3 Replies Latest reply on Feb 27, 2012 2:28 PM by jrunrandy
    About the FlexNativeMenu control
    community help Level 1
      This question was posted in response to the following article: http://help.adobe.com/en_US/flex/using/WSacd9bdd0c5c09f4a-690d4877120e8b878b0-7fea.html
        • 1. Re:  About the FlexNativeMenu control
          levancho Level 3
          example about array as dataprovider does not seem to be correct, can Array be bindable?
                      public var objMenuData:Array = [
          • 2. Re:  About the FlexNativeMenu control
            levancho Level 3
            I guess pasting code did not go that well...
            anyway it says :      public var objMenuData:Array
            • 3. Re:  About the FlexNativeMenu control
              jrunrandy Adobe Employee
              @levancho,
              Sorry, but I didn't write this and don't know the answer to your questions. However, I asked a developer and here is what he said:
              It works because the example is not using any bindable functionality. It will work the same way even if you remove the [Bindable] tag.
              If you really want to bind to the data source, then you need the following:
              1. Define the var with [Bindable] (which you already did)
              2. Use ArrayCollection instead of Array
              3. Assign the dataProvider using curly braces {} via mxml or by using BindingUtils.bindProperty() of you want to do it in actionscript.
              Hope this helps,
              Randy Nielsen
              Senior Content and Community Manager
              Adobe Systems Incorporated
