5 Replies Latest reply on Mar 3, 2012 2:04 AM by hibou38
    deletePublishedCollection : No info.photoIds
    hibou38
      Hello,
      I'm trying to use deletePublishedCollection function.
      However i don't retrieve  info.photoIds . I have always nil in this element of info structure.
      I did'nt retrieve in the documentation that this element of structure exist. But all examples are using it ???
      I don't understand.
      Do I do initialize something when I did the export as i did it to retrieve info.remoteId ?
      some help will be pleasant
      The code I copyed from sample (ZenPhoto/Flicker) isbelow  (I reduced in maximum the function and delte all test. But I never go inside the 'for' loop)
      function publishServiceProvider.deletePublishedCollection( publishSettings, info )
      import 'LrFunctionContext'.callWithContext( 'publishServiceProvider.deletePublishedCollection', function( context )
              local progressScope = LrDialogs.showModalProgressDialog {
                                  title = LOC( "$$$/Chouette38/DeletingCollectionAndContents=Deleting photoset ^[^1^]", info.name ),
                                  functionContext = context }
                  for i, photoId in ipairs( info.photoIds ) do
                      Chouette38API.deletePhoto( publishSettings, { photoId = photoId } )
                  end
              end )
      end
        • 1. Re: deletePublishedCollection : No info.photoIds
          DawMatt Level 3
          If you look at the documentation for the deletePublishedCollection() callback you are using, the info table does not contain a photoIds field.
          To get the list of images you are looking for I think you will need to use something like:
               info.publishedCollection:getPhotos()
          or
               info.publishedCollection:getPublishedPhotos()
          Matt
          • 2. Re: deletePublishedCollection : No info.photoIds
            hibou38 Level 1
            I undestand but two things:
            1) It was similar to the samples provided inside the SDK (Flickr sample)
                                        title = LOC( "$$$/Flickr/DeletingCollectionAndContents=Deleting photoset ^[^1^]", info.name ),
                        if info and info.photoIds then
                                        if progressScope:isCanceled() then break end
                                        progressScope:setPortionComplete( i - 1, #info.photoIds )
                            FlickrAPI.deletePhoto( publishSettings, { photoId = photoId } )
                                    end
                            end
                        if info and info.remoteId then
                            FlickrAPI.deletePhotoset( publishSettings, {
                                            photosetId = info.remoteId,
                                            suppressError = true,
                                                -- Flickr has probably already deleted the photoset
                                                -- when the last photo was deleted.
                        end
                            end )
            end
            2)With LrPhoto object I don't know how to retrieve the remoteID of the phototo  be deleted.
            JM
            • 3. Re: deletePublishedCollection : No info.photoIds
              johnrellis Most Valuable Participant
              info.publishedCollection:getPublishedPhotos() returns an array of LrPublishedPhoto.  publishedPhoto:getRemoteId() returns the remote id.
              • 4. Re: deletePublishedCollection : No info.photoIds
                DawMatt Level 3
                John has answered question 2. As to question 1, that looks like an error in
                the sample code. Hopefully it will be fixed soon.
                Thanks, Matt
                (Apologies for the brevity - sent from my Android)
                • 5. Re: deletePublishedCollection : No info.photoIds
                  hibou38 Level 1
                  Thank you for your answers.
                  Of course it works !
                  Merci beaucoup
                  JM
