2 Replies Latest reply on Jun 7, 2007 1:55 PM by wpbackpack
    A stack overflow error has occurred.
    jag57 Level 1
      I right clicked on a table in RDS Dataview and selected "show table contents". After doing this i get the following in a pop-up window:
      You are recommended to exit the workbench.
      Subsequent errors may happen and may terminate the workbench without warning.
      See the .log file for more details.
      I have eclipse 3.2.2 and flexbuilder 2.01.
      I deleted and then re-installed the coldfusion extensions and this did not make a difference.
      What can I do to eliminate this problem?
      Thanks in advance.
      Below is part of the ".log" file (exceeds maximum message size) from my .metadata directory (perhaps this means something to someone):
      !SESSION 2007-06-03 14:14:27.234 -----------------------------------------------
      eclipse.buildId=M20070212-1330
      java.version=1.6.0_01
      java.vendor=Sun Microsystems Inc.
      BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=en_US
      Command-line arguments: -os win32 -ws win32 -arch x86
      This is a continuation of log file C:\CFusionMX7\wwwroot\.metadata\.bak_0.log
      Created Time: 2007-06-03 14:15:29.390
      !ENTRY org.eclipse.ui.workbench 4 0 2007-06-03 14:15:29.390
      !MESSAGE Widget disposed too early!
      !STACK 0
      java.lang.RuntimeException: Widget disposed too early!
      at org.eclipse.ui.internal.WorkbenchPartReference$1.widgetDisposed(WorkbenchPartReference.ja va:153)
      at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:101)
      at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:66)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:928)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:952)
      at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:933)
      at org.eclipse.swt.widgets.Widget.release(Widget.java:743)
      at org.eclipse.swt.widgets.Composite.releaseChildren(Composite.java:636)
      at org.eclipse.swt.widgets.Widget.release(Widget.java:746)
      at org.eclipse.swt.widgets.Canvas.releaseChildren(Canvas.java:117)
      at org.eclipse.swt.widgets.Decorations.releaseChildren(Decorations.java:722)
      at org.eclipse.swt.widgets.Shell.releaseChildren(Shell.java:1062)
      at org.eclipse.swt.widgets.Widget.dispose(Widget.java:415)
      at org.eclipse.swt.widgets.Decorations.dispose(Decorations.java:397)
      at org.eclipse.swt.widgets.Shell.dispose(Shell.java:627)
      at org.eclipse.jface.window.Window.close(Window.java:330)
      at org.eclipse.jface.window.ApplicationWindow.close(ApplicationWindow.java:299)
      at org.eclipse.ui.internal.WorkbenchWindow.hardClose(WorkbenchWindow.java:1510)
      at org.eclipse.ui.internal.WorkbenchWindow.busyClose(WorkbenchWindow.java:622)
      at org.eclipse.ui.internal.WorkbenchWindow.access$0(WorkbenchWindow.java:598)
      at org.eclipse.ui.internal.WorkbenchWindow$2.run(WorkbenchWindow.java:713)
      at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:67)
      at org.eclipse.ui.internal.WorkbenchWindow.close(WorkbenchWindow.java:711)
      at org.eclipse.jface.window.WindowManager.close(WindowManager.java:109)
      at org.eclipse.ui.internal.Workbench$12.run(Workbench.java:715)
      at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:37)
      at org.eclipse.ui.internal.Workbench.busyClose(Workbench.java:712)
      at org.eclipse.ui.internal.Workbench.access$8(Workbench.java:642)
      at org.eclipse.ui.internal.Workbench$15.run(Workbench.java:855)
      at org.eclipse.ui.internal.Workbench.close(Workbench.java:853)
      at org.eclipse.ui.internal.WorkbenchConfigurer.emergencyClose(WorkbenchConfigurer.java:165)
      at org.eclipse.ui.internal.ide.IDEExceptionHandler.closeWorkbench(IDEExceptionHandler.java:1 23)
      at org.eclipse.ui.internal.ide.IDEExceptionHandler.handleException(IDEExceptionHandler.java: 101)
      at org.eclipse.ui.internal.ide.IDEWorkbenchAdvisor.eventLoopException(IDEWorkbenchAdvisor.ja va:298)
      at org.eclipse.ui.internal.ExceptionHandler.handleException(ExceptionHandler.java:62)
      at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:1934)
      at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:1894)
      at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:422)
      at org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
      at org.eclipse.ui.internal.ide.IDEApplication.run(IDEApplication.java:95)
      at org.eclipse.core.internal.runtime.PlatformActivator$1.run(PlatformActivator.java:78)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:92)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:68)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:400)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown Source)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(Unknown Source)
      at java.lang.reflect.Method.invoke(Unknown Source)
      at org.eclipse.core.launcher.Main.invokeFramework(Main.java:336)
      at org.eclipse.core.launcher.Main.basicRun(Main.java:280)
      at org.eclipse.core.launcher.Main.run(Main.java:977)
      at org.eclipse.core.launcher.Main.main(Main.java:952)
      !STACK 0
      XXXXX CUT XXXXXX
