1 Reply Latest reply on Feb 26, 2012 6:26 AM by BKBK
    How to Enable/Disable form item, with changing on CFSELECT on FLASH type CFFORM.
    Ali Parsa
      i have a problem with my small code.
      i have a CFFORM on FLASH mode. I have an CFSELECT itehm and 1 CFINPUT TEXT, so i need to Enable my text box when  i select "OTHER" from CFSELECT and disable the text box if i have other choice .
      <cfform name="pipe_add" action="kooft.cfm" enctype="multipart/form-data" method="post" format="flash" skin="haloorange" width="300" height="850">
                  <cfformitem type="script">
                  function dospec(field){
                      if(field.value == "0") {
                          _root.p_nspec.enabled = true;
                      } else {
                          _root.p_nspec.enabled = false;
                  </cfformitem>
                  <cfformgroup type="panel" label="Pipe Specification">
                      <cfselect name="p_cspec" onchange="dospec(this);" query="pipe_Spec" value="spec_id" display="spec_name" label="Specification :" size="1" width="70"  >
                          <option value = "0" >Other . . .</option>
                      </cfselect>
                      <cfinput name="p_nspec" label="Other Specification :" size="15" Enabled="False">
                  </cfformgroup>
      </cfform>
      is here anyone can help me ?
        • 1. Re: How to Enable/Disable form item, with changing on CFSELECT on FLASH type CFFORM.
          BKBK Adobe Community Professional & MVP
          <cfform name="pipe_add" action="kooft.cfm" format="flash"  method="post"  skin="haloorange" width="300" height="850">
          <cfformitem type="script" >
          function dospec(){
              if(p_cspec.value == 0) {
                  p_nspec._visible = false;
              else {
                  p_nspec._visible = true;
          </cfformitem>
          <cfselect name="p_cspec" id="p_cspec"  onchange="dospec()" query="pipe_Spec" value="spec_id" display="spec_name" label="Specification :" size="1" width="70">
          </cfselect>
          <cfinput type="text" id="p_nspec" name="p_nspec" label="Other Specification :" size="15" Enabled="False">
          </cfformgroup>
          </cfform>
