3 Replies Latest reply on Feb 22, 2012 7:31 AM by Ned Murphy
    Implicit coercion of a value of type fl.controls:ComboBox to an unrelated type XMLList
    JJ0330 Level 1
      Hi, new to Flash and working on a school assignment and don't understand the error in yellow below.  Below is the code snippets of two function involved.  Thanks, Joe
      Error:
      Implicit coercion of a value of type fl.controls:ComboBox to an unrelated type XMLList.
      Code:
                                        private var _feed_list:ComboBox;
      private function done_loading(e:Event){
                                                      var feed_xml:XML = new XML(e.target.data);
                                                      var feed_items:XMLList = feed_xml.*;
                                                      populate(_feed_list);
                                                      var match:Boolean = false;
                                                      for(var i=0;i < _feeds_dp.length;i++){
        if(_feeds_dp.getItemAt(i).link == feed_xml.@link){
        match = true;
      private function populate(xml:XMLList){
                                                      var count:int = 1;
                                                      for each(var item:XML in xml.item){
        var t:String = item.title == '' ? item.link:item.title;
        _feeds_entries_dp.addItem({
        label:t+', '+item.date,
        link:item.link,
        preview:item.preview,
        description:item.description,
        date:item.date,
        time:item.time,
        author:item.creator,
        media:item.media
        _feed_entry_list.labelField = 'label';
        _feed_entry_list.dataProvider = _feeds_entries_dp;
