1 Reply Latest reply on Dec 10, 2012 4:51 PM by roymeo_
    CacheAsBitmap and setting Alpha?
    JAXIMFLASH
      I am experiencing a problem with setting the cacheAsBitmap and alpha properties on TV devices. (This is not an issue on my desktop.)
      I'd like to set a display object's cacheAsBitmap property to true.
      The display object has an alpha transparency of .5.
      If I cache the Bitmap while the alpha is set to .5, then the display object appears to have a transparency of .25.
      I've tried to set the alpha to 1, cache the bitmap, and then set the alpha to .5 --  this does not work.
      this.alpha = 1;
      this.cacheAsBitmap = true;
      this.alpha = .5;
      What does work is if I delay in setting the alpha. If i set the alpha to 1, cache the bitmap, wait 2 seconds, and then set the alpha to .5 --- then that works!
      this.alpha = 1;
      var timer:Timer = new Timer(2000,1);
      timer.addEventListener(TimerEvent.TIMER_COMPLETE, onTimer);
      timer.start();
      protected function onTimer(e:TimerEvent):void {
                                    this.alpha = .5;
      However, this is less than ideal. I want to cache the bitmap immediately while the alpha is set to .5.
      Is there some trick to do this?
