29 Replies Latest reply on Mar 7, 2012 2:50 AM by SteveG(AudioMasters)
    question about buses
    therealdobro Helper
      I'm using parallel compression these days, and I've got some questions about different ways of doing it in Audition.
      * The first way is to clone the vocal (for instance) to a second clip on a second track and compress the hell out of it and adjust levels to taste.  It works fine, but there are two disadvantages.  First, if I want it EQ'ed the same way as the main vocal track, I have to run another parametric on the second track and that draws on computer resources.  Another disadvantage is that if I adjust the level of the main vocal, I also have to then tweak the level of the compressed track.  It would be nice if I could somehow lock the levels of the two tracks so that if I adjusted one, the other automatically followed suit.  Is that doable in Audition?  I think not, right?
      * The second way is to send the vocal track to a bus and compress the hell out of it.  The problem here is that if I turn down the level of the vocal track, there's less compression happening on the bus, so it changes the sound.  To keep the same amount of gnarly compression on the bus sound, I'd have to tweak the threshold.
      Okay, is there a way to do what I want to do that I haven't thought of?  I want to be able to adjust the level of the vocal and have the same relative amount of compression on the parallel track/effect.
        • 1. Re: question about buses
          Bob Howes Rockstar
          Try using an Aux send to the bus and make it pre fade.  This will stop fader changes on the main track affecting what is sent to the bus.
          • 2. Re: question about buses
            ryclark Rockstar
            Or you could use a second bus for the direct signal and mix the compressed/uncompressed using the bus faders.
            P.S. I couldn't find the Pre/Post switch on the Send channel until I expanded the Track header a bit.
            Message was edited by: ryclark
            • 3. Re: question about buses
              therealdobro Helper
              Bob, I'm going to try this one first, because I understand it clearly.   Thanks.  (This'll be the first time I've tried anything pre-fader.)
              • 4. Re: question about buses
                therealdobro Helper
                Thanks, ryclark.  I'll try this one when I figure it out lol.  Are you expanding on Bob's idea, or is it a completely different approach?
                • 5. Re: question about buses
                  ryclark Rockstar
                  It's a different approach which might have some advantage since it gives you overall control of your track level with the channel fader but allows you to balance the relative levels of the parallel paths using the bus faders.
                  • 6. Re: question about buses
                    therealdobro Helper
                    Hey Bob, that pre-fader send idea works fine, of course.  Thanks.  (The one advantage to doing it the cumbersome way I was doing it before - cloning the clip to a separate track and applying the compression to that second track - is that I can EQ it independently of the original clip or apply other effects.)  But now I've got more options.  Nice.
                    I still haven't figured out ryclark's idea, though.
                    • 7. Re: question about buses
                      therealdobro Helper
                      Okay, here's an issue.  (I'm working in Audition 3, right now, so I'll have to try this out in 5.5 later to see if the same thing is happening.)  After I rigged a pre-fader send on the bass track to a bus with a compressor on it, the bass track is audible when I'm soloing other tracks.  This shouldn't be happening, right?  I tried the same thing in another session in Audition 3 and got the same results.  The only way I can hear just the solo'ed track is if I click the send power switch on the bass track.  This shouldn't be happening, right?
                      • 8. Re: question about buses
                        SteveG(AudioMasters) Ninja
                        Why not? If you send a pre-fader signal to another buss, and the mute is applied at the fader stage for that signal channel, as per normal, then if the bus isn't muted, any signal sent to it from anywhere will still be audible - unless you mute the bus you sent it to as well. Sounds to me like you don't have much experience of real mixers...
                        Just to make it a bit easier for you, have a look at the channel block in this Roland mixer which should make it a little clearer. This is an absolutely standard layout from a monitoring point of view.
                        • 9. Re: question about buses
                          ryclark Rockstar
                          Steve your link seems to have gained itself an extra "http://" at the end. So it doesn't work unless you remove it.
                          • 10. Re: question about buses
                            therealdobro Helper
                            1 I've mixed in the box my whole mixing life.
                            2  I always thought that when you solo'ed a track, that it automatically muted everything else.  In this case...no.
                            • 11. Re: question about buses
                              Bob Howes Rockstar
                              As you've discovered, pre fade auxes also tend to be "pre the on off switch" as modelled after hardware mixers.  For many/most applications this is desireable.
                              For example, a main use of pre fade auxes in live work is to feed on stage monitors.  Often you don't want these to lose sound even if you solo a different channel in your headphones to check a mic problem or something .  In situations where you MUST silence whatever the pre fade aux is feeding, you just have to mute the output--for example, on a show I recently did, there was a fade to silence I had to perform live and it was necessary to fade the monitors on stage too or the audience would still hear music from there even if the FOH was silence...I just pulled down the monitor output at the same time I was fading the FOH.
                              • 12. Re: question about buses
                                Yeah, my bad editing - sorry. But absolute shame on Adobe for making it so damned difficult to do this at all. Why can't they simply have two boxes in the 'insert link' field, one for the link and another for a sensible name for it?????????????
                                • 13. Re: question about buses
                                  Er, no. There are two basic soloing models, and in Audition you can choose the one you want to use in preferences. The original default model (which is crap) says that every time you hit a solo button, you hear that channel, but if you hit another solo button it doesn't cancel that, but adds the second one to the solo feed. This used to happen on cheap mixers where the solo buttons weren't physically linked and they didn't use an electronic sub-control system. In practice, not actually a lot of use.
                                  After a lot of complaining (most of it from me, I think) the other 'professional' model was adopted. In this one, 'solo' does exactly what it says on the tin - it solos whatever you hit, and that's all. This is the equivalent of hitting every appropriate mute button on every other channel. And if you change what you solo, it cancels the previous solo setting - which as far as I'm concerned is exactly what should happen.
                                  After struggling with all of this for a long time, Audition's mixers now pretty much conform to what a real mixer does. Which, as far as I'm concerned, is as it should be.
                                  • 14. Re: question about buses
                                    Bob Howes Rockstar
                                    Aw, c'mon Steve....you don't think Adobe could provide features available in pretty much every other modern piece of forum software, do you?
                                    • 15. Re: question about buses
                                      If the product developers behaved the same way that the website developers do, Adobe wouldn't exist.
                                      • 16. Re: question about buses
                                        ryclark Rockstar
                                        Another Muting scenario that was a necessity on hardware mixers was that if you muted one channel amongst several that had reverb applied via a common bus you would want the reverb tail to continue for the muted channel rather than be cut dead. Therefore bus muting is usually kept independant from Solo or Channel Mute.
                                        Then on larger hardware mixers you would often have PFL (PreFade Listen) and Solo In Place options available to you. Audition's Solo is now more equivalent to the Solo in Place option.
                                        This may help:
                                        http://www.thedawstudio.com/Tips/Solo-Button.html
                                        • 17. Re: question about buses
                                          therealdobro Helper
                                          Ah, okay then - thanks.  One reason I solo stuff is for quick A/B checks while I'm mixing, so that would mean hitting 'solo' and then hitting 'mute' on the bus track, which is really inconvenient.
                                          So, does ryclark's idea above about bussing involve a prefade aux as well?  (If so, I'm just going to continue using the 'cloned clip' method I'm using at present for parallel compression.)
                                          • 18. Re: question about buses
                                            therealdobro Helper
                                            This may help:
                                            Yeah - helpful link - thanks.  There's some other useful stuff on that site.  Simple bass trap construction that diffuses as well as absorbs, for example, and which looks quite attractive as well.  Thanks.
                                            • 19. Re: question about buses
                                              therealdobro Helper
                                              Last night when I was here, I got the popup inviting me to comment on the site.  I'm a lot happier with the mechanics of this forum than I was before, so I gave it a passing grade generally, but what was interesting was that it was the people (helpful users *and* developers who post here) which got the top grades from me.  It's the people that make this forum, not the less-clunky-than-before-but-still-clunky forumware.
                                              • 20. Re: question about buses
                                                therealdobro Helper
                                                Okay, I found it in preferences - it's called 'exclusive' and 'non-exclusive' solo.  Actually, I got really used to being able to hit solo on one track and then hit solo on another track so that I could hear just those two tracks.  (If I wanted to solo *only* a different track, then Ctrl>solo accomplished that.)  So, I like the option of being able to choose which solo mode Audition operates in.  So...ahem...what about the option for a similar choice regarding pre-fade soloing, whereby you could select pre-fade solo with or without busses being muted?  I know, I know...this isn't the way a real mixing board works.  But why not build options into the software that allow the user to have Audition act like a real mixing board, or as a virtual mixing board with other capacities?  If you can make it do exactly what you want it to do, that's a good thing, right?
                                                • 21. Re: question about buses
                                                  No it's not a good thing at all. The whole point is that people used to real desks can transition easily between them and Audition without having a whole load of hassle.
                                                  So, if you wanted to add a Solo-safe option, that would be fine, because they exist on real desks - but you'd want it to remain working the way everybody thinks it does, otherwise instant confusion could result. What you wouldn't want to do is put options onto solo or mute buttons that didn't exist in the real world - very simple, and plain common sense really.
                                                  • 22. Re: question about buses
                                                    therealdobro Helper
                                                    Okay, I thought you'd say that.  But (and there are two 'buts' to this) software mixing *is* my real world, so if I have an option to do something the way I want, then that's good.  For me at least.  And here's the second 'but': if Audition's default setting mimic traditional mixing desks, where's the harm in offering alternatives that extend the range of the software's capabilities?
                                                    • 23. Re: question about buses
                                                      Fortunately, if just one person wants to do something strange and non-standard, it doesn't matter very much. If you don't get loads of other people clamouring for the same thing, it'is because in the real real world, it isn't a lot of use. And adding a load of strange facilities just because it's possible to do them leaves the options settings cluttered up with a load of stuff that could potentially confuse users - quite unnecessarily.
                                                      Already explained that. But I'd add that pro users aren't going to be particularly impressed with a load of strange facilities that nobody's found the need for before either. What we want is software that does what's required without being cluttered up with extraneous junk, and is accordingly easy to use. Adding functions which say more about a users' inabilty to construct a mix adequately than adding anything of practical value isn't the way to go, especially when there's still a backlog of more useful functions to add...
                                                      • 24. Re: question about buses
                                                        therealdobro Helper
                                                        From my vantage point, your strongest argument is the last one about how spending development time on a small issue takes valuable time away from other stuff.  Also, I'm less sure that you're speaking for all pro users and what they would think about new functionality in Audition.  I read reviews of software plugins in SOS magazine for instance, where the (pro) reviewer praises a plugin for successfully emulating a well-know piece of hardware and also for going beyond the capacity of the hardware and adding new and useful functionality that the original didn't have.  And finally, I personally would find a solo button that actually solo'ed the track I wanted to hear, independently of any buses other than the one(s) for that track, useful.  Sure, I care that you think I don't know what I'm doing, but also I care that the software doesn't do what I want it to.
                                                        • 25. Re: question about buses
                                                          Bob Howes Rockstar
                                                          Well, the prioritisation of the developers time is certainly a major issue from what I know.
                                                          However, there's a fine line between building in flexibility to suit a range of users and building in a level of complexity that might become confusing to people who expect things to function in a certain way.
                                                          In this case, I wouldn't worry about a mute button not killing a pre fade aux send because that's simply the way I expect it to work.  If it DID mute a pre fade aux, I might have a few moments of head scratching until I remembered an option tucked somewhere on a menu.  However, if I really need to hear just the original track soloed I can always mute the bus I'm feeding with the aux send anyway.
                                                          • 26. Re: question about buses
                                                            Okay, show me a single example anywhere of a software reviewer saying that about a software-based mixer... and Bob's POV is quite correct.
                                                            • 27. Re: question about buses
                                                              therealdobro Helper
                                                              * Yeah, I realize that.  It means a click on the solo button, and then a scroll down the screen to the bus which I then have to mute with another click.  It'd be easier with one click, naturally.  Small stuff, I guess.
                                                              * I'm surprised at the fact that the solo button doesn't in fact solo the track absolutely and independent of everything else, though.  It seems like a really sensible thing for a solo button to do.  That's why I've pursued this thread and run the risk of looking like a dweeb.
                                                              * The 'few moments of head scratching' that you mentioned wouldn't happen at all if Audition's default settings acted like a metal mixer, and if the options/alternatives I've suggested had to be invoked in the Preferences menu.
                                                              • 28. Re: question about buses
        therealdobro Helper
        I've never seen an example of that, Steve.  Only software plugins.  But if I ever come across anything like that, I promise to resurrect this thread with a link or quote.
        • 29. Re: question about buses
        The reason that you find additions made to plugins is that there's no operating standard for them in the first place - they are all conceptually different. But I'm reasonably confident that my POV on what you add or don't add to mixers is also the one that the rest of the world adopts - simply because there are commonly accepted standards, and it's common sense to stick to them.
