2 Replies Latest reply on Feb 23, 2012 11:17 AM by B4stien
    Grouping PageItems
    B4stien
      Hi everyone,
      I'm struggeling with this problem, I'm trying to group 2 PageItems, one of them is a TextFrame, while the second can be a Story, an Image or a PDF. I add those items programmatically on the page and then try to group them:
      function insertFile(file:File, description:String, page:Page):void{
        var placedObject:Object = page.place(file);
        var myTextFrame:TextFrame = page.textFrames.add();
        var objectBounds:Object = placedObject.geometricBounds;
        myTextFrame.geometricBounds = [objectBounds[2], objectBounds[1], objectBounds[2] + 5, objectBounds[3]];
        myTextFrame.contents = description;
        page.groups.add([myTextFrame, placedObject]);
      Unfortunatelly this fails and returns: Invalid parameter at the "page.groups.add([myTextFrame, placedObject]);" line.
      I've tried to call a Javascript script with the pageItems ids as argument instead, but the script can't find the "placedObject" in the list of pageItems.
      InDesign.app.doScript(file, ScriptLanguage.JAVASCRIPT, [''+myTextFrame.id, ''+placedObject.id]); // => alerts: Given ids: 302, 276 - Available ids: 302, 271
      If I try to fetch the placedObject via its id in my method it finds it, but the groups.add still fails:
      var placedItem:PageItem = page.pageItems.itemById(placedObject.id);
      I've also tried to create 2 TextFrames and group them, and this works. So there seem to be something wrong with my placedObject, but I can't figure out what. Does anyone has a clue?
      Thanks for your help.
      -- Bastien
        • 1. Re: Grouping PageItems
          absqua Level 4
          In JavaScript, anyway, place() returns an array whose members are the images, pdfs, or whatever. You can't add those to groups; you have to add their parent rectangles. So, again in JavaScript, it would need to look like:
          var placedObject  = page.place(file)[0].parent;
          You should be able to group that.
          Jeff
          • 2. Re: Grouping PageItems
            B4stien Level 1
            Thanks big time Jeff! Using the parent works.
            (In ActionScript place() returns an array as well, I just forgot it in my example)
