5 Replies Latest reply on Apr 19, 2012 5:49 AM by linopasc
    Can't execute functions correctly in a button event
    phoenix2ch
      I have some troubles with a script in JS, i can't execute correctly the code when i'm use a button event like:
      // Change button
      var btn = this.getField('Change');
      btn.setAction("MouseUp", "refreshLayers()");
      When i don't use a event and put directly the function in the code, it's work.
      error return:
      "SyntaxError: missing } in compound statement
      95: à la ligne 95" (line 95)
      Here my script, there isn't missing a '}':
      function changeAll(sSelected, sCible) {
                var sName, i, iExceptLength = sCible.length, aOCGs = this.getOCGs();
                for (i = 0; aOCGs && i < aOCGs.length; i += 1) {
                    sName = aOCGs[i].name;
                    if(sCible == sName.substring(0, iExceptLength) && sName != sSelected) {
                                    aOCGs[i].state = false;
                          else if(sName == sSelected) {
                                    aOCGs[i].state = true;
      function refreshLayers() {
                var tmp = this.getField('Shape');
                var iCurrentIndex = tmp.currentValueIndices;
                var a = tmp.getItemAt(iCurrentIndex, false);
                tmp = this.getField('Color');
                var b = tmp.getItemAt(iCurrentIndex, false);
                tmp = this.getField('ColorPrice');
                var c = tmp.getItemAt(iCurrentIndex, false);
                changeAll(a+'_'+b, 'Shape-');
                changeAll('Price_'+c, 'Price_');
      function inArray(search, a) {
                var bFinded = false;
                var i;
                for (i = 0; i < a.length && bFinded == false; i++) {
                                    if (a[i] == search)
                                              bFinded = true;
                return bFinded;
      function init() {
      // Selectors names
      var sSelectName = 'Shape';
      var sColorSelectName = 'Color';
      var sPriceSelectName = 'ColorPrice';
      // Get the select object with name
      var select = this.getField(sSelectName);
      var selectColor = this.getField(sColorSelectName);
      var selectPrice = this.getField(sPriceSelectName);
      // Clear items
      selectColor.clearItems();
      selectPrice.clearItems();
      select.clearItems();
      var iSelectNameLength = sSelectName.length;
      var aSelectOCGs = new Array();
      // Get all layers
      var aOCGs = this.getOCGs();
      // Init.
      var aShapes=new Array();
      var sOCGsName='';
      var sShapeName='';
      var aColors=new Array();
      var sColorName='';
      var iOCGsNameLength;
      // Insert the items
      var i;
      for (i=0; aOCGs && i<aOCGs.length;i++) {
                sOCGsName = aOCGs[i].name;
                sShapeName = sOCGsName.substring(0, iSelectNameLength+2);
                iOCGsNameLength = sOCGsName.length;
                sColorName = sOCGsName.substring(iSelectNameLength+3, iOCGsNameLength);
                if (sOCGsName.substring(0, iSelectNameLength) == 'Shape') {
                          // For colors
                          if(!inArray(sColorName, aColors)) {
                                    aColors.push(sColorName);
                                    selectColor.insertItemAt(sColorName);
                                    selectPrice.insertItemAt(sColorName);
                                    console.println(sColorName+' added');
                          // For shapes
                          if (!inArray(sShapeName, aShapes)) {
                                    aShapes.push(sShapeName);
                                    select.insertItemAt(sShapeName);
      // Clear the console
      console.clear();
      // init
      init();
      // Change button
      console.println('end');
      Someone see something false?
      Thanks for help and sorry for my bad english.
        • 1. Re: Can't execute functions correctly in a button event
          This code does look OK... maybe the error comes from some other code in your file?
          • 2. Re: Can't execute functions correctly in a button event
            phoenix2ch Level 1
            Tanks for your answer try67,
            It's the only code, i checked with the button "Modify all javascript" (named in french for me "Modifier tous les scripts javascript")
            And there is just my code in the comments
            //<Document-Level>
            //<ACRO_source>test</ACRO_source>
            //<ACRO_script>
            /*********** appartient à : Document-Level:test ***********/
            [my code]
            //</ACRO_script>
            //</Document-Level>
            and the event for the buttons:
            //<AcroForm>
            //<ACRO_source>Change:Annot1:MouseUp:Action1</ACRO_source>
            //<ACRO_script>
            /*********** appartient à : AcroForm:Change:Annot1:MouseUp:Action1 ***********/
            refreshLayers();
            //</ACRO_script>
            //</AcroForm>
            I try to delete it and re-execute, but no change :/
            There is something strange, if a delete, for example a function, i always can call this function.
            So maybe my code is saved somewhere else, but i don't know where.
            • 3. Re: Can't execute functions correctly in a button event
              Very likely you have the same code appearing in more than one place. Do you
              have any folder-level scripts installed?
              If you wish, send me the file in question to try6767 at gmail dot com, and
              I'll have a look at it.
              • 4. Re: Can't execute functions correctly in a button event
                phoenix2ch Level 1
                If i put my event fonctions in an other file, it's work
                I don't understand what is exactly the probleme, maybe it's because I restart with a new PDF file.
                Thanks you very much
                • 5. Re: Can't execute functions correctly in a button event
                  linopasc
                  I had similar problems when editing document-level javascript (javascript pro 8). After changes the new script works as the old script. In all cases  I found a syntax error in the new script. Unfortunately the javascript editor does not give any message for syntax error. I use the following to reveal syntax errors:
                  Suppose to write the following  document-level script
                  app.alert("Ok")
                  function Sum(x,y)
                  app.alert(x + y)
                  when you close the editor you will recieve the message "Ok"
                  suppose instead to write
                  app.alert("Ok")
                  function Sum(x,y       // (bracket missing)
                  app.alert(x + y)
                  you will not recieve the message because the syntax error. Try it !
