1 Reply Latest reply on Dec 5, 2012 5:15 PM by roymeo_
    Application updater stopped working in Air 3 (solved)
      I have an html/js app that uses applicationupdater_ui.swf to update to new versions. Everything works great in 1.0 & 2.0 versions of Air, but when I upgrade to 3.0+, the updater does not fire. Anyone else experiencing this?
      Here's the code in the app, but I don't suspect this is the problem since it has worked for a long time prior to v3.
      function Application() {
      Application.prototype = {
         initializeUpdater: function() {
                   var appUpdater = this.appUpdater = new runtime.air.update.ApplicationUpdaterUI();
                  appUpdater.updateURL = updateURL;
                  appUpdater.isCheckForUpdateVisible = true;
                  appUpdater.isDownloadUpdateVisible = true;
                  appUpdater.isDownloadProgressVisible = true;
                  appUpdater.isInstallUpdateVisible = true;
                  appUpdater.addEventListener( runtime.flash.events.ErrorEvent.ERROR, function(ev){ alert('there was an error ') } );
         checkForUpdates: function(){
      var application = new Application();
      I solved the problem. I had to delay the checkForUpdates() function for 2 seconds. Now it works.
