0 Replies Latest reply on Feb 23, 2012 9:39 AM by hobbes26
    Can anyone solve this simple MVC problem with ArrayCollection
    hobbes26
      I have very simple application trying to understand how to apply MVC without any framework. There are quite a few exemples on the net but most do not deal with complex data.
      here is my application with 4 files: MVCtest.mxml, MyController.as, MyModel.as and MyComponent.as
      first the Model MyModel.as
      package model
      import flash.events.Event;
      import flash.events.EventDispatcher;
      import flash.events.IEventDispatcher;
      import mx.collections.ArrayCollection;
      [Event(name="ArrayColChanged", type="flash.events.Event")]
      [Bindable]
      public class MyModel extends EventDispatcher
        private static var instance:MyModel;
        public static const ARRAYCOL_CHANGED:String = "ArrayColChanged";
        private var _myArrayCol:ArrayCollection;
        public function MyModel(target:IEventDispatcher=null)
         super(target);
         instance = this;
        public static function getInstance():MyModel
         if(instance == null)
          instance = new MyModel();
         return instance;
        public function get myArrayCol():ArrayCollection
         return _myArrayCol;
        public function set myArrayCol(value:ArrayCollection):void
         _myArrayCol = new ArrayCollection(value.source);
         dispatchEvent(new Event(ARRAYCOL_CHANGED));
      then the controller: MyController.as
      package controller
      import components.MyComponent;
      import model.MyModel;
      import mx.controls.Alert;
      import mx.rpc.events.FaultEvent;
      import mx.rpc.events.ResultEvent;
      import mx.rpc.remoting.RemoteObject;
      public class MyController extends EventDispatcher
        [Bindable]
        public var view:MVCtest;
        [Bindable]
        public var componentView:MyComponent;
        private var _model:MyModel = MyModel.getInstance();
        public function MyController(target:IEventDispatcher=null)
         super(target);
         _model.addEventListener("ArrayColChanged", onArrayColChange);
        public function initialise(event:Event):void
         getData();
        public function getData():void
         var dataRO:RemoteObject = new RemoteObject;
         dataRO.endpoint = "gateway.php";
         dataRO.source = "MytestdbService";
         dataRO.destination = "MytestdbService";
         dataRO.addEventListener(ResultEvent.RESULT, dataROResultHandler);
         dataRO.addEventListener(FaultEvent.FAULT, dataROFaultHandler);
         dataRO.getAllMytestdb();
        public function dataROResultHandler(event:ResultEvent):void
         _model.myArrayCol = new ArrayCollection((event.result).source);
        public function dataROFaultHandler(event:FaultEvent):void
         Alert.show(event.fault.toString());
        public function onArrayColChange(event:Event):void
         componentView.myDataGrid.dataProvider = _model.myArrayCol;
      This is the main application: MVCtest.mxml
            xmlns:mx="library://ns.adobe.com/flex/mx"
            xmlns:controller="controller.*"
            xmlns:components="components.*"
            width="600" height="600"
            creationComplete="control.initialise(event)">
      <fx:Declarations>
        <controller:MyController id="control" view = "{this}"/>
      </fx:Declarations>
      <fx:Script>
        <![CDATA[
         import valueObjects.MyVOorDTO;
         [Bindable]
      </fx:Script>
      <s:VGroup paddingTop="10" paddingLeft="10" paddingRight="10" paddingBottom="10">
        <s:Label fontSize="20" fontWeight="bold" text="MVC Test with components"
           verticalAlign="middle"/>
        <components:MyComponent/>
      </s:VGroup>
      </s:Application>
      And this is the component: MyComponent.mxml
      <s:Group xmlns:fx="http://ns.adobe.com/mxml/2009"
         xmlns:mx="library://ns.adobe.com/flex/mx" width="400" height="300">
      <s:layout>
        <s:VerticalLayout paddingBottom="10" paddingLeft="10" paddingRight="10" paddingTop="10"/>
      </s:layout>
      <fx:Declarations>
        <!-- Place non-visual elements (e.g., services, value objects) here -->
      </fx:Declarations>
      <s:Label fontSize="16" fontWeight="bold" text="My Component " verticalAlign="bottom"/>
      <s:DataGrid id="myDataGrid" width="100%" height="100%" requestedRowCount="4">
        <s:columns>
         <s:ArrayList>
          <s:GridColumn dataField="mystring" headerText="String"></s:GridColumn>
          <s:GridColumn dataField="myinteger" headerText="Integer"></s:GridColumn>
          <s:GridColumn dataField="myreal" headerText="Real"></s:GridColumn>
          <s:GridColumn dataField="mydate" headerText="Date"></s:GridColumn>
         </s:ArrayList>
        </s:columns>
      </s:DataGrid>
      </s:Group>
      Here is the code to generate the database:
      CREATE DATABASE mytest;
      CREATE TABLE myTestDB
            myid INT UNSIGNED NOT NULL AUTO_INCREMENT,
            mystring CHAR(15) NOT NULL,
            myinteger INT NOT NULL,
            myreal DECIMAL(6,2) NOT NULL,
            mydate DATE NOT NULL,
            PRIMARY KEY(myid)
      ) ENGINE = InnoDB;
      INSERT INTO myTestDB (mystring, myinteger, myreal, mydate) VALUES ('Test', 123, 45.67, '2012-01-01'), ('Practice', 890, 12.34, '2012-02-01'), ('Assay', 567, 78.90, '2011-10-01'), ('Trial', 111, 22.22, '2009-09-09'), ('Experiment', 333, 44.44, '1999-04-15'), ('Challenge', 555, 66.66, '2012-12-21');
      And finally here is the PHP script.
      <?php
      class myVOorDTO
        var $_explicitType = "valueObjects.myVOorDTO";
        public $myid;
        public $mystring;
        public $myinteger;
        public $myreal;
        public $mydate;
        public function __construct()
          $this->myid = 0;
          $this->mystring = "";
          $this->myinteger = 0;
          $this->myreal = 0.0;
          $this->mydate = date("c");
      class MytestdbService
        var $username = "yourusername";
        var $password = "yourpassword";
        var $server = "yourserver";
        var $port = "yourport";
        var $databasename = "mytest";
        var $tablename = "mytestdb";
        var $connection;
          $this->connection = mysqli_connect(
          $this->server, $this->username, $this->password, $this->databasename, $this->port);
      * Returns all the rows from the table.
      * @return myVOorDTO
        public function getAllMytestdb()
          $query = "SELECT * from $this->tablename";
          $result = mysqli_query($this->connection, $query);
          $results = array();
          while ($obj = mysqli_fetch_assoc($result))
            $row = new myVOorDTO();
            $row->myid = $obj['myid'] + 0;
            $row->mystring = $obj['mystring'];
            $row->myinteger = $obj['myinteger'] + 0;
            $row->myreal = $obj['myreal'] + 0.0;
            $row->mydate = new Datetime($obj['mydate']);
            array_push($results, $row);
          return $results;
      My understanding as to what is going on is: (1) on creation complete the application launch the initialise() function of the controller (2) this function starts the remoteObject which get the data (3) once the results arrive the resultHandler store the data into the ArrayCollection of the model ***this does not work*** (4) even if part 3 did not work, the setter of the ArrayCollection in the model send an event that it has been changed (5) the controller receive this event and assigns the ArrayCollection of the model as the dataprovider for the datagrid in the compoent.
      Of course, since the ArrayCollection is null, the application gives an error as the dataProvider for the datagrid is null.
      What is missing in this application to make it work properly? I believe this is an example that could help a lot of people.
      Even if I change the setter in the model to _myArrayCol = ObjectUtil.copy(value) as ArrayCollection; it still does not work.
      Also, it seems that the remoteObject does not return a typed object (i.e. myVOorDTO) but rather generic objects. I am usually able to make this works but in this particular application I have not managed to do it. Again what's missing?
      Thanks for any help with this!
