6 Replies Latest reply on Feb 22, 2012 5:09 AM by Ned Murphy
    why wont this script work???
    janineabc
      I have previously used this script to make a portrait scroll bar which works perfectly, however i have altered the script to work in a landscape scroll bar by altering the x and y axis and switching out the height for width. However a part of it wont work...The left and right arrows work correctly however the scroll bar does not move and I can not for the life of me figure out why.
      Does anyone have any ideas as to what ive missed or done wrong?
      Thanks in advance
      scrolling = function () {
      var scrollWidth:Number = scrollTrack._width;
      var contentWidth:Number = contentMain._width;
      var scrollFaceWidth:Number = scrollFace._width;
      var maskWidth:Number = maskedView._width;
      var initPosition:Number = scrollFace._x=scrollTrack._x;
      var initContentPos:Number = contentMain._x;
      var finalContentPos:Number = maskWidth-contentWidth+initContentPos;
      var left:Number = scrollTrack._y;
      var top:Number = scrollTrack._x;
      var right:Number = scrollTrack._y;
      var bottom:Number = scrollTrack._width-scrollFaceWidth+scrollTrack._x;
      var dy:Number = 0;
      var speed:Number = 10;
      var moveVal:Number = (contentWidth-maskWidth)/(scrollWidth-scrollFaceWidth);
      scrollFace.onPress = function() {
        var currPos:Number = this._x;
        startDrag(this, false, left, top, right, bottom);
        this.onMouseMove = function() {
         dy = Math.abs(initPosition-this._x);
         contentMain._x = Math.round(dy*-1*moveVal+initContentPos);
      scrollFace.onMouseUp = function() {
        stopDrag();
        delete this.onMouseMove;
      btnUp.onPress = function() {
        this.onEnterFrame = function() {
         if (contentMain._x+speed<maskedView._x) {
          if (scrollFace._x<=top) {
           scrollFace._x = top;
          } else {
           scrollFace._x -= speed/moveVal;
          contentMain._x += speed;
         } else {
          contentMain._x = maskedView._x;
          delete this.onEnterFrame;
      btnUp.onDragOut = function() {
      btnUp.onRelease = function() {
      btnDown.onPress = function() {
         if (contentMain._x-speed>finalContentPos) {
          if (scrollFace._x>=bottom) {
           scrollFace._x = bottom;
          } else {
           scrollFace._x += speed/moveVal;
          contentMain._x -= speed;
         } else {
          contentMain._x = finalContentPos;
      btnDown.onRelease = function() {
      btnDown.onDragOut = function() {
      if (contentWidth<maskWidth) {
        scrollFace._visible = false;
        btnUp.enabled = false;
        btnDown.enabled = false;
      } else {
        scrollFace._visible = true;
        btnUp.enabled = true;
        btnDown.enabled = true;
      scrolling();
        • 1. Re: why wont this script work???
          Can you isolate only the code that applies to the part that doesn't work.  It makes it easier to focus on the problemed area.
          • 2. Re: why wont this script work???
            janineabc Level 1
            sorry should have said...its the aspect relating to "scrollFace" which is mentioned throughout..ive marked it out in bold and taken out anything unrelivant.
            So its:
              stopDrag();
                } else {
               } else {
                } else {
               } else {
            } else {
            • 3. Re: why wont this script work???
              Even with that reduction it is at best a tangle of code to try to reason out.  I think I see you have nested functions at least two levels deep, possibly further since I can't see where the initial one ends, and nesting functions is best avoided and more often unnecessary....
              Since you say the problem is that the scrollbar does not move, does it not move relative to pushing the buttons or does it not move relative to dragging it.
              • 4. Re: why wont this script work???
                janineabc Level 1
                I've had a bit of a play with it and i managed to make it register that there is a scroll bar there, however it appears way to the right even beyond the right hand arrow and as soon as i click on the arrow button the scroll completely disappears. So the scroll bar doesn’t move either way at the minute.
                I will have a play and see how I go.
                • 5. Re: why wont this script work???
                  janineabc Level 1
                  Throught I would let you know that I've got it working..the script didnt need editing at all...it was the scroll element that was working back to front. So i simply rotated it and boom.
                  Thanks alot for your time
                  • 6. Re: why wont this script work???
                    Your best bet at solving this will be to use the trace function to see what kinds of _x values you are encountering and which values that define them are causing the jumps.
