5 Replies Latest reply: Feb 28, 2012 4:56 AM by JayCharles RSS
    shared object with complex values
    jacograaff Community Member
      My remote shared object on the server was created like this...
      var userList = new Array();
      application.onAppStart = function(){
      this.usersSO = SharedObject.get("userList", false);
      then on connect I create a new object and put that into the so-list
      application.onConnect = function(client, user){
      application.acceptConnection(client);
           var newUser = new Object();
          newUser.userName = user.userName;
          newUser.userID = user.userID;
          newUser.userStatus = user.userStatus;
      this.usersSO.setProperty(user.userID, newUser);
      I can clear the user:
      this.usersSO.setProperty(client.userID, null);
      but how do I set a value like
      userStatus
      when it is inside a object refered to by the so name-id
      setProperty(userID, simpleValue);
      if I added simple values like
      this.usersSO.setProperty('simpleName', "nameABC");
      then I could
      setProperty('simpleName', "nameNEW");
      - is the only way to call a script on the server and set the original userList reference of the user adn then send a call with update function to all connected clients???
      thanks
        • 1. Re: shared object with complex values
          the way I am doing it now:
          in main.asc
          Client.prototype.changeConsultantStatus = function(action, selectedUserID, client){
               trace("server.changeStatus: "+action+", to: "+selectedUserID+", from: "+client.userName);
                users[selectedUserID].userStatus = action;
              application.broadcastMsg("updateRemoteStatus",selectedUserID, action);
          then in my flex/AIR app
          private function updateRemoteStatus(event):void{
              var _selectedUserID:String = event.infoObject.selectedUserID;
              var _action:String = event.infoObject.action;
              for (var n:int = 0; n < consultantCollection.length; n++){
                  if((consultantCollection[n].userID) == _selectedUserID){
                      traceStr("Set status for: " + consultantCollection[n].userName+" to "+_action);
                      consultantCollection[n].userStatus = _action;
                      consultantCollection.refresh();
                      //found it - don't look further
                      break;
          Ideally the default update on a sharedobject change should run - like when i add or delete a "user" from the sharedobject
          but i really need to change a value of a property of an existing user inside the sharedobject
          • 2. Re: shared object with complex values
            ok - i am looking at this explanation (goes beyond the basic adobe ball.x and ball.y example)
            http://www.justskins.com/forums/remote-shared-object-78616.html
            will implement it...
            • 3. Re: shared object with complex values
              i tried:
                  /* option 1 */
                  //tempUser = this.usersSO.get[selectedUserID]; // -------------------------  throws error - TypeError: this.usersSO has no properties
                  tempUser = users[selectedUserID];
                  tempUser.userStatus = action;
                  this.usersSO.setProperty(selectedUserID, tempUser); // will also throw error when reffering to usersSO inside Client.prototype.function
                  /* option 2 */
                  //client.userStatus = action;
                  //application.broadcastMsg("updateRemoteStatus",selectedUserID, action);
              when refering to shared object inside a Client.prototype.function
              I get
              -- the second option works though
              • 4. Re: shared object with complex values
                it seems like serverside I will have to declare/instantiate the sharedobject again and link it with the stored userList variable
                as seen at
                http://echo.ryerson.ca/fcsEchoSite/arraysSharedObjects/index.html
                  I don t have to on
                application.onDisconnect and other application level functions
                but I have to on
                Client.prototype.someFunction and client level related functions
                I'll try a bit later .....
                • 5. Re: shared object with complex values
                  JayCharles Community Member
                  I *think* I understand what you're asking here...
                  If you need to update a property within an object that is the value of a sharedobject slot, you need to get the property, change the value, and then set the property again.
                  var obj = my_so.getProperty("someslot");
                  obj.someproperty = somevalue
                  my_so.setProperty("someslot", obj);
