1 Reply Latest reply on Feb 25, 2012 9:30 AM by the_wine_snob
    Premier Elements 9 No Export option
      I bought Premier Elements 9 shortly before 10 was released and ever since I bought it I have been able to create and edit projects, but not export them. The export option in the File menu is grey and unselectable. What do I need to do to be able to export?
        • 1. Re: Premier Elements 9 No Export option
          the_wine_snob Level 9
          Welcome to the forum.
          All "export" operations for outputting AV files from the Timeline, have been moved to the Share Tab. There, you will find just what you are looking for.
          The Export setting from the Toolbar is basically now only for Saving a Title as a Template. Seems that there is one more similar operation from there, but for AV file output, just look on the Share Tab. Also note: the options Panel has a scroll bar on the right, so if you do not see what you want initially, use that scroll bar to expose more options.
