1. Re: Slicing an image
Noel Carboni Feb 26, 2012 11:00 AM (in response to ericgraig)Have you looked into Photoshop's Slice feature? Generally speaking, it's oriented toward web publishing, where a web page is comprised of multiple parts that make up a whole, and you would use Save For Web & Devices to save the document as multiple images, each of which contains a part of the whole. Not sure if this matches up to what you're wanting to do.
Another approach might be to select portions of your image, then use Cut/Paste to put those parts on different layers.
-Noel
2. Re: Slicing an image
Mylenium Feb 26, 2012 6:39 PM (in response to ericgraig)Depends on what you specifically have in mind. Tiled printing can be easily done from a PDF and/ or set up accordingly in ID. Just the same, if you plan additional layout work in ID or Quark, then there's no need to bother at all to slice the files - placing the same single image and positioning it differently inside multiple frames is a basic workflow and I'm sure with some automation/ a script in ID you could do this 500 times a day without ever having to do it manually....
Mylenium
3. Re: Slicing an image
ericgraig Feb 28, 2012 8:40 AM (in response to Mylenium)I don't think slicing will work for a variety of reasons not the least of which it doesn't seem to allow one to specify the sizes of each slice.I sort of see what you're saying with placing the same image in different image frames and repositioning it within the frames but that's pretty much a manual process unless you're writing a script. SOmething FAR outside of my capabilities. Here is the starting image:
Here is what I want to end with EXCEPT I want very small slices and more than that, I want to slice both vertically (as shown) and horizontally.
This was done quickly with the selection tool. The second image is comprised of four layers, one for each slice and one for the background. I will be buying either Quark or ID in the next couple of days so I can do this in either of those if that would be best.
Eric
4. Re: Slicing an image
Noel Carboni Feb 28, 2012 8:52 AM (in response to ericgraig)What's your intent with the pieces? Are you going to be printing them separately?
-Noel
5. Re: Slicing an image
ericgraig Feb 28, 2012 8:57 AM (in response to Noel Carboni)No. I want them all on a single sheet.
6. Re: Slicing an image
Noel Carboni Feb 28, 2012 9:06 AM (in response to ericgraig)Can you not just draw white rectangles over them, much as you've done above? I'm just not seeing the problem.
-Noel
7. Re: Slicing an image
ericgraig Feb 28, 2012 9:24 AM (in response to Noel Carboni)I can't for two reasons: First, to draw over them would be to obscure part of the image. Second, all these rectangles need to be prscisely positioned and there will be a ton of them. For a 16 X 16 inche image divided into 1/2 inch squares there will be 1024 individual squares.
8. Re: Slicing an image
Paul Riggott Feb 28, 2012 9:49 AM (in response to ericgraig)You can do this with a script ...
#target photoshop function main(){ var dlg= "dialog{text:'Script Interface',bounds:[100,100,380,290],"+ "panel0:Panel{bounds:[10,10,270,180] , text:'' ,properties:{borderStyle:'etched',su1PanelCoordinates:true},"+ "title:StaticText{bounds:[60,10,220,40] , text:'Tile Picture' ,properties:{scrolling:undefined,multiline:undefined}},"+ "panel1:Panel{bounds:[10,40,250,130] , text:'' ,properties:{borderStyle:'etched',su1PanelCoordinates:true},"+ "statictext1:StaticText{bounds:[10,10,111,30] , text:'Accross' ,properties:{scrolling:undefined,multiline:undefined}},"+ "statictext2:StaticText{bounds:[140,10,230,27] , text:'Down' ,properties:{scrolling:undefined,multiline:undefined}},"+ "across:DropDownList{bounds:[10,30,100,50]},"+ "down:DropDownList{bounds:[140,30,230,50]}},"+ "button0:Button{bounds:[10,140,110,160] , text:'Ok' },"+ "button1:Button{bounds:[150,140,250,160] , text:'Cancel' }}};" var win = new Window(dlg,'Tile Picture'); if(version.substr(0,version.indexOf('.'))>9){ win.panel0.title.graphics.font = ScriptUI.newFont("Arial","BOLD",20); g = win.graphics; var myBrush = g.newBrush(g.BrushType.SOLID_COLOR, [1.00, 1.00, 1.00, 1]); g.backgroundColor = myBrush; var myPen =g.newPen (g.PenType.SOLID_COLOR, [1.00, 0.00, 0.00, 1],lineWidth=1); } win.center(); for(var i=1;i<41;i++){ win.panel0.panel1.across.add ('item', i); win.panel0.panel1.down.add ('item', i); } win.panel0.panel1.across.selection=0; win.panel0.panel1.down.selection=0; var done = false; while (!done) { var x = win.show(); if (x == 0 || x == 2) { win.canceled = true; done = true; } else if (x == 1) { done = true; { if(!documents.length)return; var startRulerUnits = preferences.rulerUnits; preferences.rulerUnits = Units.PIXELS; doc = app.activeDocument; app.displayDialogs = DialogModes.NO; var tilesAcross = parseInt(win.panel0.panel1.across.selection.index)+1; var tilesDown =parseInt(win.panel0.panel1.down.selection.index)+1; var tileWidth = parseInt(doc.width/tilesAcross); var tileHeight = parseInt(doc.height/tilesDown); ProcessFiles(tilesDown,tilesAcross,tileWidth,tileHeight); app.preferences.rulerUnits = startRulerUnits; } } } } main(); function ProcessFiles(Down,Across,offsetX,offsetY){ activeDocument.flatten(); TLX = 0; TLY = 0; TRX = offsetX; TRY = 0; BRX = offsetX; BRY = offsetY; BLX = 0; BLY = offsetY; for(var a = 0; a < Down; a++){ for(var i = 0;i <Across; i++){ doc.activeLayer = doc.artLayers.getByName("Background"); doc.selection.select([[TLX,TLY],[TRX,TRY],[BRX,BRY],[BLX,BLY]], SelectionType.REPLACE, 0, false); executeAction(charIDToTypeID( "CpTL" ), undefined, DialogModes.NO ); doc.selection.deselect(); doc.activeLayer = doc.artLayers.getByName("Background"); TLX = offsetX * (i+1) ; TRX = TLX + offsetX; BRX = TRX; BLX = TLX; } TLX = 0; TLY = offsetY * (a +1); TRX = offsetX; TRY = offsetY * (a +1); BRX = offsetX; BRY = TRY + offsetY; BLX = 0; BLY = (offsetY * (a +1)+offsetY); } } -
9. Re: Slicing an image
ericgraig Feb 28, 2012 10:25 AM (in response to Paul Riggott)Well that is incredibly cool. Not only that, I actually got it to run. Now, one last question... how can each of the layers this creates be saved as a separate file (in order to enable me to lay them out as I need to in ID or Quark)?
Eric
10. Re: Slicing an image
Paul Riggott Feb 28, 2012 10:37 AM (in response to ericgraig)You can use File - Scripts - Export Layers to Files
or my own...
11. Re: Slicing an image
ericgraig Feb 28, 2012 10:47 AM (in response to Paul Riggott)Again, incredible. I'm going to try your script. I like the idea of being able to number the files according to my needs. Thanks again!
Eric
