2 Replies Latest reply on Feb 22, 2012 7:23 AM by cathysnyder
    RH 7 project upgraded to RH 9 does not show the doctype as XHTML
    cathysnyder Level 1
      I’m using Robohelp version 9.0.2.271 and I successfully upgraded a project in Robohelp 9 from Robohelp 7. However, in the source at the top of the files, the doctype shows as HTML instead of XHTML as follows:
      <!DOCTYPE HTML PUBLIC "-//W3C//DTD HTML 4.01 Transitional//EN">
      My co-worker who is using the same version of RH 9 upgraded this same project and her doctype shows as XHTML as follows:
      <!DOCTYPE html PUBLIC "-//W3C//DTD XHTML 1.0 Transitional//EN"
          "http://www.w3.org/TR/xhtml1/DTD/xhtml1-transitional.dtd">
      Shouldn’t the source show XHTML when using RH 9? And, if so, shouldn’t this have automatically converted when I upgraded the project from RH 7? Is there a setting or something I need to change to show this?
      I’ve tried uninstalling and reinstalling RH 9 several times and reconverted the project, as well, in case there was some problem with the install or the conversion, and have not had any success. I have also applied the 9.0.2 update after running the installation. Thanks for your help.
