a:118)
              at com.adobe.idp.dsc.interceptor.impl.InvocationInterceptor.intercept(InvocationInterceptor. java:140)
              at com.adobe.idp.dsc.interceptor.impl.RequestInterceptorChainImpl.proceed(RequestInterceptor ChainImpl.java:60)
              at com.adobe.idp.dsc.interceptor.impl.DocumentPassivationInterceptor.intercept(DocumentPassi vationInterceptor.java:53)
              at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor$1.doInTransaction(Transa ctionInterceptor.java:74)
              at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionBMTAdapterBean.doBMT(EjbTran sactionBMTAdapterBean.java:197)
              at sun.reflect.GeneratedMethodAccessor308.invoke(Unknown Source)
              at $Proxy216.doBMT(Unknown Source)
              at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:95)
              at com.adobe.idp.dsc.transaction.interceptor.TransactionInterceptor.intercept(TransactionInt erceptor.java:72)
              at com.adobe.idp.dsc.interceptor.impl.InvocationStrategyInterceptor.intercept(InvocationStra tegyInterceptor.java:55)
              at com.adobe.idp.dsc.interceptor.impl.InvalidStateInterceptor.intercept(InvalidStateIntercep tor.java:37)
              at com.adobe.idp.dsc.interceptor.impl.AuthorizationInterceptor.intercept(AuthorizationInterc eptor.java:188)
              at com.adobe.idp.dsc.interceptor.impl.JMXInterceptor.intercept(JMXInterceptor.java:48)
              at com.adobe.idp.dsc.engine.impl.ServiceEngineImpl.invoke(ServiceEngineImpl.java:121)
              at com.adobe.idp.dsc.routing.Router.routeRequest(Router.java:129)
              at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.routeMessage(AbstractMessage Receiver.java:93)
              at com.adobe.idp.dsc.provider.impl.vm.VMMessageDispatcher.doSend(VMMessageDispatcher.java:22 5)
              at com.adobe.idp.dsc.provider.impl.base.AbstractMessageDispatcher.send(AbstractMessageDispat cher.java:66)
              at com.adobe.idp.dsc.clientsdk.ServiceClient.invoke(ServiceClient.java:208)
              at com.adobe.workflow.engine.PEUtil.invokeAction(PEUtil.java:861)
              at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.transientInvoke(WorkflowDSCInvoker. java:347)
              at com.adobe.idp.workflow.dsc.invoker.WorkflowDSCInvoker.invoke(WorkflowDSCInvoker.java:158)
              at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.execute(EjbTr ansactionCMTAdapterBean.java:357)
              at com.adobe.idp.dsc.transaction.impl.ejb.adapter.EjbTransactionCMTAdapterBean.doRequiresNew (EjbTransactionCMTAdapterBean.java:299)
              at sun.reflect.GeneratedMethodAccessor289.invoke(Unknown Source)
              at org.jboss.ejb.plugins.TxInterceptorCMT.runWithTransactions(TxInterceptorCMT.java:404)
              at org.jboss.ejb.plugins.TxInterceptorCMT.invoke(TxInterceptorCMT.java:181)
              at $Proxy215.doRequiresNew(Unknown Source)
              at com.adobe.idp.dsc.transaction.impl.ejb.EjbTransactionProvider.execute(EjbTransactionProvi der.java:143)
              at com.adobe.idp.dsc.provider.impl.base.AbstractMessageReceiver.invoke(AbstractMessageReceiv er.java:329)
              at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invokeCall(SoapSdkEndpoint. java:139)
              at com.adobe.idp.dsc.provider.impl.soap.axis.sdk.SoapSdkEndpoint.invoke(SoapSdkEndpoint.java :81)
              at sun.reflect.GeneratedMethodAccessor514.invoke(Unknown Source)
              at org.apache.axis.providers.java.RPCProvider.invokeMethod(RPCProvider.java:397)
              at org.apache.axis.providers.java.RPCProvider.processMessage(RPCProvider.java:186)
              at org.apache.axis.providers.java.JavaProvider.invoke(JavaProvider.java:323)
              at org.apache.axis.strategies.InvocationStrategy.visit(InvocationStrategy.java:32)
              at org.apache.axis.SimpleChain.doVisiting(SimpleChain.java:118)
              at org.apache.axis.SimpleChain.invoke(SimpleChain.java:83)
              at org.apache.axis.handlers.soap.SOAPService.invoke(SOAPService.java:454)
              at org.apache.axis.server.AxisServer.invoke(AxisServer.java:281)
              at org.apache.axis.transport.http.AxisServlet.doPost(AxisServlet.java:699)
              at javax.servlet.http.HttpServlet.service(HttpServlet.java:710)
              at org.apache.axis.transport.http.AxisServletBase.service(AxisServletBase.java:327)
              at javax.servlet.http.HttpServlet.service(HttpServlet.java:803)
              at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:290)
              at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:206)
              at com.adobe.idp.dsc.provider.impl.soap.axis.InvocationFilter.doFilter(InvocationFilter.java :43)
              at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.j ava:235)
              at com.adobe.idp.um.auth.filter.CSRFFilter.doFilter(CSRFFilter.java:41)
              at org.jboss.web.tomcat.filters.ReplyHeaderFilter.doFilter(ReplyHeaderFilter.java:96)
              at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:230)
              at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:175)
              at org.jboss.web.tomcat.security.SecurityAssociationValve.invoke(SecurityAssociationValve.ja va:179)
              at org.jboss.web.tomcat.security.JaccContextValve.invoke(JaccContextValve.java:84)
              at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:128)
              at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:104)
              at org.jboss.web.tomcat.service.jca.CachedConnectionValve.invoke(CachedConnectionValve.java: 157)
              at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:109)
              at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:241)
              at org.apache.coyote.http11.Http11Processor.process(Http11Processor.java:844)
              at org.apache.coyote.http11.Http11Protocol$Http11ConnectionHandler.process(Http11Protocol.ja va:580)
              at org.apache.tomcat.util.net.JIoEndpoint$Worker.run(JIoEndpoint.java:447)
              at java.lang.Thread.run(Thread.java:619)
      14:02:38,154 ERROR [OutputException] ALC-OUT-001-204: Could not transform input PDF file. com.adobe.repository.RepositoryException cannot be cast to com.adobe.repository.ResourceNotFoundException
      14:02:38,175 ERROR [WorkflowDSCInvoker] An exception was thrown with name com.adobe.livecycle.output.exception.OutputException message:ALC-OUT-001-204: Could not transform input PDF file. com.adobe.repository.RepositoryException cannot be cast to com.adobe.repository.ResourceNotFoundException while
