0 Replies Latest reply on Feb 25, 2012 8:20 AM by Ankit Tanna
    Flash Builder Application, WAMP Server, PHP Service Problem
    Ankit Tanna Level 1
      Hye there,
      I am Ankit Tanna and I am a developer and a designer.
      I am currently facing problems with the database connectivities of the Flash Builder form with the WAMP server.
      I am using Flash Builder 4.5 along with the Zend AMF framework to connect the php services to the WAMP server database.
      The thing goes like this, I am unable to use generate the sample service from the WAMP database since my Flash Buider 4.5 is crashing again and again. Hence I decided to write my own php service file for the database connectivity.
      The details of the WAMP server database goes like this:
      - username: root
      - password: blank
      - hostname: localhost
      - port number: 80
      - database name: rmxuserdb
      - table name: users
      I have built a form with a few fields which is as shown in the figure:
      I am using this service code for connecting to the database:
      class UserService {
          var $username = "root";
          var $password = "root";
          var $server = "localhost";
          var $port = "3306";
          var $databasename = "employees";
          var $tablename = "employees";
          var $connection;
           * The constructor initializes the connection to database. Everytime a request is
           * received by Zend AMF, an instance of the service class is created and then the
           * requested method is invoked.
      public function _construct() {
      $this->connection = mysqli_connect(
      $this->server,
      $this->username,
      $this->password,
      $this->databasename,
      $this->port
      $this->throwExceptionOnError($this->connection);
      public function createUser($item) {
      $stmt = mysqli_prepare($this->connection, "INSERT INTO $this->tablename (fname, lname, email, username, password, dob, address, city, state, zip, country, mobile, url) VALUES (?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?, ?)");
      $this->throwExceptionOnError();
      mysqli_bind_param($stmt, 'isssss', $item->fname, $item->lname, $item->email, $item->username, $item->password, $item->dob, $item->address, $item->city, $item->state, $item->zip, $item->country, $item->mobile, $item->url);
      mysqli_stmt_execute($stmt);
      $this->throwExceptionOnError);
      $autoid = mysqli_stmt_insert_id($stmt);
      mysqli_stmt_free_result($stmt);
      mysqli_close($this->connection);
      return $autoid;
      Upon refreshing the service I get the following error:
      I am not sure where to place this services file in which folder.
      Please guide me through this.
      Thank you.
      Ankit Tanna.
