18 Replies Latest reply on Jun 29, 2011 10:31 PM by sunny.adigarla
    how to show submenu in a menubar on mouseover
    Madhav Subedi Level 4
      i am using a menubar component. i want to display my submenu items on mouseover, not on a click as flex does. please somebody suggest me.
        • 1. Re: how to show submenu in a menubar on mouseover
          laurent_pinson Level 1
          You can simulate a click on a mouseOver event:
          import flash.events.mouseEvents;
          myMenuBar.addEventListener(MouseEvent.MOUSE_OVER,fakeMouseClick);
          private function fakeMouseClick(event:MouseEvent):void {
          var clickEvent:MouseEvent = new MouseEvent(MouseEvent.CLICK, true, false, event.localX, event.localY);
          dispatchEvent(clickEvent);
          source & example from Doug MacCune:
          http://dougmccune.com/blog/2007/09/22/nifty-flex-accordion-menu-like-on-applecom/
          Laurent
          • 2. Re: how to show submenu in a menubar on mouseover
            i tried with the code given by laurent pinson.
            it dispatches the click event(i got it by adding a evnet listener for mouse click.)
            but it doesnot show the submenus.
            • 3. Re: how to show submenu in a menubar on mouseover
              Shelady Level 1
              Try this.
              <mx:Application xmlns:mx=" http://www.adobe.com/2006/mxml" layout="vertical"
              backgroundColor="#eeeeee">
              <mx:Style>
              Label {
              fontSize:18;
              </mx:Style>
              <mx:Script>
              <![CDATA[
              import mx.events.MenuEvent;
              import mx.core.Container;
              private function menuClickHandler(event:MenuEvent):void
              var viewString:String = event.item.@view;
              vStack.selectedChild=this[viewString];
              </mx:Script>
              <mx:XMLList id="menuData">
              <menu label="View">
              <menu label="Courses" view="viewCourses"/>
              <menu label="Instructors" view="viewInstructors"/>
              <menu label="Schedule" view="viewSchedule"/>
              </menu>
              </mx:XMLList>
              <mx:MenuBar dataProvider="{menuData}"
              labelField="@label"
              itemClick="menuClickHandler(event)"/>
              <mx:ViewStack id="vStack"
              height="300" width="400">
              <mx:VBox id="viewCourses"
              height="100%" width="100%"
              <mx:Label text="This is the Courses View"/>
              </mx:VBox>
              <mx:VBox id="viewInstructors"
              backgroundColor="#dddddd">
              <mx:Label text="This is the Instructors View"/>
              </mx:VBox>
              <mx:VBox id="viewSchedule"
              backgroundColor="#cccccc">
              <mx:Label text="This is the Schedule View"/>
              </mx:VBox>
              </mx:ViewStack>
              </mx:Application>
              • 4. Re: how to show submenu in a menubar on mouseover
                but this code( shelady) also requires clicking to display the submenu.
                • 5. Re: how to show submenu in a menubar on mouseover
                  dispatching a event works.
                  but we should dispatch a new mouse_down event on item_roll_over event.
                  now the another problem is to hide the submenu on mouse out.
                  • 6. Re: how to show submenu in a menubar on mouseover
                    noworkdone Level 1
                    Hi There i have tried the code below but the submenu still doest not show
                    • 7. Re: how to show submenu in a menubar on mouseover
                      quote:
                      public class MenuBarExt extends MenuBar
                      public function MenuBarExt()
                      super();
                      addEventListener(MenuEvent.ITEM_ROLL_OVER, fakeclick);
                      private function fakeclick(event:MenuEvent):void
                      var evt:MouseEvent = new MouseEvent(MouseEvent.MOUSE_DOWN, true, false);
                      //dispatchEvent(evt);
                      //at this point you need some changes.
                      //you need to find the menuitem clicked and dispatch the event with that item, not the whole menu.
                      • 8. Re: how to show submenu in a menubar on mouseover
                        dimival Level 1
                        Try this:
                        <mx:MenuBar id="mb" creationComplete="mb.addEventListener('mouseOver', rollOver, true)"/>
                        private function rollOver(event:MouseEvent):void
                        if (event.target is IMenuBarItemRenderer && mb.selectedIndex == -1)
                        var index:int = IMenuBarItemRenderer(event.target).menuBarItemIndex;
                        mb.selectedIndex = (index == 0) ? 1 : 0;
                        This worked for me
                        • 9. Re: how to show submenu in a menubar on mouseover
                          Actually i have solved how to DISPLAY the submenu on mouse over.
                          Now my problem is to HIDE the submenu on mouse out.
                          • 10. Re: how to show submenu in a menubar on mouseover
                            dimival Level 1
                            I see, i tried to do that too but i couldn't find a way. If you manage to solve it let us know.
                            • 11. Re: how to show submenu in a menubar on mouseover
                              MayLam18 Level 1
                              Can you please post your code so that I can use? Thanks.
                              May
                              • 12. Re: how to show submenu in a menubar on mouseover
                                public function MenuCom():void
                                this.showRoot = false;
                                this.addEventListener(MenuEvent.ITEM_ROLL_OVER,_fakeMouseClick);
                                private function _fakeMouseClick(event:MenuEvent):void
                                var clickEvent:MouseEvent = new MouseEvent(MouseEvent.MOUSE_DOWN, true, false, mouseX, mouseY);
                                var x:XML = this.dataProvider[0] as XML;
                                for(var i:int = 0; i < this.menuBarItems.length; i++)
                                if( event.item == x.menuitem )
                                this.menuBarItems
                                .dispatchEvent(clickEvent);
                                here is the xml:
                                <menu>
                                <menuitem label="addd" data="1">
                                <menuitem1 id="11" label="aaa"></menuitem1>
                                </menuitem>
                                <menuitem label="b" data="2">
                                <menuitem1 id="21" label="bbb"></menuitem1>
                                </menuitem>
                                <menuitem label="c" data="3">
                                <menuitem1 id="34" label="ccc"></menuitem1>
                                </menuitem>
                                <menuitem label="d" data="4">
                                <menuitem1 id="31" label="ddd1">
                                <menuitem1 id="311" label="ddd11"></menuitem1>
                                <menuitem1 id="312" label="ddd12"></menuitem1>
                                </menuitem1>
                                <menuitem1 id="32" label="ddd2"></menuitem1>
                                <menuitem1 id="33" label="ddd3"></menuitem1>
                                </menuitem>
                                </menu>
                                • 13. Re: how to show submenu in a menubar on mouseover
                                  rdoyle720 Level 1
                                  Any resolution to this? I've been trying to dispatch a click event from the Stage, but am having no luck.
                                  • 14. Re: how to show submenu in a menubar on mouseover
                                    not really..
                                    i had started a custom menu component in my free time, i didnot get any resolution on it so i left it.
                                    • 15. Re: how to show submenu in a menubar on mouseover
                                      Prestine Level 1
                                      Hello,
                                      Does anyone has solved the problem of showing the submenu on rollover and hiding it on rollout.
                                      I was able to show and hide submenu , but  I am not able to click the submenu,as you will see from my example.
                                      Here is my code: You can run it directly at your place.
                                      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical" >
                                         <mx:Script>
                                             <![CDATA[
                                                 import mx.controls.Alert;
                                                 import mx.controls.Menu;
                                                 private function showSubMenu(event:MenuEvent):void{
                                                     var menu:Menu = myMenuBar.getMenuAt(event.index);
                                                     if(event.index == 0){
                                                         menu.x    =    myMenuBar.x + 10;
                                                         menu.y  =   myMenuBar.y + myMenuBar.height;
                                                           menu.show();
                                                     }else if(event.index == 2){
                                                         menu.x    =    myMenuBar.x + 197;
                                                         menu.show();
                                                 private function hideSubMenu(event:MenuEvent):void{
                                                     menu.hide();
                                         </mx:Script>
                                          <mx:MenuBar id="myMenuBar" labelField="@label"
                                                      itemRollOver="showSubMenu(event)" itemRollOut="hideSubMenu(event)">
                                              <mx:XMLList>
                                                  <menuitem label="MenuItem A">
                                                      <menuitem label="SubMenuItem A-1" enabled="false"/>
                                                      <menuitem label="SubMenuItem A-2"/>
                                                  </menuitem>
                                                  <menuitem label="MenuItem B"/>
                                                  <menuitem label="MenuItem C">
                                                      <menuitem label="SubMenuItem C-1"
                                                          type="radio" groupName="one"/>
                                                      <menuitem label="SubMenuItem C-2"
                                                          selected="true"/>
                                                      <menuitem label="SubMenuItem C-3"
                                                  </menuitem>
                                              </mx:XMLList>
                                          </mx:MenuBar>
                                      </mx:Application>
                                      Awaiting for the prompt reply with a solution.
                                      Regards......
                                      • 16. Re: how to show submenu in a menubar on mouseover
                                        sunny.adigarla Level 1
                                        I too have the same problem. I need the sub menu items with mouseOver effect for creationComplete event (on load of the swf object). My script is given below. Can anybody help me to find out the solution?
                                        <?xml version="1.0" encoding="UTF-8"?>
                                        <mx:Application name="header"
                                        xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute"
                                        verticalAlign="middle" horizontalAlign="center" creationComplete="{ createAndShow(); menuSrv.send();}">
                                            <mx:Script>
                                                <![CDATA[
                                                    // Function to create and show a menu.
                                                    private function createAndShow():void {
                                                        // Add an event listener for the itemClick event.
                                                        myMenu.addEventListener(MenuEvent.ITEM_CLICK , itemClickInfo);
                                                        myMenu.addEventListener(MouseEvent.CLICK, itemClickInfo2);
                                                    // The event listener for the itemClick event.
                                                    private function itemClickInfo(event:MenuEvent):void {
                                                    //Alert.show(event.item.@data);
                                                    var url:String = event.item.@data;
                                                    var u:URLRequest = new URLRequest(url);
                                                    //navigateToURL(u, '_self');
                                                    private function itemClickInfo2(event:MouseEvent):void {
                                                    //Alert.show(event.target.data.@data);
                                                    var url:String = event.target.data.@data;
                                            </mx:Script>
                                        <mx:HTTPService id="menuSrv"
                                        url="http://localhost/sentrifugo/admin/layout/getMenuLevel1"
                                        resultFormat="e4x" />
                                        <mx:Panel width="980">
                                        <mx:Image
                                        source="http://localhost/sentrifugo/public/media/images/fleximages/layout/Capture3.png"
                                        height="70">
                                        </mx:Image>
                                        <mx:Label text="Sentrifugo" fontWeight="bold" fontSize="20">
                                        </mx:Label>
                                        <mx:MenuBar id="myMenu" showRoot="false" labelField="@label"
                                        dataProvider="{menuSrv.lastResult as XML}">
                                        </mx:MenuBar>
                                        </mx:Panel>
                                        </mx:Application>
                                        • 17. Re: how to show submenu in a menubar on mouseover
                                          Flex harUI Adobe Employee
                                          I don't understand the goal.  Please re-state.
                                          • 18. Re: how to show submenu in a menubar on mouseover
                                            I have implemented menubar with data provider attribute. I mean, i get menu items by HTTP service. In order to view the sub menu items user has to click on the menu bar atleast one time. Then only it shows the sub menu items on hover. But without clicking the menu bar even one time, i need that hover effect for sub menu items.
