6 Replies Latest reply on Feb 24, 2012 3:12 PM by RGB2CMYK2
    InDesign CS5.5 missing objects when export to PDF
    RGB2CMYK2 Level 1
      I have a solid black block as header on a spread in the master page as below so I assume that the entire block should be shown when exporting to single sheet PDF.
      But the weird thing is when I "print the booklet" everything looks fine in each spread as above but when I export to single page pdf, witch are not showing in exported pdf. Not all of them, only one page.
      What I did to that page 10 is I "override all master page items" but I put the black and blue blocks back manually to the page 10 so it doesn't have any problems when I print them in spread. Nothing ontop or transparent at all.
      Also I missed the page numbers on page 1 and 2 but I didn't do anything to these two pages. The 3rd page has the correct page number "3". And again, it only happens when I export to single page PDF but not in the spread. The page numbers are on the master page. So does anybody know why it's like that?
      Thanks a lot!
