16 Replies Latest reply on May 4, 2008 1:22 AM by BKBK
    problem with xmlParse()
    djc11 Level 1
      I can not get around this problem... I have tried:
      <cfset model = xmlParse(#cfhttp.fileContent#)>
      <cfset model = xmlParse(cfhttp.fileContent)>
      <cfset model = xmlParse(ToString(cfhttp.fileContent))>
      <cfset model = xmlParse(Trim(cfhttp.fileContent))>
      <cfset model = xmlParse(Trim(ToString(cfhttp.fileContent)))>
      All of these give me the error : 'content is not allowed in prolog'...
      What is the deal??? What is the syntax for this?
        • 1. Re: problem with xmlParse()
          Level 7
          your xml is ill formed. look at the first few lines of it.
          • 2. Re: problem with xmlParse()
            djc11 Level 1
            It is the automatically generated XML from the chttp request response from Authorize.net. For an example, if i dump cfhttp.fileContent I get:
            <?xml version="1.0" encoding="utf-8"?><ARBCreateSubscriptionResponse xmlns:xsi=" http://www.w3.org/2001/XMLSchema-instance" xmlns:xsd=" http://www.w3.org/2001/XMLSchema" xmlns="AnetApi/xml/v1/schema/AnetApiSchema.xsd"><refId>dus6073</refId><messages><resultCo de>Error</resultCode><message><code>E00012</code><text>You have submitted a duplicate of Subscription 277440. A duplicate subscription will not be created.</text></message></messages></ARBCreateSubscriptionResponse>
            • 3. Re: problem with xmlParse()
              djc11 Level 1
              Which one of the above formats should work?
              • 4. Re: problem with xmlParse()
                Level 7
                • 5. Re: problem with xmlParse()
                  djc11 Level 1
                  I am having no luck with this. Do you see any problem with the sample XML above?
                  • 6. Re: problem with xmlParse()
                    djc11 Level 1
                    If i dump cfhttp.fileContent it outputs the above xml. If i <cfoutput>#cfhttp.fileContent#</cfoutput>, it only outputs the text in the element nodes. That's what i would expect it to do but does it have anything to do with my problem?
                    • 7. Re: problem with xmlParse()
                      Level 7
                      i thought i replied to that already but i guess the xml in the posting scrabbled
                      the email off to never-never land.
                      yes, that xml snippet got parsed fine but if there's any goop at the beginning
                      of the xml it won't parse,which is why i thought trim would work.
                      • 8. Re: problem with xmlParse()
                        Level 7
                        no, if you view source you should see the xml.
                        i guess there's something going on w/the cfhttp. what version of cf? is there a
                        url i can test?
                        • 9. Re: problem with xmlParse()
                          djc11 Level 1
                          Here is a url: https://midas.jnet.us/dc/cf_aim/testarb.cfm
                          It is CF8.
                          Here is the source:
                          <cfxml variable="XMLSubscriptionRequest">
                          <ARBCreateSubscriptionRequest xmlns="AnetApi/xml/v1/schema/AnetApiSchema.xsd">
                          <merchantAuthentication>
                          <name>xasdfasdfpJD</name>
                          <transactionKey>xsdafdsafasdfjrx6</transactionKey>
                          </merchantAuthentication>
                          <refId>sample</refId>
                          <subscription>
                          <name>ProPlanner Subscription</name>
                          <paymentSchedule>
                          <interval>
                          <length>12</length>
                          <unit>months</unit>
                          </interval>
                          <startDate>2008-04-20</startDate>
                          <totalOccurrences>9999</totalOccurrences>
                          </paymentSchedule>
                          <amount>500.00</amount>
                          <payment>
                          <creditCard>
                          <cardNumber>4111111111111111</cardNumber>
                          <expirationDate>2008-12</expirationDate>
                          </creditCard>
                          </payment>
                          <customer>
                          <id>test0001</id>
                          <email>test@abc.com</email>
                          <phoneNumber>555-555-5555</phoneNumber>
                          </customer>
                          <billTo>
                          <firstName>Dustin</firstName>
                          <lastName>Chesterman</lastName>
                          <company>CFOTools.Net</company>
                          <address>123 Main St</address>
                          <city>Anytown</city>
                          <state>CA</state>
                          <zip>12345</zip>
                          </billTo>
                          </subscription>
                          </ARBCreateSubscriptionRequest>
                          </cfxml>
                          <cfhttp method="POST" url="https://apitest.authorize.net/xml/v1/request.api" >
                          <cfhttpparam type="Header" name="Accept-Encoding" value="deflate;q=0">
                          <cfhttpparam type="Header" name="TE" value="deflate;q=0">
                          <cfhttpparam name="body" type="xml" value="#ToString(XMLSubscriptionRequest)#" />
                          </cfhttp>
                          <cfdump var="#cfhttp#">
                          <cfset model = '#ToString(Trim(cfhttp.fileContent))#'>
                          <cfdump var="#model#">
                          <br />
                          <br />
                          <cfoutput>#ToString(model)#</cfoutput>
                          <cfset model1 = XmlParse(model)>
                          <cfdump var="#model1#">
                          • 10. Re: problem with xmlParse()
                            Level 7
                            that was harder then it should have been, should have realized this from the git
                            go, sorry. its adding a BOM to the xml. its optional for UTF-8 & many s/w don't
                            add it or even strip it out. frankly i don't know that xml is supposed to have
                            this or not (and cf's xmlParse is doing the right thing).
                            in any case:
                            <cfset BOM=chr(65279)> <!--- utf-8 ONLY --->
                            <cfset z=replace(cfhttp.fileContent,BOM,"")>
                            <cfdump var="#xmlParse(z)#">
                            • 11. Re: problem with xmlParse()
                              BKBK Adobe Community Professional & MVP
                              Djc11,
                              Your latest post simply complicates matters. It is not clear what you want with it. For example, what does it have to do with the error?
                              You seem to think PaulH is talking about your source code. When he says you should look at the source, he means the source in the browser. For example, in IE, the menu View => Source.
                              To return to the 'content is not allowed in prolog' error, I noticed in an XML from authorize.net that there is an extra character at the beginning. I would therefore suggest that you first remove the characters in the beginning. Do something like the following.
                              • 12. Re: problem with xmlParse()
                                djc11 Level 1
                                Thanks Paul, I looked for a BOM after reading another post, but didn't see one so i didn't even try it :-P Works perfect now. Thank you again!
                                BKBK- I was making sure that i was calling xmlParse in the correct fashion. Thanks for you input though.
                                • 13. Re: problem with xmlParse()
                                  Level 7
                                  well you're not supposed to, but if you need to check write the content out
                                  w/cffile & use iso-8859-1 as the "charset". if you open that file in notepad you
                                  should see garbage (a question mark) before the 1st xml tag. if you use utf-8 as
                                  the "charset" you won't see anything but notepad will want to save that file as
                                  utf-8.
                                  after reading some W3C stuff on xml & BOMs i'm thinking that maybe xmlParse()
                                  should actually handle this.
                                  • 14. Re: problem with xmlParse()
                                    The REREplaceNoCase line in my code removes the BOM as well, so it may seem like a duplication, coming after PaulH's code. There was a delay in the post from the newsgroup. When I composed my last post, PaulH's post of 04/17/2008 06:40:57 AM wasn't yet in the forum.
                                    that maybe xmlParse() should actually handle this.
                                    Difficult. BOM is related to unicode, but xmlParse doesn't have any attribute that relates to encoding.
                                    • 15. Re: problem with xmlParse()
                                      Level 7
                                      no not difficult and nothing to do w/the developer knowing the encoding beforehand.
                                      if there's a BOM & the *xml* is declaring itself to be utf-8 encoded, the parser
                                      can toss the BOM, it has no relevance for parsing the xml (only if the encoding
                                      is utf-16 or i guess utf-32 is the BOM really relevant). if there's no xml
                                      encoding declaration then the parser would have to look at & use the BOM to see
                                      the encoding & which "endiness" to use.
                                      if the parser can't handle BOMs (as far as i can tell from the W3C WG it's
                                      supposed) then any valid utf-16, etc encoded xml docs will also bomb--the BOM is
                                      *required* for those.
                                      • 16. Re: problem with xmlParse()
                                        PaulH,
                                        I am aware of the requirement of an XML parser to be able to determine two types of information from the BOM or even from the XML declaration. First, whether the storage type is big-endian or little-endian. Secondly, whether the document's encoding used 1, 2 or 4 bytes per character. From there, the parser can get a good idea of the type of encoding.
                                        What made me think it would be difficult is the fact that XMLParse also has the function of validating XML by means of an external DTD. I can see the point you make about UTF-16. It would be easy to redesign XMLParse for XML in UTF-16 encoding. As you said, the BOM is a required feature for XML documents in UTF-16 encoding as well as for their DTDs. However, for most other encodings, there is no requirement for either BOM or XML declaration in the DTD.
