4 Replies Latest reply on Feb 27, 2012 11:11 AM by andydesigns2
    Problem with Applying a pattern
    andydesigns2 Level 1
      Hi all,
      I am just starting out with the Photoshop CS5 trial. I am trying to apply a triangular pattern to a thin rectangular shape. I used the custom shape tool>triangle, then defined the pattern successfully.
      However, when I apply the pattern it partially repeats it along the vertical as well as the horizontal axis. Please see attached screenshot:patternproblem.jpg
      I only want it to repeat horizontally, what am I doing wrong?
      Also, I am Fireworks CS5 user and am really missing the properties inspector panel which allows you to quickly and esily edit sizes of objects, is there a Photoshop equivalent of this?........at the moment the only way I can find to edit objects is through Edit>Free Transform.
      tia,
      Andy
