0 Replies Latest reply on Feb 27, 2012 10:31 PM by davy zhang
    flex sdk incremental build will lose swc information
    davy zhang
      I have a mxmlc ant task job like this
              <mxmlc
              file="${trunk_dir}/main/src/main.mxml"
              output="${local_tmp}/app/bin/main.swf"
                  <load-config filename="${basedir}/flex-config-sea.xml"/>
                  <source-path path-element="${FLEX_HOME}/frameworks"/>
              </mxmlc>
      in flex-config-sea.xml I put this in for incremental compile and swc build
            <include-libraries>
               <library>/opt/cruisecontrol-bin-2.8.4/projects/sea_client/trunk/main/libs/Mate_08_9.swc</library>
               <library>/opt/cruisecontrol-bin-2.8.4/projects/sea_client/trunk/main/libs/xprogress.swc</library>
               <library>/opt/cruisecontrol-bin-2.8.4/projects/sea_client/trunk/main/libs/component.swc</library>
            </include-libraries>
            <incremental>true</incremental>
      the first time build is ok, but the second time after I changed one single file, the output is
      [mxmlc] Loading configuration file /opt/cruisecontrol-bin-2.8.4/projects/cc/flex-config-sea.xml
          [mxmlc] Recompile: /opt/cruisecontrol-bin-2.8.4/projects/sea_client/trunk/main/src/C.as
          [mxmlc] Reason: The source file or one of the included files has been updated.
          [mxmlc] Files changed: 1 Files affected: 0
          [mxmlc] Required RSLs:
          [mxmlc]     textLayout_2.0.0.232.swz with 1 failover.
          [mxmlc]     framework_4.6.0.23201.swz with 1 failover.
          [mxmlc]     rpc_4.6.0.23201.swz with 1 failover.
          [mxmlc]     mx_4.6.0.23201.swz with 1 failover.
          [mxmlc]     spark_4.6.0.23201.swz with 1 failover.
          [mxmlc]     sparkskins_4.6.0.23201.swz with 1 failover.
          [mxmlc] /tmp/sea_local/app/bin/main.swf (426617 bytes)
      but the output swf is complaining lack of some swc when running, which didn't show up in the first time
      ReferenceError: Error #1065: Variable _shared_maps_GlobalMapWatcherSetupUtil is not defined.
                at global/flash.utils::getDefinitionByName()
                at shared.maps::GlobalMap()
                at main/_main_GlobalMap1_i()
                at main()
                at _main_mx_managers_SystemManager/create()
                at mx.managers.systemClasses::ChildManager/initializeTopLevelWindow()
                at mx.managers::SystemManager/initializeTopLevelWindow()
                at mx.managers::SystemManager/http://www.adobe.com/2006/flex/mx/internal::kickOff()
                at mx.managers::SystemManager/http://www.adobe.com/2006/flex/mx/internal::preloader_completeHandler()
                at flash.events::EventDispatcher/dispatchEventFunction()
                at flash.events::EventDispatcher/dispatchEvent()
                at mx.preloaders::Preloader/timerHandler()
                at flash.utils::Timer/_timerDispatch()
                at flash.utils::Timer/tick()
      this message normally shows up when there's no Mate_08_9.swc found at runtime. but this shouldn't happen.
      is there anyway to work around this? thanks a lot
      here is the full flex-config-sea.xml:
      <flex-config>
         <!-- benchmark: output performance benchmark-->
         <!-- benchmark usage:
         <benchmark>boolean</benchmark>
         <compiler>
            <!-- compiler.accessible: generate an accessible SWF-->
            <accessible>true</accessible>
            <!-- compiler.actionscript-file-encoding: specifies actionscript file encoding. If there is no BOM in the AS3 source files, the compiler will use this file encoding.-->
            <!-- compiler.actionscript-file-encoding usage:
            <actionscript-file-encoding>string</actionscript-file-encoding>
            <!-- compiler.allow-source-path-overlap: checks if a source-path entry is a subdirectory of another source-path entry. It helps make the package names of MXML components unambiguous.-->
            <allow-source-path-overlap>false</allow-source-path-overlap>
            <!-- compiler.as3: use the ActionScript 3 class based object model for greater performance and better error reporting. In the class based object model most built-in functions are implemented as fixed methods of classes.-->
            <as3>true</as3>
            <!-- compiler.compress usage:
            <compress>boolean</compress>
            <!-- compiler.context-root: path to replace {context.root} tokens for service channel endpoints-->
            <!-- compiler.context-root usage:
            <context-root>context-path</context-root>
            <!-- compiler.debug: generates a movie that is suitable for debugging-->
            <debug>false</debug>
            <!-- compiler.defaults-css-files usage:
            <defaults-css-files>
               <filename>string</filename>
            </defaults-css-files>
            <!-- compiler.defaults-css-url: defines the location of the default style sheet. Setting this option overrides the implicit use of the defaults.css style sheet in the framework.swc file.-->
            <!-- compiler.defaults-css-url usage:
            <defaults-css-url>string</defaults-css-url>
            <!-- compiler.define: define a global AS3 conditional compilation definition, e.g. -define=CONFIG::debugging,true or -define+=CONFIG::debugging,true (to append to existing definitions in flex-config.xml) -->
            <!-- compiler.define usage:
            <define>
               <name>string</name>
               <value>string</value>
            </define>
            <!-- compiler.enable-runtime-design-layers usage:
            <enable-runtime-design-layers>boolean</enable-runtime-design-layers>
            <!-- compiler.es: use the ECMAScript edition 3 prototype based object model to allow dynamic overriding of prototype properties. In the prototype based object model built-in functions are implemented as dynamic properties of prototype objects.-->
            <es>false</es>
            <extensions>
               <!-- compiler.extensions.extension usage:
               <extension>
                  <extension>string</extension>
                  <parameters>string</parameters>
               </extension>
            </extensions>
            <!-- compiler.external-library-path: list of SWC files or directories to compile against but to omit from linking-->
            <external-library-path>
               <path-element>/opt/flexsdk/4.6.0/frameworks/libs/player/11.1/playerglobal.swc</path-element>
            </external-library-path>
            <fonts>
               <!-- compiler.fonts.advanced-anti-aliasing: enables advanced anti-aliasing for embedded fonts, which provides greater clarity for small fonts.-->
               <advanced-anti-aliasing>true</advanced-anti-aliasing>
               <!-- compiler.fonts.flash-type: enables FlashType for embedded fonts, which provides greater clarity for small fonts.-->
               <!-- compiler.fonts.flash-type usage:
               <flash-type>boolean</flash-type>
               <languages>
                  <!-- compiler.fonts.languages.language-range: a range to restrict the number of font glyphs embedded into the SWF-->
                  <!-- compiler.fonts.languages.language-range usage:
                  <language-range>
                     <lang>string</lang>
                     <range>string</range>
                  </language-range>
               </languages>
               <!-- compiler.fonts.local-font-paths usage:
               <local-font-paths>
                  <path-element>string</path-element>
               </local-font-paths>
               <!-- compiler.fonts.local-fonts-snapshot: File containing system font data produced by flex2.tools.FontSnapshot.-->
               <!-- compiler.fonts.managers: Compiler font manager classes, in policy resolution order-->
               <managers>
                  <manager-class>flash.fonts.JREFontManager</manager-class>
                  <manager-class>flash.fonts.BatikFontManager</manager-class>
                  <manager-class>flash.fonts.AFEFontManager</manager-class>
                  <manager-class>flash.fonts.CFFFontManager</manager-class>
               </managers>
               <!-- compiler.fonts.max-cached-fonts: sets the maximum number of fonts to keep in the server cache.  The default value is 20.-->
               <max-cached-fonts>20</max-cached-fonts>
               <!-- compiler.fonts.max-glyphs-per-face: sets the maximum number of character glyph-outlines to keep in the server cache for each font face. The default value is 1000.-->
               <max-glyphs-per-face>1000</max-glyphs-per-face>
            </fonts>
            <!-- compiler.headless-server: a flag to set when Flex is running on a server without a display-->
            <!-- compiler.headless-server usage:
            <headless-server>boolean</headless-server>
            <!-- compiler.include-libraries: a list of libraries (SWCs) to completely include in the SWF-->
            <!-- compiler.include-libraries usage:
            <include-libraries>
               <library>string</library>
            <include-libraries>
            <!-- compiler.incremental: enables incremental compilation-->
            <!-- compiler.incremental usage:
            <incremental>boolean</incremental>
            <!-- compiler.isolate-styles: enables the compiled application or module to set styles that only affect itself and its children-->
            <!-- compiler.isolate-styles usage:
            <isolate-styles>boolean</isolate-styles>
            <!-- compiler.keep-all-type-selectors: disables the pruning of unused CSS type selectors-->
            <!-- compiler.keep-all-type-selectors usage:
            <keep-all-type-selectors>boolean</keep-all-type-selectors>
            <!-- compiler.keep-as3-metadata: keep the specified metadata in the SWF-->
            <!-- compiler.keep-as3-metadata usage:
            <keep-as3-metadata>
               <name>string</name>
               <name>string</name>
            </keep-as3-metadata>
            <!-- compiler.keep-generated-actionscript: save temporary source files generated during MXML compilation-->
            <keep-generated-actionscript>false</keep-generated-actionscript>
            <!-- compiler.library-path: list of SWC files or directories that contain SWC files-->
            <library-path>
               <path-element>/opt/flexsdk/4.6.0/frameworks/libs/flash-integration.swc</path-element>
               <path-element>/opt/flexsdk/4.6.0/frameworks/libs/authoringsupport.swc</path-element>
               <path-element>/opt/flexsdk/4.6.0/frameworks/locale/{locale}</path-element>
            </library-path>
            <!-- compiler.locale: specifies the locale for internationalization-->
            <locale>
               <locale-element>en_US</locale-element>
            </locale>
            <!-- compiler.minimum-supported-version usage:
            <minimum-supported-version>string</minimum-supported-version>
            <!-- compiler.mobile: specifies the target runtime is a mobile device-->
            <mobile>false</mobile>
            <mxml>
               <!-- compiler.mxml.compatibility-version: specifies a compatibility version. e.g. -compatibility-version=2.0.1-->
               <!-- compiler.mxml.compatibility-version usage:
               <compatibility-version>version</compatibility-version>
               <!-- compiler.mxml.minimum-supported-version usage:
               <!-- compiler.mxml.qualified-type-selectors usage:
               <qualified-type-selectors>boolean</qualified-type-selectors>
            </mxml>
            <namespaces>
               <!-- compiler.namespaces.namespace: Specify a URI to associate with a manifest of components for use as MXML elements-->
               <namespace>
                  <uri>http://ns.adobe.com/mxml/2009</uri>
                  <manifest>/opt/flexsdk/4.6.0/frameworks/mxml-2009-manifest.xml</manifest>
               </namespace>
               <namespace>
                  <uri>library://ns.adobe.com/flex/spark</uri>
                  <manifest>/opt/flexsdk/4.6.0/frameworks/spark-manifest.xml</manifest>
               </namespace>
               <namespace>
                  <uri>library://ns.adobe.com/flex/mx</uri>
                  <manifest>/opt/flexsdk/4.6.0/frameworks/mx-manifest.xml</manifest>
               </namespace>
               <namespace>
                  <uri>http://www.adobe.com/2006/mxml</uri>
                  <manifest>/opt/flexsdk/4.6.0/frameworks/mxml-manifest.xml</manifest>
               </namespace>
            </namespaces>
            <!-- compiler.omit-trace-statements: toggle whether trace statements are omitted-->
            <omit-trace-statements>true</omit-trace-statements>
            <!-- compiler.optimize: Enable post-link SWF optimization-->
            <optimize>true</optimize>
            <!-- compiler.preloader: Specifies the default value for the Application's preloader attribute. If not specified, the default preloader value is mx.preloaders.SparkDownloadProgressBar when -compatibility-version >= 4.0 and mx.preloaders.DownloadProgressBar when -compatibility-version < 4.0.-->
            <!-- compiler.preloader usage:
            <preloader>string</preloader>
            <!-- compiler.report-invalid-styles-as-warnings: enables reporting of invalid styles as warnings-->
            <!-- compiler.report-invalid-styles-as-warnings usage:
            <report-invalid-styles-as-warnings>boolean</report-invalid-styles-as-warnings>
            <!-- compiler.report-missing-required-skin-parts-as-warnings: Use this option to generate a warning instead of an error when a missing required skin part is detected.-->
            <!-- compiler.report-missing-required-skin-parts-as-warnings usage:
            <report-missing-required-skin-parts-as-warnings>boolean</report-missing-required-skin-parts-as-warnings>
            <!-- compiler.services: path to Flex Data Services configuration file-->
            <!-- compiler.services usage:
            <services>filename</services>
            <!-- compiler.show-actionscript-warnings: runs the AS3 compiler in a mode that detects legal but potentially incorrect code-->
            <show-actionscript-warnings>true</show-actionscript-warnings>
            <!-- compiler.show-binding-warnings: toggle whether warnings generated from data binding code are displayed-->
            <show-binding-warnings>true</show-binding-warnings>
            <!-- compiler.show-invalid-css-property-warnings: toggle whether invalid css property warnings are reported-->
            <!-- compiler.show-invalid-css-property-warnings usage:
            <show-invalid-css-property-warnings>boolean</show-invalid-css-property-warnings>
            <!-- compiler.show-shadowed-device-font-warnings: toggles whether warnings are displayed when an embedded font name shadows a device font name-->
            <show-shadowed-device-font-warnings>false</show-shadowed-device-font-warnings>
            <!-- compiler.show-unused-type-selector-warnings: toggle whether warnings generated from unused CSS type selectors are displayed-->
            <show-unused-type-selector-warnings>true</show-unused-type-selector-warnings>
            <!-- compiler.source-path: list of path elements that form the roots of ActionScript class hierarchies-->
            <source-path>
            </source-path>
            <!-- compiler.strict: runs the AS3 compiler in strict error checking mode.-->
            <strict>true</strict>
            <!-- compiler.theme: list of CSS or SWC files to apply as a theme-->
            <!-- compiler.use-resource-bundle-metadata: determines whether resources bundles are included in the application.-->
            <use-resource-bundle-metadata>true</use-resource-bundle-metadata>
            <!-- compiler.verbose-stacktraces: save callstack information to the SWF for debugging-->
            <verbose-stacktraces>false</verbose-stacktraces>
            <!-- compiler.warn-array-tostring-changes: Array.toString() format has changed.-->
            <warn-array-tostring-changes>false</warn-array-tostring-changes>
            <!-- compiler.warn-assignment-within-conditional: Assignment within conditional.-->
            <warn-assignment-within-conditional>true</warn-assignment-within-conditional>
            <!-- compiler.warn-bad-array-cast: Possibly invalid Array cast operation.-->
            <warn-bad-array-cast>true</warn-bad-array-cast>
            <!-- compiler.warn-bad-bool-assignment: Non-Boolean value used where a Boolean value was expected.-->
            <warn-bad-bool-assignment>true</warn-bad-bool-assignment>
            <!-- compiler.warn-bad-date-cast: Invalid Date cast operation.-->
            <warn-bad-date-cast>true</warn-bad-date-cast>
            <!-- compiler.warn-bad-es3-type-method: Unknown method.-->
            <warn-bad-es3-type-method>true</warn-bad-es3-type-method>
            <!-- compiler.warn-bad-es3-type-prop: Unknown property.-->
            <warn-bad-es3-type-prop>true</warn-bad-es3-type-prop>
            <!-- compiler.warn-bad-nan-comparison: Illogical comparison with NaN. Any comparison operation involving NaN will evaluate to false because NaN != NaN.-->
            <warn-bad-nan-comparison>true</warn-bad-nan-comparison>
            <!-- compiler.warn-bad-null-assignment: Impossible assignment to null.-->
            <warn-bad-null-assignment>true</warn-bad-null-assignment>
            <!-- compiler.warn-bad-null-comparison: Illogical comparison with null.-->
            <warn-bad-null-comparison>true</warn-bad-null-comparison>
            <!-- compiler.warn-bad-undefined-comparison: Illogical comparison with undefined.  Only untyped variables (or variables of type *) can be undefined.-->
            <warn-bad-undefined-comparison>true</warn-bad-undefined-comparison>
            <!-- compiler.warn-boolean-constructor-with-no-args: Boolean() with no arguments returns false in ActionScript 3.0.  Boolean() returned undefined in ActionScript 2.0.-->
            <warn-boolean-constructor-with-no-args>false</warn-boolean-constructor-with-no-args>
            <!-- compiler.warn-changes-in-resolve: __resolve is no longer supported.-->
            <warn-changes-in-resolve>false</warn-changes-in-resolve>
            <!-- compiler.warn-class-is-sealed: Class is sealed.  It cannot have members added to it dynamically.-->
            <warn-class-is-sealed>true</warn-class-is-sealed>
            <!-- compiler.warn-const-not-initialized: Constant not initialized.-->
            <warn-const-not-initialized>true</warn-const-not-initialized>
            <!-- compiler.warn-constructor-returns-value: Function used in new expression returns a value.  Result will be what the function returns, rather than a new instance of that function.-->
            <warn-constructor-returns-value>false</warn-constructor-returns-value>
            <!-- compiler.warn-deprecated-event-handler-error: EventHandler was not added as a listener.-->
            <warn-deprecated-event-handler-error>false</warn-deprecated-event-handler-error>
            <!-- compiler.warn-deprecated-function-error: Unsupported ActionScript 2.0 function.-->
            <warn-deprecated-function-error>true</warn-deprecated-function-error>
            <!-- compiler.warn-deprecated-property-error: Unsupported ActionScript 2.0 property.-->
            <warn-deprecated-property-error>true</warn-deprecated-property-error>
            <!-- compiler.warn-duplicate-argument-names: More than one argument by the same name.-->
            <warn-duplicate-argument-names>true</warn-duplicate-argument-names>
            <!-- compiler.warn-duplicate-variable-def: Duplicate variable definition -->
            <warn-duplicate-variable-def>true</warn-duplicate-variable-def>
            <!-- compiler.warn-for-var-in-changes: ActionScript 3.0 iterates over an object's properties within a "for x in target" statement in random order.-->
            <warn-for-var-in-changes>false</warn-for-var-in-changes>
            <!-- compiler.warn-import-hides-class: Importing a package by the same name as the current class will hide that class identifier in this scope.-->
            <warn-import-hides-class>true</warn-import-hides-class>
            <!-- compiler.warn-instance-of-changes: Use of the instanceof operator.-->
            <warn-instance-of-changes>true</warn-instance-of-changes>
            <!-- compiler.warn-internal-error: Internal error in compiler.-->
            <warn-internal-error>true</warn-internal-error>
            <!-- compiler.warn-level-not-supported: _level is no longer supported. For more information, see the flash.display package.-->
            <warn-level-not-supported>true</warn-level-not-supported>
            <!-- compiler.warn-missing-namespace-decl: Missing namespace declaration (e.g. variable is not defined to be public, private, etc.).-->
            <warn-missing-namespace-decl>true</warn-missing-namespace-decl>
            <!-- compiler.warn-negative-uint-literal: Negative value will become a large positive value when assigned to a uint data type.-->
            <warn-negative-uint-literal>true</warn-negative-uint-literal>
            <!-- compiler.warn-no-constructor: Missing constructor.-->
            <warn-no-constructor>false</warn-no-constructor>
            <!-- compiler.warn-no-explicit-super-call-in-constructor: The super() statement was not called within the constructor.-->
            <warn-no-explicit-super-call-in-constructor>false</warn-no-explicit-super-call-in-constructor>
            <!-- compiler.warn-no-type-decl: Missing type declaration.-->
            <warn-no-type-decl>true</warn-no-type-decl>
            <!-- compiler.warn-number-from-string-changes: In ActionScript 3.0, white space is ignored and '' returns 0. Number() returns NaN in ActionScript 2.0 when the parameter is '' or contains white space.-->
            <warn-number-from-string-changes>false</warn-number-from-string-changes>
            <!-- compiler.warn-scoping-change-in-this: Change in scoping for the this keyword.  Class methods extracted from an instance of a class will always resolve this back to that instance.  In ActionScript 2.0 this is looked up dynamically based on where the method is invoked from.-->
            <warn-scoping-change-in-this>false</warn-scoping-change-in-this>
            <!-- compiler.warn-slow-text-field-addition: Inefficient use of += on a TextField.-->
            <warn-slow-text-field-addition>true</warn-slow-text-field-addition>
            <!-- compiler.warn-unlikely-function-value: Possible missing parentheses.-->
            <warn-unlikely-function-value>true</warn-unlikely-function-value>
            <!-- compiler.warn-xml-class-has-changed: Possible usage of the ActionScript 2.0 XML class.-->
            <warn-xml-class-has-changed>false</warn-xml-class-has-changed>
         </compiler>
         <!-- debug-password: the password to include in debuggable SWFs-->
         <!-- debug-password usage:
         <debug-password>string</debug-password>
         <!-- default-background-color: default background color (may be overridden by the application code)-->
         <default-background-color>0xFFFFFF</default-background-color>
         <!-- default-frame-rate: default frame rate to be used in the SWF.-->
         <default-frame-rate>24</default-frame-rate>
         <!-- default-script-limits: default script execution limits (may be overridden by root attributes)-->
         <default-script-limits>
            <max-recursion-depth>1000</max-recursion-depth>
            <max-execution-time>60</max-execution-time>
         </default-script-limits>
         <!-- default-size: default application size (may be overridden by root attributes in the application)-->
         <default-size>
            <width>500</width>
            <height>375</height>
         </default-size>
         <!-- externs: a list of symbols to omit from linking when building a SWF-->
         <!-- externs usage:
         <externs>
            <symbol>string</symbol>
         </externs>
         <frames>
            <!-- frames.frame: A SWF frame label with a sequence of classnames that will be linked onto the frame.-->
            <!-- frames.frame usage:
            <frame>
               <label>string</label>
               <classname>string</classname>
            </frame>
         </frames>
         <framework>halo</framework>
         <!-- include-inheritance-dependencies-only: only include inheritance dependencies of classes specified with include-classes -->
         <!-- include-inheritance-dependencies-only usage:
         <include-inheritance-dependencies-only>boolean</include-inheritance-dependencies-only>
         <!-- include-resource-bundles: a list of resource bundles to include in the output SWC-->
         <!-- include-resource-bundles usage:
         <include-resource-bundles>
            <bundle>string</bundle>
         </include-resource-bundles>
         <!-- includes: a list of symbols to always link in when building a SWF-->
         <!-- includes usage:
         <includes>
         </includes>
         <!-- link-report: Output a XML-formatted report of all definitions linked into the application.-->
         <!-- link-report usage:
         <link-report>filename</link-report>
         <!-- load-config: load a file containing configuration options-->
         <!-- load-externs: an XML file containing <def>, <pre>, and <ext> symbols to omit from linking when building a SWF-->
         <!-- load-externs usage:
         <load-externs>filename</load-externs>
         <metadata>
            <!-- metadata.contributor: A contributor's name to store in the SWF metadata-->
            <!-- metadata.contributor usage:
            <contributor>name</contributor>
            <!-- metadata.creator: A creator's name to store in the SWF metadata-->
            <creator>darkhutgme</creator>
            <!-- metadata.date: The creation date to store in the SWF metadata-->
            <!-- metadata.date usage:
            <date>text</date>
            <!-- metadata.description: The default description to store in the SWF metadata-->
            <description></description>
            <!-- metadata.language: The language to store in the SWF metadata (i.e. EN, FR)-->
            <language>EN</language>
            <!-- metadata.localized-description: A localized RDF/XMP description to store in the SWF metadata-->
            <!-- metadata.localized-description usage:
            <localized-description>
               <text>string</text>
               <lang>string</lang>
               <lang>string</lang>
            </localized-description>
            <!-- metadata.localized-title: A localized RDF/XMP title to store in the SWF metadata-->
            <!-- metadata.localized-title usage:
            <localized-title>
               <title>string</title>
               <lang>string</lang>
               <lang>string</lang>
            </localized-title>
            <!-- metadata.publisher: A publisher's name to store in the SWF metadata-->
            <publisher>darkhutgame</publisher>
            <!-- metadata.title: The default title to store in the SWF metadata-->
            <title>GAME</title>
         </metadata>
         <!-- raw-metadata: XML text to store in the SWF metadata (overrides metadata.* configuration)-->
         <!-- raw-metadata usage:
         <raw-metadata>text</raw-metadata>
         <!-- remove-unused-rsls: remove RSLs that are not being used by the application-->
         <remove-unused-rsls>true</remove-unused-rsls>
         <!-- resource-bundle-list: prints a list of resource bundles to a file for input to the compc compiler to create a resource bundle SWC file. -->
         <!-- resource-bundle-list usage:
         <resource-bundle-list>filename</resource-bundle-list>
         <!-- runtime-shared-libraries: a list of runtime shared library URLs to be loaded before the application starts-->
         <!-- runtime-shared-libraries usage:
         <runtime-shared-libraries>
            <url>string</url>
            <url>string</url>
         </runtime-shared-libraries>
         <!-- runtime-shared-library-path: specifies a SWC to link against, an RSL URL to load, with an optional policy file URL and optional failover URLs -->
         <runtime-shared-library-path>
            <path-element>/opt/flexsdk/4.6.0/frameworks/libs/textLayout.swc</path-element>
            <rsl-url>textLayout_2.0.0.232.swz</rsl-url>
            <policy-file-url></policy-file-url>
            <rsl-url>http://fpdownload.adobe.com/pub/swz/tlf/2.0.0.232/textLayout_2.0.0.232.swz</rsl-url>
            <policy-file-url>http://fpdownload.adobe.com/pub/swz/crossdomain.xml</policy-file-url>
         </runtime-shared-library-path>
            <path-element>/opt/flexsdk/4.6.0/frameworks/libs/osmf.swc</path-element>
            <rsl-url>osmf_1.0.0.16316.swz</rsl-url>
            <rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.6.0.23201/osmf_1.0.0.16316.swz</rsl-url>
            <path-element>/opt/flexsdk/4.6.0/frameworks/libs/framework.swc</path-element>
            <rsl-url>framework_4.6.0.23201.swz</rsl-url>
            <rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.6.0.23201/framework_4.6.0.23201.swz</rsl-url>
            <path-element>/opt/flexsdk/4.6.0/frameworks/libs/charts.swc</path-element>
            <rsl-url>charts_4.6.0.23201.swz</rsl-url>
            <rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.6.0.23201/charts_4.6.0.23201.swz</rsl-url>
            <path-element>/opt/flexsdk/4.6.0/frameworks/libs/rpc.swc</path-element>
            <rsl-url>rpc_4.6.0.23201.swz</rsl-url>
            <rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.6.0.23201/rpc_4.6.0.23201.swz</rsl-url>
            <path-element>/opt/flexsdk/4.6.0/frameworks/libs/mx/mx.swc</path-element>
            <rsl-url>mx_4.6.0.23201.swz</rsl-url>
            <rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.6.0.23201/mx_4.6.0.23201.swz</rsl-url>
            <path-element>/opt/flexsdk/4.6.0/frameworks/libs/advancedgrids.swc</path-element>
            <rsl-url>advancedgrids_4.6.0.23201.swz</rsl-url>
            <rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.6.0.23201/advancedgrids_4.6.0.23201.swz</rsl-url>
            <path-element>/opt/flexsdk/4.6.0/frameworks/libs/spark.swc</path-element>
            <rsl-url>spark_4.6.0.23201.swz</rsl-url>
            <rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.6.0.23201/spark_4.6.0.23201.swz</rsl-url>
            <path-element>/opt/flexsdk/4.6.0/frameworks/libs/spark_dmv.swc</path-element>
            <rsl-url>spark_dmv_4.6.0.23201.swz</rsl-url>
            <rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.6.0.23201/spark_dmv_4.6.0.23201.swz</rsl-url>
            <path-element>/opt/flexsdk/4.6.0/frameworks/libs/sparkskins.swc</path-element>
            <rsl-url>sparkskins_4.6.0.23201.swz</rsl-url>
            <rsl-url>http://fpdownload.adobe.com/pub/swz/flex/4.6.0.23201/sparkskins_4.6.0.23201.swz</rsl-url>
         <runtime-shared-library-settings>
            <!-- runtime-shared-library-settings.application-domain: override the application domain an RSL is loaded into. The supported values are 'current', 'default', 'parent', or 'top-level'.-->
            <application-domain>
               <application-domain-target>default</application-domain-target>
            </application-domain>
            <!-- runtime-shared-library-settings.force-rsls: force an RSL to be loaded, overriding the removal caused by using the remove-unused-rsls option-->
            <!-- runtime-shared-library-settings.force-rsls usage:
            <force-rsls>
            </force-rsls>
         </runtime-shared-library-settings>
         <!-- size-report: Output an XML-formatted report detailing the size of all code and data linked into the application.-->
         <!-- size-report usage:
         <size-report>filename</size-report>
         <!-- static-link-runtime-shared-libraries: statically link the libraries specified by the -runtime-shared-libraries-path option.-->
         <static-link-runtime-shared-libraries>false</static-link-runtime-shared-libraries>
         <!-- swf-version: specifies the version of the compiled SWF file.-->
         <swf-version>14</swf-version>
         <!-- target-player: specifies the version of the player the application is targeting. Features requiring a later version will not be compiled into the application. The minimum value supported is "9.0.0".-->
         <target-player>11.1.0</target-player>
         <!-- tools-locale: specifies the locale used by the compiler when reporting errors and warnings.-->
         <!-- tools-locale usage:
         <tools-locale>string</tools-locale>
         <!-- use-direct-blit: Use hardware acceleration to blit graphics to the screen, where such acceleration is available.-->
         <!-- use-direct-blit usage:
         <use-direct-blit>boolean</use-direct-blit>
         <!-- use-gpu: Use GPU compositing features when drawing graphics, where such acceleration is available.-->
         <!-- use-gpu usage:
         <use-gpu>boolean</use-gpu>
         <!-- use-network: toggle whether the SWF is flagged for access to network resources-->
         <use-network>true</use-network>
         <!-- verify-digests: verifies the libraries loaded at runtime are the correct ones.-->
         <verify-digests>true</verify-digests>
         <!-- warnings: toggle the display of warnings-->
         <!-- warnings usage:
         <warnings>boolean</warnings>
      </flex-config>
